Hello, I wanted to capture RF signals using Arduino with this receiver & transmitter set (AliExpress )
The remote I am trying to sniff signal from is Simu Remote which should operate at frequency 433.42 MHz.
Here is my setup for referrence ^.
I tried using RCSwitch.h and RadioHead libraries. The receiver seemed to be initialized without any issue.
Is there anything I blatantly overlooked or any other equipment I should get to make it work?
That broadband receiver should work even if the frequencies are somewhat different. Since transmission protocols are mostly proprietary, you need a more general method of "sniffing" the signal.
