-5 Volts Analog In
Hello Everyone,
I have a PCB-Ciruit with a Amplifier which has a -5 to 5 Voltage Rail.
Its output is directly connected to an Arduino Mega2560 AnalogIn-Pin...
Two Questions now:
-What is the Input Impedance on those Pins?
and
-What will happen if the Voltage wil go below 0 Volts? Can it damage the interior?
Best
Jakob
Edit: After carefully reading the AtMEGA2560 Datasheet, i found out that the Pins are not to be loaded with less thatn -0.5Volts and the Input Impedance is 100k. So that would answer my question. Case closed.
