3 axis auto stabilized platform
hey guys i'm doing a project on 3 axis auto stabilized camera platform.. i'm using the arduino as the prototyping platform.
so what i am using is IDG300 n ADXRS300 as gyros..... i need to integrate this together with the R/C transmitter.. so that I can control it using RC as well as it has auto stabilized capability as well at the same time...
can somebody share some insights on how the sequence of the program shld be like? i'm currently having problems....
hey..ok.. maybe i post more description about my blog...
you see, i am using the pulseIn function to read my R/C
xtime = pulseIn(2,HIGH);
digitalWrite(6,HIGH); delayMicroseconds(xtime); digitalWrite(6,LOW);
ytime = pulseIn(3,HIGH);
digitalWrite(7,HIGH); delayMicroseconds(ytime); digitalWrite(7,LOW);
ztime = pulseIn(4,HIGH);
digitalWrite(8,HIGH); delayMicroseconds(ztime); digitalWrite(8,LOW);
and then i am reading in the pulse from the RC receiver and into my arduino and using it to pulse my servos...
it works fine with only this code.
but thenext step of my projet is to integrate it together with the sensors..... but i dont know how to configure the interrupt.... how do i pulse the servos and at the same time not affect my program code for obtaining the sensor data?
hi can any one help? i am looking to pulse the servo simultaneously....
anyway to do this efficient? either using interrupt or a function?
Input capture on pin 8 is the most efficient and accurate way of measuring pulse widths at the same time your sketch is doing something else. There is only one Input Capture pin so you would need to measure the composite signal where each channel pulses in sequence followed by a relatively long (at least 4 millisecond) sync gap to indicate the start of the next sequence of channel pulses.
A code fragment for Input Capture was posted in this thread http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201890734/12 It would need enhancing to recognize the sync delay and then store the widths of the channel pulses.
Assuming you are driving this from a radio control receiver then you could 'or' the channels together to get a composite signal to feed into the Arduino input capture pin.
Or you could use a receiver that has the composite signal somewhere on the PCB. I have been poking around with the Hitec [u]HF-05s receiver[/u] recently and if you can do the precision soldering to the tiny surface mount pin, this should work. These receivers are small, reliable and inexpensive; versions seem to be available in every country where RC equipment is sold.
This receiver uses a Pic [u]16F676[/u] microcontroller to decode the pulses from the radio circuit and drive the servo pins. One of the Pic's pins has the composite signal at digital levels suitable for driving an Arduino if you can solder a tiny wire to the correct place on the board to get at it.
Pin 11 (RA3) has the composite pulse train at digital levels. The radio circuit powers the Pic through a 5v to 3.3 volt regulator so the output pulses are 0v low and around 3v high.
FYI, Pin 13 (RA0) is the composite input signal from the radio circuit.
I don't have any more code than I have already posted so unless someone else has done the work and can publish it here, you would be pioneering this. I would be glad to provide advice and I am sure there are others with similar applications would benefit if you published your results.
hi.. actually i'm using the futaba PCM1024 receiver...and i'm using pitch, roll, yaw, 3 channels at one time...
i'm directly feeding it to digital pins, 2,3,4... but i'm having problems.... the whole loop takes 28 msecs and when i time them using digitalwrite separately, i get 14 msecs for each channel pulsein function.. but when i time them 3 channels together.... roll gets 14 ms... but yaw n pitch gets only 7 ms.. so i'm thinking whether is it becos of lack of processing time from the atmel chip..
sorry for asking.. but how do i actually connect it to the same pin 8? that means i short the 3 channels together?
i'm in a rush actually... have a couple of wks to finish everyhting.. plus integration with the gyro signals and everything...
this is the same of the code i'm using
  digitalWrite(10,HIGH);
  pin = servoRoll;
  pulseWidthx = xtime;
  update_servo(pin, pulseWidthx);
  //digitalWrite(11,HIGH);
  //digitalWrite(11,LOW);
  pin = servoPitch;
  pulseWidthy = ytime;
  //digitalWrite(12,HIGH);
  //digitalWrite(12,LOW);
  pin = servoYaw;
  pulseWidthz = ztime;
  update_servo(pin, pulseWidthz);
  digitalWrite(10,LOW);
void update_servo(int pin,long pulsewidth)
  long pulse = 0;
  int pin_num = 0;
  pin_num = pin;
  pulse = pulsewidth;
  if(millis()- lastPulse >= RefreshTime)
      digitalWrite(pin_num, HIGH);
      delayMicroseconds(pulse);
      digitalWrite(pin_num, LOW);
      lastPulse = millis();
You could build a diode logic 'or' gate with yr three receiver outputs connected to diodes so the output will be high when any of the inputs is high. Here is some more info: http://en.wikipedia.org/wiki/Diode_logic
if we were to use an OR logic gate.. how is the micro p going to differentiate within the 3 channels? i.e. which is which channel, so that it can pulse the servo?
The channels are pulsed in order and channel 1 is the first channel after the long sync delay.
actually i’m testing it out for 1 channel right now… here’s the code… but i’m getting erratic pulses coming out from my pin 7…
volatile unsigned int Ticks;         // holds the pulse count as .5 us ticks
int icpPin = 8;                       // this interrupt handler must use pin 8
int servoRoll = 7;
long pulsewidthX = 0;
int RefreshTime = 20;
long lastPulse = 0;
ISR(TIMER1_CAPT_vect){
   if( bit_is_set(TCCR1B ,ICES1)){       // was rising edge detected ?
       TCNT1 = 0;                        // reset the counter
   else {                                // falling edge was detected
        Ticks = ICR1;
   TCCR1B ^= _BV(ICES1);                 // toggle bit value to trigger on the other edge
void setup()                    // run once, when the sketch starts
  pinMode(icpPin,INPUT);
  TCCR1A = 0x00;         // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
  TCCR1B = 0x02;         // 16MHz clock with prescaler means TCNT1 increments every .5 uS (cs11 bit set
  Ticks = 0;             // default value indicating no pulse detected
  TIMSK1 = _BV(ICIE1);   // enable input capture interrupt for timer 1
int getTick() {
  int akaTick;       // holds a copy of the tick count so we can return it after re-enabling interrupts
  cli();             //disable interrupts
  akaTick = Ticks;
  sei();             // enable interrupts
  return akaTick;
void loop()                     // run over and over again
  static int prevTick = 0;
  if( getTick()  != prevTick) {
      prevTick = getTick();
        pulsewidthX = prevTick;
        update_servo(servoRoll,pulsewidthX);
//Serial.println( prevTick/2);     // print the tick value only when it changes  value of tick/2 to get in microseconds
  long pulse = 0;
  int pin_num = 0;
  pin_num = pin;
  pulse = pulsewidth;
the problem is … sometimes there is a pulse… sometimes there isnt…
There are a few issues with that sketch. Its not waiting for the sync pulse so the routine has no idea what channel it is measuring. Also the code fragment it is based on was for a sony remote control that synchronises with a pulse that is longer then the data pulses, your receiver synchronises using a long space between the data pulses
I have modified the original sketch I posted to accommodate these differences and added some code to provide debug output on the channel pulse widths.
I have not run this code and its likely to need some fixing to get it to work so make sure the debug output gives the results you expect (pulses between 1000us and 2000us that vary with the transmitter controls) before you risk connecting any servos to this.
The most likely problem you will hit is that the detection on the rising and falling edges may need to be reversed. Its easy to do but we need to see what the debug looks like with your receiver to see if that change is necessary.
Looking forward to seeing the debug output.
#define icpPin            8         // this interrupt handler must use pin 8
#define TICKS_PER_uS      2          // number of timer ticks per microsecond
#define MAX_CHANNELS    8         // maximum number of channels we can store
#define SYNC_GAP_LEN      (3000 * TICKS_PER_uS) // we assume a space at least 3000us is sync (note clock counts in 0.5 us ticks)
volatile unsigned int Pulses[ MAX_CHANNELS + 1]; // array holding channel pulses width value in microseconds
volatile uint8_t  Channel;      // number of channels detected so far in the frame (first channel is 1)
volatile uint8_t State;         // this will be one of the following states:
#define NOT_SYNCHED_state  0    // the system is not synched so the data is random
#define ACQUIRING_state  1      // one sync pulse detected but not all channels have been received
#define READY_state     2       // synched and all channel data is valid
   if(! bit_is_set(TCCR1B ,ICES1)){       // was falling edge detected ?
       if(Channel <= MAX_CHANNELS) {
           Pulses[Channel++] = ICR1 / TICKS_PER_uS;  // store pulse length as microsoeconds
   else {                          // rising  edge was detected
        if(ICR1 >= SYNC_GAP_LEN){   // is the space between pulses big enough to be the SYNC
            Channel = 1;       // if so, reset the channel counter to 1
              if(State == NOT_SYNCHED_state)
                  State = ACQUIRING_state;        // this is the first sync pulse, we need one more to fill the channel data array
              else if( State == ACQUIRING_state)
                   State = READY_state;           // this is the second sync so flag that channel data is valid
  Channel = 1;
  State = NOT_SYNCHED_state;
int GetChannelPulseWidth( uint8_t channel) {
  // this is the access function for channel data
  int result;
  if( (State == READY_state)  && (channel > 0) && (channel <=  MAX_CHANNELS)  ) {
     result =  Pulses[channel] ;
     result = 0;        // return 0 if no valid pulse is available
  return result;
int pulsewidth;
   // print the decoder state
       Serial.println("The decoder has not detected a synch pulse ");
   else if ( State == ACQUIRING_state)
       Serial.println("The decoder has detected one synch pulse and has started filling channel data");
   else if( State == READY_state)
     Serial.println("The decoder is synched and the channel data is valid");
     Serial.println("Unknown decoder state, this should never happen!");
  // now print the channel pulse widths
  // they should be 0 if the state is not ready
  for ( int i =1; i <=4; i++ ){ // print the status of the first four channels
      Serial.print("Channel ");
      Serial.print(i);
      Serial.print(" has width ");
      pulsewidth = GetChannelPulseWidth(i);
      Serial.println(pulsewidth);
  delay(100); // update 10 times a second
hi thanks. i will try that later at school...
anyway.. i didnt use a diode. instead i used a 8 to 1 mutiplexer to control the pulse coming in...
had problems intregrating it with the servos too.. hope your code will help. i will debug it later..
and post the results. thanks a lot!
Try to resist connecting the servos till the code is debugged, there will be some things that need fixing and it would be a shame to burn out your servos.
Edit: I wonder how you will gate your multiplexer? I think you will be much better off with an or gate.
ya sure. i always test read the pulse on the scope before connecting. :)
actually i still dont really understand something. if you OR all the pulses, how will the microP be able to pick up the signal? since all 3 falls under 1 signal.
i read the 3 channels on the oscilloscope. the 1st 2 actually overlaps.. the 3rd pulse is somewhere in btween the other 2.
regarding the multiplexer. i had to control the channel (OUT) by pulsing 3 pins, a combination of either HIs or LOWs to get the pins i want. so basically i did that 3 times in a loop to get the 3 pulses.
is that the correct way to do?
Can you use that receiver in PPM mode?
If your receiver can't output the channels sequentially then you will have difficulty decoding the channels. I think you will have a lot less aggravation if you can find a cheap PPM receiver to use for your project.
I am not really sure. I will ask someone tomo.
thanks for your help. will post the results when i go to school later in the morning.
There is some info on this site http://www.mp.ttu.ee/risto/rc/electronics/radio/signal.htm about receiver pulse output that has what looks like the wavform for a Futaba PCM1024 receiver that appears to be sequential. I believe Futaba have updated the design in this model over time without changing the model number so yours may be different.
actually i read that website before... the pulse that I am getting is actually 1.5 ms pulse with regular intervals. i read it on the scope.. it doesnt look sequential.
i tried your code... the output i get is kinda not really correct.
somehow only the 1st channel is read correctly but not all the time. and channel 2/3 is just 1 or 2 numbers at time..
maybe using the multiplexer would be a better approach?
How about posting the debug output so I can see what the software thinks is happening. Do a run with only one channel connected and another run with three channels connected if you can.
That code expects the pulses to be sequential so if they are not then you could use the multiplexer but that would mean that your data will be updated less frequently, every 3 frames (60ms) for 3 channels but that may be ok in your application.
hi
the 3 channels debug is available at this url http://axileon.com/blog/debug_3channels.jpg
the 1 channel is here. http://axileon.com/blog/debug_1channel.jpg
for the 1 channel.. i noticed something strange.
the 1st channel will output the correct pulsewidth if i turn off the transmitter. but when i turn it on,it gets the output similar to the image above. this is so if I pass the signal thru the diode...
but If i drive the whole thing directly by the signal from the receiver. everything is fine.
i also tried using the mutiplexer method... for 3 channels...
however i only got readings for the channel 1. the other 2 channels are zero. for 3 channels. i.e channel 1 has width 1450,(this is actually the value for channel 3) channel 2 has width 0. channel 3 has width 0.
It does look like the channel pulses are not sequential so you will probably need to use the multiplexer with your receiver. The challenge is to get the switching of the multiplexer synchronized so that you don't miss part of a pulse. To do this you need to ensure that you only switch the multiplexer to the next channel after that channels pulse goes low (that's the easy part) and you need to wait before taking the next pulse width measurement until you are sure that channels pulse has not already gone high.
One way to do this is to take two readings for each channel before moving on to the next one. It won't matter if the first measurment was in error because it will be overwritten by the second. The disadvantage of this technique is that it takes twice as long for changing pulse widths to be recognized but that may not matter in your application.
If you use this method then you can ignore the existing code to detect the sync pulse and replace that with a counter that increments the channel counter after the second trailing edge is detected.
If that isn't clear then I will try to post some pseudo code.
Or, if it is ok to miss some pulses then perhaps you should reconsider using pulsein with the multiplexer. The logic would be similar to the above: Wait for the trailing edge of the previous pulse, then store the next pulse in the channel array, increment the channel and repeat. The advantage of the interrupt version is that it will never miss a pulse edge no matter what your code is doing but it will only work if the pulses are sequential. As yours are not than perhaps the simpler PulseIn route is better for your app.
