I managed to use the cheap 433 MHz radio receiver and transmitter with 2 Arduinos. The transmitter works fine with LowPower.h, but the receiver is little bit more complicated. I tried to use pin 2 as data pin from the receiver to wake up the receiver-Arduino, but the receiver always sends some data to pin 2, even if there is no real signal sending. So the receiver-Arduino is too often awake.
Any ideas how to manage this problem? Is it possible to only wake up the Arduino when some data arrives?
The aim is to save energy because of battery operation.
Those receivers have automatic gain. They amplify the signal, and they don't care if that is noise or real data. So everything comes out of the data pin. The VirtualWire or RadioHead library reads the noise or data, tries to identify the start pulses and tries to read the data. It even allows some noise in between the data.
That means that those receivers receive all the time, and send all the noise or data to the pin.
