Hello,
I have Arduino Uno, and 28BYJ-48 Stepper motor with a uln2003an driver.
I am new with the Arduino programming. It seems like I set up the connection between the software I have and the Arduino Uno.
Connection of pins:
On ULN2003An driver 1 through 4 is connected to Arduino Uno 8through 11.
Pin 5 is not connected, I am powering up the motor using a battery kronox, I looked through multimeter, it gives 6volts.
For now, I am trying to basically rotate my motor clockwise and after 5 seconds counterclockwise.
- I am not sure what kind of number is appropriate for motor speed. I am randomly using 5, which number would suite more?
I got an understanding on one code and edited it for my purpose.Does it make sense, please help me if anything doesn't make sense for you.
Here is my code:
//declare variables for the motor pins
int motorPin1 = 8; // Blue - 28BYJ48 pin 1
int motorPin2 = 9; // Pink - 28BYJ48 pin 2
int motorPin3 = 10; // Yellow - 28BYJ48 pin 3
int motorPin4 = 11; // Orange - 28BYJ48 pin 4
int motorSpeed = 5; //variable to set stepper speed
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
void loop(){
clockwise(); //make clockwise rotation
delay (5000); //delay for 5 seconds
counterclockwise(); //make counterclockwise rotation
//set pins to ULN2003 high in sequence from 1 to 4
//delay "motorSpeed" between each pin setting (to determine speed)
void counterclockwise (){
// 1
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
delay(motorSpeed);
// 2
digitalWrite(motorPin2, HIGH);
delay (motorSpeed);
// 3
digitalWrite(motorPin1, LOW);
delay(motorSpeed);
// 4
digitalWrite(motorPin3, HIGH);
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
digitalWrite(motorPin4, HIGH);
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
//set pins to ULN2003 high in sequence from 4 to 1
void clockwise(){
// 1
delay(motorSpeed);
// 2
delay (motorSpeed);
// 3
delay(motorSpeed);
// 4
delay(motorSpeed);
// 5
delay(motorSpeed);
// 6
delay (motorSpeed);
// 7
delay(motorSpeed);
// 8
delay(motorSpeed);
