2ch 10-Bit DAC LTC1662
So I was working on a project and created this code for a DAC for the Arduino. No more using Capacitors and PWM.
//Code for LTC1662 2 channel DAC Converter
//By Weston Smith
//11-10-09
#define DATA_PIN 11
#define LOAD_PIN 13 //Set these 3 pins to your liking
#define CLOCK_PIN 12
pinMode(DATA_PIN, OUTPUT); // sets the digital pins as outputs
pinMode(LOAD_PIN, OUTPUT);
digitalWrite(LOAD_PIN, HIGH);
pinMode(CLOCK_PIN, OUTPUT);
digitalWrite(CLOCK_PIN, LOW);
void updateDAC(int XYZ, int val) //val should be 0-1023
byte data1 = 0;
byte data2 = 0;
byte first =0;
byte mid = 0;
if(val>255)
mid = B00000100;
if(val>511)
mid = B00001000;
if(val>767)
mid = B00001100;
if(XYZ == 'X' || XYZ == 'x') //Updates Analog Output A
first = B10010000; //data1= '10010000' First 4 bits are "Command Code"
if(XYZ == 'Y' || XYZ == 'y') //Updates Analog Output B
first = B10100000; // sets first four bits to 1010
if(XYZ == 'Z' || XYZ == 'z') //Updates Analog Output A & B to same value
first = B11110000; // sets first four bits to 1111
data1 = first + mid + (byte(val)>>6);
data2 = byte(val) << 2;
digitalWrite(LOAD_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, data1);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, data2);
updateDAC('x',1023);
