Hey all
I'm having issues connecting my 433Mhz module to an esp32.
from what I can see, there are not any resources that assist me.
if you have any guidance that you could provide, it is greatly appreciated
thanks!
Hey all
thanks!
Google
esp32+433+mhz+transmitter
First hit doesn't help?
have a look at rf-433mhz-transmitter-receiver-module-with-arduino
the example code uses the SparkFun_RadioHead_Arduino_Library
if connecting to an ESP32 you will need to explicitly set the pins used, e.g.
/// Constructor.
/// At present only one instance of RH_ASK per sketch is supported.
/// \param[in] speed The desired bit rate in bits per second
/// \param[in] rxPin The pin that is used to get data from the receiver
/// \param[in] txPin The pin that is used to send data to the transmitter
/// \param[in] pttPin The pin that is connected to the transmitter controller. It will be set HIGH to enable the transmitter (unless pttInverted is true).
/// \param[in] pttInverted true if you desire the pttin to be inverted so that LOW wil enable the transmitter.
RH_ASK(uint16_t speed = 2000, uint8_t rxPin = 11, uint8_t txPin = 12, uint8_t pttPin = 10, bool pttInverted = false);
using verson Radiohead library version 1..21 (Edited!)
connected a 433MHz transmitter to ESP8266 pin GPIO4 with constructor
//RH_ASK(uint16_t speed = 2000, uint8_t rxPin = 11, uint8_t txPin = 12, uint8_t pttPin = 10, bool pttInverted = false);
RH_ASK rf_driver(2000, 2, 4); // ESP8266 Create Amplitude Shift Keying Object
works OK transmitting data to receiver
connected 433MHz transmitter to ESP32 and it resets and goes into a loop when
if (!rf_driver.init()) {
is called
looking at RF_ASK.H it lists supported microcontrollers - ESP8266 is listed but not the ESP32
Edit: looking at RF_ASK.CPP it does support ESP32
ESP32 433MHz receiver code using pin GPIO21 (Tools>Board set to NodeMCU-32S)
// ESP32 433MHz receiver test 1
#include <RH_ASK.h> // Include RadioHead Amplitude Shift Keying Library
#include <SPI.h> // Include dependant SPI Library
RH_ASK rf_driver(2000, 21, 22); // ESP32 Create Amplitude Shift Keying Object
delay(4000);
Serial.println("ESP32 433MHz receiver");
if (RH_PLATFORM == RH_PLATFORM_ESP32)
Serial.println("RH_PLATFORM_ESP32");
delay(5000);
Serial.println("Receiver: rf_driver initialising");
Serial.println("init failed");
while (1) delay(1000);
Serial.println("Receiver: rf_driver initialised");
uint8_t buf[20]={0}; // Set buffer to size of expected message
uint8_t buflen = sizeof(buf);
// Check if received packet is correct size
if (rf_driver.recv(buf, &buflen)) {
// Message received with valid checksum
Serial.print("Message Received: ");
Serial.println((char*)buf);
not tested transmitter on GPIO22
ESP8266 transmitter
// ESP8266 433MHz transmitter test 1
delay(4000);
Serial.println("ESP8266 433MHz transmitter");
while (1) delay(10000);
Serial.println("Transmitter: rf_driver initialised");
// transmit packet every 5 seconds
Serial.println("Transmitting packet");
const char *msg = "Hello World";
rf_driver.send((uint8_t *)msg, strlen(msg)+1);
rf_driver.waitPacketSent();
delay(5000);
ESP8266 serial monitor
Transmitting packet
Transmitting packet
Transmitting packet
Transmitting packet
ESP32 receiver serial monitor
RH_PLATFORM_ESP32
Message Received: Hello World
Thank you so much for this, I was wondering if I would have needed to change my board.
Thanks again!
Where can I download RadioHead version 1.22
follow the Radiohead library link in post 4 and download RadioHead-1.121.zip
if you unzip it you will find the version of RH_ASK.h is commented as
RH_ASK.h,v 1.22 2020/05/06 22:26:45
which is the one I used in post 4
