3dprintersarehard
mymarlinsoftware is having this error
Arduino: 1.6.6 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Marlin.h:22:0,
from sketch\BlinkM.cpp:5:
sketch\Configuration.h:238:0: warning: "Y2_STEP_PIN" redefined [enabled by default]
#define Y2_STEP_PIN ORIG_E1_STEP_PIN
In file included from sketch\Configuration.h:42:0,
from sketch\Marlin.h:22,
sketch\pins.h:614:0: note: this is the location of the previous definition
#define Y2_STEP_PIN 36
sketch\Configuration.h:239:0: warning: "Y2_DIR_PIN" redefined [enabled by default]
#define Y2_DIR_PIN ORIG_E1_DIR_PIN
sketch\pins.h:615:0: note: this is the location of the previous definition
#define Y2_DIR_PIN 34
sketch\Configuration.h:240:0: warning: "Y2_ENABLE_PIN" redefined [enabled by default]
#define Y2_ENABLE_PIN E1_ENABLE_PIN
sketch\pins.h:616:0: note: this is the location of the previous definition
#define Y2_ENABLE_PIN 30
sketch\Configuration.h:242:0: warning: "Z2_STEP_PIN" redefined [enabled by default]
#define Z2_STEP_PIN ORIG_E1_STEP_PIN
sketch\pins.h:618:0: note: this is the location of the previous definition
#define Z2_STEP_PIN 36
sketch\Configuration.h:243:0: warning: "Z2_DIR_PIN" redefined [enabled by default]
#define Z2_DIR_PIN ORIG_E1_DIR_PIN
sketch\pins.h:619:0: note: this is the location of the previous definition
#define Z2_DIR_PIN 34
sketch\Configuration.h:244:0: warning: "Z2_ENABLE_PIN" redefined [enabled by default]
#define Z2_ENABLE_PIN E1_ENABLE_PIN
sketch\pins.h:620:0: note: this is the location of the previous definition
#define Z2_ENABLE_PIN 30
In file included from sketch\BlinkM.cpp:5:0:
Marlin.h:212: error: 'EXTRUDERS' was not declared in this scope
extern int extruder_multiply[EXTRUDERS]; // sets extrude multiply factor (in percent) for each extruder individually
Marlin.h:213: error: 'EXTRUDERS' was not declared in this scope
extern float volumetric_multiplier[EXTRUDERS]; // reciprocal of cross-sectional area of filament (in square millimeters), stored this way to reduce computational burden in planner
Marlin.h:214: error: 'NUM_AXIS' was not declared in this scope
extern float current_position[NUM_AXIS] ;
exit status 1
enabled in File > Preferences.
Marlin.ino (1.83 KB)
you will probably have better luck over at the reprap forums since this is a specific problem about 3D printing software, not an Arduino issue
http://forums.reprap.org
personally, I think you might be missing some of the library files
ok thank you
