3 buttons 3 LEDs
Can anyone make me a code like this but with 3 buttons and LEDs?
I have searched and searched but without finding something that has helped me. Have promised to make something to a friend but I have probably promised more than I can bear... :frowning:
What specifically do you intend to do?
That happens to many of us. :wink:
We can help you write this.
What hardware do you have?
What programming have you done in the past?
Oh, thank you :smiley:
I have a Uno r3 and a lot of LEDs, buttons, resistors etc. So i should be good to go :slight_smile:
I have just done some basic programming, not much. I have managed to get one LED to turn on/off, but when I tried 2 LEDs, I ended up pulling my hair off...
What I need is that when I press button1, LED1 lights up and stays on until I press button1 again. And when I press button2, LED2 lights up and so on.
But if possible, if I press button1, led1 lights up and led2 and led3 are "low". And if i press button2 is led2 on and led1 and led3 "low" and if button3 is pressed then led3 is on and led1 and led2 off?
Show us a schematic (hand drawn or otherwise) of how you plan to wire the LEDs and switches.
There is an example called "State Change in Detection" in the examples that comes with the IDE.
Edit
You could modify this as needed:
  SwitchChangeDetectionSimple.ino
  LarryD
  Version YY/MM/DD
  1.00    16/09/28   Running code
  1.01    16/09/30   Added heartbeat LED
  Demonstrates switch state change detection, no library.
//+5V----InternalPullupResitor----InputPin----[SwitchPin1/SwitchPin2]----GND
#define Pressed  LOW
#define Released HIGH
//+5V----[LEDanode/LEDcathode]----[220ohmResistor]----OutputPin
#define LEDon    LOW
#define LEDoff   HIGH
  //+5V----[SwitchPin1/SwitchPin2]----InputPin----[10K resistor]----GND
  #define Pressed  HIGH
  #define Released LOW
  //OutputPin----[LEDanode/LEDcathode]----[220ohmResistor]----GND
  #define LEDon    HIGH
  #define LEDoff   LOW
const byte  switchOne    = 8;
const byte  switchTwo    = 9;
const byte  LED_One      = 11;
const byte  LED_Two      = 12;
const byte  heartBeatLED = 13;
byte switchOneState;
byte lastswitchOneState;
byte lastswitchTwoState;
unsigned long heartBeatMillis;
unsigned long switchMillis;
//                          s e t u p ( )
  pinMode(switchOne, INPUT_PULLUP);
  pinMode(switchTwo, INPUT_PULLUP);
  pinMode(heartBeatLED, OUTPUT);
  pinMode(LED_One, OUTPUT);
  digitalWrite(LED_One, LEDoff);
  pinMode(LED_Two, OUTPUT);
  digitalWrite(LED_Two, LEDoff);
} //END of                  s e t u p ( )
//                           l o o p ( )
  //check for blocking code
  heartBeat();
  //do some loop() stuff
  //every 50ms check the switches
  if (millis() - switchMillis >= 50ul)
    //reset timing
    switchMillis = millis();
    //check switchOne
    if (checkSwitch(switchOne, lastswitchOneState) == true)
      //toggle LED
      digitalWrite(LED_One, !digitalRead(LED_One));
    //check switchTwo
    if (checkSwitch(switchTwo, lastswitchTwoState) == true)
      //toggle LED
      digitalWrite(LED_Two, !digitalRead(LED_Two));
  }//END of     if (millis() - switchMillis >= 50ul)
} //END of                   l o o p ( )
//                        F U N C T I O N S
//                      h e a r t B e a t ( )
//optional, check for blocking code
//toggle heartBeatLED every 500ms
void heartBeat()
  if (millis() - heartBeatMillis < 500ul)
    //nothing to do yet
    return;
  //reset timing
  heartBeatMillis = millis();
  //toggle LED
  digitalWrite(heartBeatLED, !digitalRead(heartBeatLED));
}//END of               h e a r t B e a t ( )
//                    c h e c k S w i t c h ( )
//check if a switch has changed state
bool checkSwitch(byte switchPin, byte &lastState)
  byte thisSwitchState = digitalRead(switchPin);
  //was there a change in state?
  if (thisSwitchState != lastState)
    //update the switch state
    lastState = thisSwitchState;
    if (thisSwitchState == Pressed)
      //this switch was pressed
      return true;
      //this switch was released
      //nothing to do here
  }//END of    if (thisSwitchState != lastState)
  return false;
}//END of             c h e c k S w i t c h ( )
//                       E N D  O F  C O D E
EDIT
Updated code
here is what i have
OPs diagram.
Tom.. :slight_smile:
As mentioned, the sketch in post #4 can be modified do do what you want, give it a try.
Oh, great, another unreadable Fritzing.
A few comments.
I see the buttons are paired with a resistor. Wire your buttons between the pin and ground and enable the internal pull-up, then you can lose the external resistor. Note that buttons are active LOW in this case, so logic is reversed.
You'll have to look into debouncing your buttons (either in hardware - with a small capacitor - or in software, a short delay/blackout is probably good enough for you - the sketch in #4 has a 50 millisecond interval which should be good enough), so you don't register multiple presses upon a single press.
Other than that your code should be fairly straightforward. A great beginners project to get to understand the basics.
