I have an Arduino Uno Rev 3 and a RFM69HCW RF shield from Robot Shop. I'm trying to decode messages from a 433MHZ FM transmitter to emulate the functionality of this receiver:
I'm using the radio head library and the example sketches. There seems to be no message coming in from the transmitter which I assume is because of encryption? I'm not too experienced with RF, what do I need to do to pair the transmitter with my Arduino?
The modulation protocols don't match. I imagine that the protocol used by the remote control is proprietary, but you might learn something about it using a Software Defined Radio (SDR), or do a web search to see if someone has decoded it.
I will try SDR to see what comes up. I don't think anyone has tried to hack this particular system, I did quite a bit of searching and didn't come across anything
You would need a good understanding of data modulation methods, protocols and packet structures, then study the manuals for both the RFM69 and the 'FM Decoder'. A good quality spectrum analyzer could be useful too.
Do not assume that because the two devices use the same frequency you will be able to ge them to talk to each other, quite often this is just not possible.
I'm not trying to hack it really. My issue is my I can't get my hands on this model (HORNET) of receiver that is compatible with the transmitter I have. The replacement series is not compatible so I'm in a bit of a tight spot.
Every transmitter of that product would have different identifying codes that a receiver would have to be trained to recognize. Similar to your automobile alarm system.
To clarify, I have a HORNET transmitter / receiver set that work together with no issues. I want to add a second receiver but the manufacturer told me they're obsolete. They recommended a new series which they said would not work with a HORNET. Looks like I need to try one of these universal receivers and hope for the best
