Thank you for the sample code. I read it over and didn't understand what work() did or why the LED on pin 13 is being lit.
May I verify that you wanted me to call these functions:
maxSingle(max7219_reg_displayTest, 0x00);
maxSingle(max7219_reg_scanLimit, 0x07);
maxSingle(max7219_reg_decodeMode, 0x00);
maxSingle(max7219_reg_shutdown, 0x01);
maxSingle(max7219_reg_intensity, 0x08 & 0x0f);
to "set up" the chip before displaying something?
Paul__B:
The code you posted there is nonsense.
You have to set up all the correct registers in the MAX7219 in order to display something.
/* Loop scanner demonstration
Code for MAX7219 from maxim, reduced & optimised for using multiple 7219 cascaded.
General notes:
if using only one max7219, then use maxSingle function to control
the module --- maxSingle(register (1-8), column (0-255))
if using more then one max7219, and all should work the same, use maxAll
function --- maxAll(register (1-8), collum (0-255))
if using more than one max7219 and want to change something on one module only,
then use maxOne function
--- maxOne(module you want to control [1=first], register [1-8], column [0-255])
During initiation, be sure to send every part to every max7219 and then upload it.
For example, if you have five max7219's, you have to send the scanLimit 5 times
before you load it, otherwise not every max7219 will get the data. the (fixed)
variable maxInUse keeps track of this, just tell it how many max7219 you are using.
int dataIn = 12; // "DIN" on module
int load = 6; // "CS" on module
int clock = 13; // "CLK" on module
const int ledPin = 13; // LED pin number
int maxInUse = 1; // set how many MAX7219's used
int ledState = LOW; // initialise the LED
int e = 0; // just a varialble
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask) { // choose bit
digitalWrite(dataIn, HIGH);// send 1
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
// maxSingle is the "easy" function to use for a single max7219
void maxSingle( byte reg, byte col) {
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(col); //((data & 0x01) * 256) + data >> 1); // put data
digitalWrite(load,HIGH);
// initialize all MAX7219's
void maxAll( byte reg, byte col) {
int c = 0;
for ( c =1; c<= maxInUse; c++) {
// for adressing different MAX7219's while cascaded
void maxOne(byte maxNr, byte reg, byte col) {
int c = 0;
for ( c = maxInUse; c > maxNr; c--) {
putByte(0); // no operation
for ( c = maxNr-1; c >= 1; c--) {
void putCol( byte colno, byte coldat) {
// Interprets colno as (zero ref) index in combined array
byte t;
t = colno >> 3;
byte u;
u = colno & 0x07;
maxOne(t+1, u+1, coldat);
void dispon() {
maxAll(max7219_reg_shutdown, 0x01); // Display on
void dispoff() {
maxAll(max7219_reg_shutdown, 0x00); // Display off
byte irow = 0; // Row index
byte icol = 0; // Column index
byte pattern; // bit mask
byte lcol; // left border
byte rcol; // right border
byte trow; // top row marker
byte brow; // bottom row marker
int s_vert; // Vertical switch
int s_horz; // Horizontal switch
void worker () {
if (pattern == 0) pattern = trow; // pattern must be set
if (s_vert != 0) {
if (s_vert == -1) { // moving upward
pattern = pattern >> 1;
if (pattern == trow) { // hit the top
s_vert = 0; s_horz = 1;
pattern = pattern << 1; // moving downward
if (pattern == brow) { // hit the bottom
s_vert = 0; s_horz = -1;
putCol(icol,pattern); // Show the column.
return;
if (s_horz != 0) {
putCol(icol,0); // blank previous column.
if (s_horz == -1) { // moving left
icol--;
if (icol == lcol) { // hit the side
s_horz = 0; s_vert = -1;
icol++; // moving right
if (icol == rcol) { // hit the side
s_horz = 0; s_vert = 1;
// the follow variable is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 60; // interval at which to step (milliseconds)
long previousMillis = 0; // will store last time LED was updated
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
pinMode(ledPin, OUTPUT);
//Serial begin(9600);
digitalWrite(13, HIGH);
//initiation of the max 7219
maxAll(max7219_reg_displayTest, 0x00); // no display test
maxAll(max7219_reg_scanLimit, 0x07); // all columns in use
maxAll(max7219_reg_decodeMode, 0x00); // using a LED matrix (not digits)
maxAll(max7219_reg_shutdown, 0x01); // not in shutdown mode
for (e=1; e<=8; e++) { // empty registers, turn all LEDs off
maxAll(e,0);
maxAll(max7219_reg_intensity, 0x08 & 0x0f); // middle argument is intensity value
// range: 0x00 to 0x0f
pattern = 0;
s_vert = 0;
s_horz = 1;
// define edges of loop
lcol = 1; // left border
rcol = 6; // right border
trow = 0x02; // top row marker
brow = 0x40; // bottom row marker
void loop () {
// Active waiting for next event
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) { ledState = HIGH; } else { ledState = LOW; }
// Timed process:
worker();
// set the LED according to ledState:
digitalWrite(ledPin, ledState);
