3 phase Pure sine wave inverter
I want to design three phase sine wave inverter using Arduino I have already implement single phase sine wave inverter using pic microcontroller available on this link pure sine wave inverter using microcontroller Mr Malik has done very good work. But now I want to design three phase inverter.
Can any body help me out how can I generate phase shift of 120$ between three SPWMS as post on the link given.
Kindly reply I will be very thankful to you
thanks :slight_smile:
there are likely many ways to generate 3 sine waves 120 deg phase apart..
u might start here--
with the playground example for generating one sine wave
and then it should be pretty simple to just sample from the table 1/3 ahead and 2/3 ahead
for the other two legs..
I finally designed three phase sine wave inverter using Arduino you can check this link for more information on circuit and code
Nice. What do you use it for?
