Hi, I’m building an automated beer tap. I’m using a 4 load cell, an hx711 amplifier and two servos. Basically, when I put my glass the sensor reads the weight and the first servo tilts the glass 35 degrees and the second servo reads the 35 degree angle and opens the tap. The sensor keeps reading while the glass is getting full, tilting the glass at 25, 15 and 5 degrees, depending on the weight. Once the weight gets between 719 grams and 1 kilo, the tilting servo turns to 5 degrees and the second servo detects this angle and closes the tap.
My problem is that sometimes when I take out the glass, it looks that detects some kind of change in the weight and the servos moves, tilting the device and opening for a second and spilling the beer.
I have the feeling that a longer delay could help with the problem. But I don’t know where I should put it. Or maybe there’s a way to ignore the weight readings when i'm taking the glass. I appreciate if someone can point me in the right direction.
This is my code.
Example using the SparkFun HX711 breakout board with a scale
By: Nathan Seidle
SparkFun Electronics
Date: November 19th, 2014
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This example demonstrates basic scale output. See the calibration sketch to get the calibration_factor for your
specific load cell setup.
This example code uses bogde's excellent library:"https://github.com/bogde/HX711"
bogde's library is released under a GNU GENERAL PUBLIC LICENSE
The HX711 does one thing well: read load cells. The breakout board is compatible with any wheat-stone bridge
based load cell which should allow a user to measure everything from a few grams to tens of tons.
Arduino pin 2 -> HX711 CLK
3 -> DAT
5V -> VCC
GND -> GND
The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine.
//Scale Prep
#include "HX711.h"
#define calibration_factor -26040 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define LOADCELL_DOUT_PIN 2
#define LOADCELL_SCK_PIN 3
HX711 scale;
//Servo Tilt Prep
#include <Servo.h>
Servo ServoTilt;
Servo ServoTap;
int ServoTiltPos;
//Oled Prep
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define ANCHO 128
#define ALTO 64
#define OLED_RESET 4
Adafruit_SSD1306 oled(ANCHO, ALTO, &Wire, OLED_RESET);
//Setup Scale
Serial.println("HX711 scale demo");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
//Setup Servo Tilt
ServoTilt.attach(9);
ServoTilt.write(0); //Tilt Servo in initial position
//Setup Servo Tap
ServoTap.attach(5);
ServoTap.write(120);// Tap Servo in close position
//Setup Oled
Wire.begin ();
oled.begin (SSD1306_SWITCHCAPVCC, 0x3C);
Serial.print("Reading: ");
Serial.print(scale.get_units(), 3); //scale.get_units() returns a float
Serial.print(" Kg"); //You can change this to kg but you'll need to refactor the calibration_factor
oled.clearDisplay();
oled.setTextColor(WHITE);
oled.setTextSize(2);
oled.setCursor(10, 16);
oled.print("Reading: ");
oled.print(scale.get_units(), 3);
oled.print(" Kg");
oled.display();
//Condition Open tap
ServoTiltPos=ServoTilt.read();
if (ServoTiltPos <= 35 && ServoTiltPos > 5 ) {
delay (300);
ServoTap.write(0); // Tap Servo opens position
else {
delay (50);
ServoTap.write(120);//Tap Servo Close position
//Condition Glass Stay at 0
if (scale.get_units() >= -0.1 && scale.get_units() < 0.375) {
ServoTilt.write(0);
//Condition Glass go to 35
if (scale.get_units() >= 0.375 && scale.get_units() < 0.585) {
ServoTilt.write(35);
//Condition Glass go to 25
if (scale.get_units() >= 0.585 && scale.get_units() < 0.619) {
ServoTilt.write(25);
//Condition Glass go to 15
if (scale.get_units() >= 0.619 && scale.get_units() < 0.719) {
ServoTilt.write(15);
//Condition Glass go to 5
if (scale.get_units() >= 0.719 && scale.get_units() < 1.00) {
ServoTilt.write(5);
delay(50);
This is a link of the prototype.
And this is the link of the prototype malfunctioning.
