I have a minimum circuit with a BNO080 imu connected to a Atmega 32u4, I have had to remove the bootloader due to memory constraints. Due to failsafes I want to enable the watchdog to reset the board if needed, However when I do this the watchdog disables the chip but it does not come back up.
If i re-enable the bootloader it works fine, I thought i must be an issue with the fuses but using the fuse calc it states they should be fine?
L: FF
H: DF
E: FB
I can reproduce this with the following code:
#include <Wire.h>
#include<avr/wdt.h> /* Header for watchdog timers in AVR */
#include "SparkFun_BNO080_Arduino_Library.h" // Click here to get the library: http://librarymanager/All#SparkFun_BNO080
BNO080 myIMU;
Serial.println("BNO080 Read Example");
Wire.begin();
myIMU.begin(0X4A);
Wire.setClock(400000); //Increase I2C data rate to 400kHz
myIMU.enableDebugging(Serial);
myIMU.enableMagnetometer(100);
myIMU.enableAccelerometer(25);
wdt_enable(WDTO_8S); /* Enable the watchdog with a timeout of 2 seconds */
//Look for reports from the IMU
if (myIMU.receivePacket() == true)
myIMU.printPacket();
If I remove the IMU commands it runs as it should. could this be the IMU holding the I2C bus or something?
That is very, very strange. What is taking up all that memory?
I've used the BNO055 with memory left over, on a 16K ATmega168 board. The only library needed is Wire (and not even that, if you use simple calls to the I2C hardware).
If all you want is orientation sensor data, there are many other choices, most of which perform much better than the old Bosch products, and require very little Arduino memory.
This is a very large project, taking in IMU readings/NFC/bty management, gps, gpio plus a oled screen and handing the readings over usb hid to a android device. unfortunately we have had custom boards made so are stuck with what we have, but mission creep has expanded what we originally wanted from the board,( What the Boss wants compared to what the Boss needs!).
The code above is the minimum that will cause the issue, and unfortunately The BNO00 cant be removed from the project
As for the watchdog problem, just enabling it is not enough. You have to make sure that the reset vector points to your code, and not the bootloader section.
I don't recall the details, though. The ATmega32U4 datasheet has the information you need.
There is no reason that RESET can't start your program properly. You are probably running afoul of Arduino IDE expectations for a bootloader, or incorrect fuse settings.
My approach would be to examine flash memory to see where the reset location is pointing, and look for the loaded program start address. It is possible to get a complete memory map of the program load module.
This was never a problem when using Atmel Studio to develop code, and it has been a long time since I've had to do something like that with Arduino, so I can't provide the details off the top of my head.
I don't understand what you mean by this comment:
Do you mean that the RESET starts the program correctly in that case? If so, something else is very wrong. If not, please describe in detail what actually happens.
