using two Arduinos to send data over RF
the code:
transmitter:
#include <VirtualWire.h>
const int TX_DIO_Pin = 2;
unsigned int Data2 = 0;
pinMode(13, OUTPUT);
pinMode(10, OUTPUT);
vw_set_tx_pin(TX_DIO_Pin);
vw_set_ptt_inverted(true);
vw_setup(2000);
unsigned int Data;
// unsigned int Data2;
byte TxBuffer[4];
Data = 33;
// Data2 = 55;
Data2++;
if (Data2 ==11 ) Data2=0;
TxBuffer[0] = Data >> 8;
TxBuffer[1] = Data;
TxBuffer[2] = Data2 >> 8;
TxBuffer[3] = Data2;
digitalWrite(13, HIGH);
digitalWrite(10, HIGH);
vw_send((byte *)TxBuffer, 4);
vw_wait_tx();
delay(30);
Serial.print(" device: ");
Serial.print(Data);
Serial.print(" mesg: ");
Serial.println(Data2);
digitalWrite(13, LOW);
digitalWrite(10, LOW);
receiver:
const int RX_DIO_Pin = 2;
unsigned int Data;
unsigned int Data2;
vw_set_rx_pin(RX_DIO_Pin);
vw_setup(2000);
vw_rx_start();
uint8_t Buffer_Size =4;
uint8_t RxBuffer[Buffer_Size];
delayMicroseconds(1);
if (vw_get_message(RxBuffer, &Buffer_Size))
Data = RxBuffer[0] << 8 | RxBuffer[1];
Data2 = RxBuffer[2] << 8 | RxBuffer[3];
Serial.print(Data);
update moderatore: reformatted the code to be more readable... (CTRL-T in the IDE)
