abhixs
November 18, 2022, 7:21am
1
Hello all,
I want to add 3 push button on my project to preform 3 different condition, see the code below.
But this code is working for only button i.e A5 and other button and its condition not working.
please help
int s1 = 0;
int s2 = 0;
int s3 = 0;
int relay1 = A1; //relay1
int relay2 = A2; //relay1
int relay3 = A3; //relay3
pinMode(A5, INPUT_PULLUP);// define pin two as input for push button
pinMode(A6, INPUT_PULLUP);// define pin two as input for push button
pinMode(A7, INPUT_PULLUP);// define pin two as input for push button
pinMode(relay1,OUTPUT);
pinMode(relay2,OUTPUT);
pinMode(relay3,OUTPUT);
digitalWrite(relay1,LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
//// conditions //// conditions //// conditions //// conditions //// conditions
if (s1==0 && s2==1 && s3==0){
digitalWrite(relay1, HIGH);
if (s1==1 && s2==1 && s3==0){
digitalWrite(relay2, HIGH);
if (s1==1 && s2==1 && s3==1){
digitalWrite(relay3, HIGH);
//// buttons //// buttons //// buttons //// buttons
int b1 = digitalRead(A7);
if (b1 == LOW)
s1=1;
int b2 = digitalRead(A6);
if (b2 == LOW)
s3=1;
int b3 = digitalRead(A5);
if (b3 == LOW)
s2=1;
Hello abhixs
Take here a view to get some ideas.
What experience do you have in programming in c++?
Hi, @abhixs
Is there a reason you are using the analog input pins, they can be used for digital, instead of the D digital pins.
What model Arduino are you using?
If it is a Nano, A6 and A7 are not fitted with internal pullup resistors.
You will have to fit 10K pullup resistors externally.
What happens if b1, b2 or b3 are == HIGH ?
Tom...
abhixs
November 18, 2022, 8:19am
4
I am using ARDUINO NANO board , and i can use D pin but it is not working on D pin also.
if b1, b2 or b3 are == HIGH it start working directly upon switch on.
I think i need to put 10K pullup resistors as you suggested.
You need to code for the HIGH input case as well.
if (b1 == LOW)
s1=1;
s1 = 0;
if (b2 == LOW)
s3=1;
s3 = 0;
if (b3 == LOW)
s2=1;
s2 = 0;
This might be why it didn't work when you used the digital pins.
A6 and A7 do not work as digital pins.
Rewrite your code for D pins.
There is an easier way to write this code, but lets use yours for starters.
Tom...
abhixs
November 18, 2022, 9:42am
6
Hi @TomGeorge ,
I updated the code with digital pin, but this is still not working, only last condition
delay (1000);
digitalWrite(relay1, LOW);
delay (1000);
s2=0;
s1=0;
s3=0;
is working upon pressing D6 connected button
Updated code with digital pin
int s1 = 0;
int s2 = 0;
int s3 = 0;
pinMode(4, INPUT_PULLUP);// define pin two as input for push button
pinMode(5, INPUT_PULLUP);// define pin two as input for push button
pinMode(6, INPUT_PULLUP);// define pin two as input for push button
s2=0;
if (s1==0 && s2==1 && s3==1){
delay (1000);
s2=0;
s1=0;
delay (1000);
delay (1000);
s2=0;
s1=0;
s3=0;
int b1 = digitalRead(4);
if (b1 == LOW)
s1=1;
s1 = 0;
int b2 = digitalRead(5);
if (b2 == LOW)
s3=1;
s3 = 0;
int b3 = digitalRead(6);
if (b3 == LOW)
s2=1;
s2 = 0;
Remove these from the if statements.
// s2=0;
delay (1000);
// s2=0;
// s1=0;
delay (1000);
delay (1000);
// s2=0;
// s1=0;
// s3=0;
You don't need to intitialise the s variables now that you have the "else" statements when you read the buttons.
Tom...
abhixs
November 18, 2022, 10:39am
8
Removed s variables but still it is having same issue, only last if statement is working by pressing D6 button
gcjr
November 18, 2022, 10:41am
9
not sure if you tried pressing more than one button at a time because the only condition that requires just one button to be pressed to energies a relay is when s2 is 1 and the s1/s3 are 0.
the 2nd condition requires that s1 is 1 and A7 is pressed AND s2/A5
the 3rd condition requires all 3 buttons to be pressed
abhixs
November 21, 2022, 4:39am
10
Yes you are right, and i am facing this error and unable to solve at my end.
abhixs
November 21, 2022, 4:41am
11
can you please suggest other easier way to write this code..please
JCA34F
November 21, 2022, 5:06am
12
How are your buttons wired to the input pins? Which button is wired to which input pin? Which relay board are you using? Are the relays enabled with a HIGH signal or a LOW signal? Where does the relay board power come from? If from the Nano's 5V pin, it will not work correctly.
So what happens when you press S1, S2, and S3 TOGETHER?
Does relay1 go ON for 1second, OFF for 1second, then ON.
Can you tell us what sequence you want for each combination of button presses.
Make a table.
NOTE for your if statements to work, you must operate the relevant buttons TOGETHER, NOT one after the other.
Tom....
abhixs
November 21, 2022, 7:06am
14
Currently i am not using relay, it is connected with led.
Hello abhixs
And again:
Post a schematic and a timing diagram.
gcjr
November 21, 2022, 9:25am
16
do you want each of your conditions to depend on multiple button presses or just a single button?
if the one case works, your buttons are wires properly
abhixs
November 21, 2022, 9:34am
17
Yes i need exactly this ...attaching my schematic.
My updated code
int s1 = 0;
int s2 = 0;
int s3 = 0;
int led1 = A1; //led1
int led2 = A2; //led1
int led3 = A3; //led3
pinMode(D2, INPUT_PULLUP);// define pin two as input for push button
pinMode(D3, INPUT_PULLUP);// define pin two as input for push button
pinMode(D4, INPUT_PULLUP);// define pin two as input for push button
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
digitalWrite(led1,LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
digitalWrite(led3, HIGH);
int b1 = digitalRead(D4);
if (b1 == LOW)
s1=1;
int b2 = digitalRead(D3);
if (b2 == LOW)
s3=1;
int b3 = digitalRead(D2);
if (b3 == LOW)
s2=1;
gcjr
November 21, 2022, 9:48am
18
abhixs:
so what happens when you press all 3 buttons at the same time and when you press buttons attached to A5 and A7 at the same time?
abhixs
November 21, 2022, 10:09am
19
nothing happening, my requirement is different i.e:
1. when b1 is pressed then nothing will happen
2. when b1 and after b2 is pressed then this should triggered
3. when only b2 is pressed then this should triggered
4. when b3 and after b2 and after b1 is pressed then this should triggered
noiasca
November 21, 2022, 10:11am
20
you still don't reset your variables to 0 if the button gets released.
untested:
const byte s1 = 0;
const byte s2 = 0;
const byte s3 = 0;
const byte led1 = A1; //led1
const byte led2 = A2; //led1
const byte led3 = A3; //led3
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
digitalWrite(led1, LOW);
if (b1 == LOW)
s1 = 1;
s1 = 0;
if (b2 == LOW)
s3 = 1;
s3 = 0;
if (b3 == LOW)
s2 = 1;
s2 = 0;
delay(100); // dirty delay to overcome the problem of not parallel pressing the buttons
if (s1 == 0 && s2 == 1 && s3 == 0) {
if (s1 == 1 && s2 == 1 && s3 == 0) {
if (s1 == 1 && s2 == 1 && s3 == 1) {
this will check that the buttons are pressed (nearly) at the same time.
If you need a sequence/order ... you will need something different.
And a lot of more definitions, what should happen in edge cases ... like pressing a wrong order, timeouts etc ...
