6 AccelSteppers as an array of struct/array of class/array of object
This simulation uses an array of AccelStepper classes to drive six steppers on a simulated RAMPS/RUMBA/Mega shield.
While the steppers bounce back and forth between extremes, the inputs are monitored for pushbutton/limitSwitch activation (which sets the chosen stepper target to the value of the Position slide potentiometer) and also monitors for changes in the Speed and Acceleration slide, which affects all of the steppers immediately.
https://wokwi.com/projects/411859783629453313
/*  AccelStepper6AxisRampsMega.ino
This simulation demonstrates bouncing 6 stepper motors between different
limits while simultaneously reading potentiomters to adust speed
acceleration, and target positions during moves.
It also demonstrates use of an array of classes in order to manage them
together as a set.
  // built from :
  // https://wokwi.com/projects/390741120778917889
// For RAMPS 1.4, Copied from https://wokwi.com/projects/390741120778917889
#define X_DIR_PIN          55
#define X_STEP_PIN         54
#define X_ENABLE_PIN       38
#define Y_DIR_PIN          61
#define Y_STEP_PIN         60
#define Y_ENABLE_PIN       56
#define Z_DIR_PIN          48
#define Z_STEP_PIN         46
#define Z_ENABLE_PIN       62
#define A_DIR_PIN          28
#define A_STEP_PIN         26
#define A_ENABLE_PIN       24
#define B_DIR_PIN          34
#define B_STEP_PIN         36
#define B_ENABLE_PIN       30
#define C_DIR_PIN          32
#define C_STEP_PIN         47
#define C_ENABLE_PIN       45
#import <AccelStepper.h> // https://www.airspayce.com/mikem/arduino/AccelStepper/
// and https://github.com/waspinator/AccelStepper
// An array of classes,
AccelStepper steppers[] = {
  {AccelStepper::DRIVER, X_STEP_PIN, X_DIR_PIN},
  {AccelStepper::DRIVER, Y_STEP_PIN, Y_DIR_PIN},
  {AccelStepper::DRIVER, Z_STEP_PIN, Z_DIR_PIN},
  {AccelStepper::DRIVER, A_STEP_PIN, A_DIR_PIN},
  {AccelStepper::DRIVER, B_STEP_PIN, B_DIR_PIN},
  {AccelStepper::DRIVER, C_STEP_PIN, C_DIR_PIN},
// parallel array for enable pins
const int StepperEnablePins[] = {X_ENABLE_PIN, Y_ENABLE_PIN, Z_ENABLE_PIN, A_ENABLE_PIN, B_ENABLE_PIN, C_ENABLE_PIN };
// parallel array for limit buttons
const int ButtonPins[] = {3, 14, 18, 27, 29, 25};
const int NUM_STEPPERS = sizeof(steppers) / sizeof(steppers[0]);
void usage() {
  Serial.print(__FILE__ " on " __DATE__);
  Serial.print(F(R"(AccelStepper6AxisRAMPSMega.ino )"));
const int PositionPin = A13, SpeedPin = A14, AccelPin = A15;
uint16_t position, speed, acceleration, lastPosition, lastSpeed, lastAccel; // pot-read
void readAllInputs() {
  uint32_t now = millis();
  const auto interval = 200;
  static auto last = - interval;
  if (now - last >= interval) {
    now += interval;
    speed = map(analogRead(SpeedPin), 0, 1023, 0, 2000);
    acceleration = map(analogRead(AccelPin), 0, 1023, 0, 2000);
    position = map(analogRead(PositionPin), 0, 1023, 0, 2000);
    int ii = 0;
    for (auto pin : ButtonPins) {
      if (digitalRead(pin) == LOW) {
        steppers[ii].moveTo(position);
      ++ii;
void process() {
  if (acceleration != lastAccel || speed != lastSpeed) {
    for ( auto & stepper : steppers) {
      stepper.setAcceleration(acceleration);
      stepper.setMaxSpeed(speed);
      lastSpeed = speed;
      lastAccel = acceleration;
void enableAllSteppers() {
  int ii = 0;
  for (auto &stepper : steppers) {
    stepper.setEnablePin(StepperEnablePins[ii]);
    stepper.setPinsInverted(false, false, true);
    stepper.enableOutputs();
    stepper.setMaxSpeed(1000);
    stepper.setAcceleration(100);
    stepper.moveTo(random(2000));
    pinMode(ButtonPins[ii], INPUT_PULLUP);
    ++ii;
void runAllSteppers() {
  int ii = 0 ;
    if (stepper.distanceToGo() == 0) {
      stepper.moveTo(-stepper.currentPosition());
      Serial.print(ii);
      Serial.print("@");
      Serial.print(stepper.currentPosition());
      Serial.print(" ");
    ++ii;
    stepper.run();
// Arduino required #####################################
  srandom( 20241015 + analogRead(SpeedPin) + analogRead(AccelPin));
  enableAllSteppers();
  usage();
  readAllInputs();
  process();
  runAllSteppers();
This applies some of the techniques in:
And from:
However, this example creates an array for AccelStepper objects and assigns it with brace-delimited array of constructor parameters.
Array of struct containing classes
This example defines an array of struct, with one of the struct members being an accelStepper class. This is it's data definition:
// Assemble an array of structures
struct MyStruct {
  const char *name;
  const AccelStepper stepper;
  int enablePin;
  int button;
} stepperAssemblies[] = {
  {"X", {AccelStepper::DRIVER, X_STEP_PIN, X_DIR_PIN}, X_ENABLE_PIN,3},
  {"Y", {AccelStepper::DRIVER, Y_STEP_PIN, Y_DIR_PIN}, Y_ENABLE_PIN,14},
  {"Z", {AccelStepper::DRIVER, Z_STEP_PIN, Z_DIR_PIN}, Z_ENABLE_PIN,18},
  {"A", {AccelStepper::DRIVER, A_STEP_PIN, A_DIR_PIN}, A_ENABLE_PIN,27},
  {"B", {AccelStepper::DRIVER, B_STEP_PIN, B_DIR_PIN}, B_ENABLE_PIN,29},
  {"C", {AccelStepper::DRIVER, C_STEP_PIN, C_DIR_PIN}, C_ENABLE_PIN,25},
(It is in the Wokwi simulation example above as the V4_array_structs.ino.txt tab. See the notes on renaming tabs)
It also demonstrates use of an array of structs containing classes in order to manage them
together as a set.
  // built from :
struct MyStruct {
  const char *name;
  int enablePin;
  int button;
const int NUM_STEPPERS = sizeof(stepperAssemblies) / sizeof(stepperAssemblies[0]);
void usage() {
    now += interval;
    // // Parallel array form
    // int ii = 0;
    // for (auto pin : ButtonPins) {
    //   if (digitalRead(pin) == LOW) {
    //     steppers[ii].moveTo(position);
    //   ++ii;
    // array of struct form:
    for (auto &obj : stepperAssemblies) {
      if (digitalRead(obj.button) == LOW) {
        obj.stepper.moveTo(position);
void process() {
    for ( auto & assy : stepperAssemblies) {
      assy.stepper.setAcceleration(acceleration);
      assy.stepper.setMaxSpeed(speed);
      lastSpeed = speed;
    Serial.print("Speed:");
    Serial.print(speed);
    Serial.print(" Acceleration:");
    Serial.println(acceleration);
void enableAllSteppersParallel() {
  int ii = 0;
  for (auto &assy : stepperAssemblies) {
    assy.stepper.setEnablePin(assy.enablePin);
    assy.stepper.setPinsInverted(false, false, true);
    assy.stepper.enableOutputs();
    assy.stepper.setMaxSpeed(1000);
    assy.stepper.setAcceleration(100);
    assy.stepper.moveTo(random(2000));
    pinMode(assy.button, INPUT_PULLUP);
    ++ii;
  int ii = 0;
    obj.stepper.setEnablePin(obj.enablePin);
    obj.stepper.setPinsInverted(false, false, true);
    obj.stepper.enableOutputs();
    obj.stepper.setMaxSpeed(1000);
    obj.stepper.setAcceleration(100);
    obj.stepper.moveTo(random(2000));
    pinMode(obj.button, INPUT_PULLUP);
    Serial.print("Initialized ");
    Serial.print(obj.name);
    Serial.print(" Stepper, enabe Button Pin:");
    Serial.println(obj.button);
    ++ii;
  int ii = 0 ;
    if (obj.stepper.distanceToGo() == 0) {
      obj.stepper.moveTo(-obj.stepper.currentPosition());
      Serial.print(ii);
      Serial.print("@");
      Serial.print(obj.stepper.currentPosition());
      Serial.print(" ");
    ++ii;
    obj.stepper.run();
  //enableAllSteppers();
  usage();
  readAllInputs();
  process();
  runAllSteppers();
Ooh, you can avoid the parallel arrays of enable pins and button pins and assemble an array of structures by using references to the steppers[..] array of classes:
struct MyStruct {
  const char *name;
  const AccelStepper &stepper;
  int enablePin;
  int button;
  {"X", steppers[0], X_ENABLE_PIN,3},
  {"Y", steppers[1], Y_ENABLE_PIN,14},
  {"Z", steppers[2], Z_ENABLE_PIN,18},
  {"A", steppers[3], A_ENABLE_PIN,27},
  {"B", steppers[4], B_ENABLE_PIN,29},
  {"C", steppers[5], C_ENABLE_PIN,25},
I'm sure you could go one step further and put the AccelStepper initializer parameters into that declaration and avoid this parallel array of classes of AccelSteppers:
The whole code will drop into the Wokwi linked above:
whole code
together as a set.
  // built from :
struct MyStruct {
  const char *name;
  int enablePin;
  int button;
void usage() {
    now += interval;
    // int ii = 0;
    //   ++ii;
void process() {
      lastSpeed = speed;
  int ii = 0;
    ++ii;
  int ii = 0;
    ++ii;
  int ii = 0 ;
      Serial.print(ii);
      Serial.print("@");
      Serial.print(" ");
    ++ii;
    stepper.run();
  usage();
  readAllInputs();
  process();
  runAllSteppers();
As an array of struct containing an AccelStepper class as a member.
This example is built around a declaration of an array of structs, where one of the elements is an AccelStepper:
struct MyStruct {
  const char *name;
  int enablePin;
  int button;
(...where the pins are set per some RAMPS 3d-printing control board pin assignments)
The Simulation:
The full code:
/*  AccelStepper6AxisArrayStruct.ino
See https://forum.arduino.cc/t/6-accelsteppers-as-an-array-of-struct-array-of-class-array-of-object/1311789/ and
https://wokwi.com/projects/411859783629453313 for some some parent sketches
together as a set.
  // built from :
// RAMPS pins from https://reprap.org/wiki/RAMPS_1.4#Pins & https://forum.arduino.cc/t/arduino-mega-use-analog-pins-as-digital/13844/6?u=davex
// with auxiliary pins for axis C controls and A,B,C min pins
#define X_MIN_PIN           3
#define Y_MIN_PIN          14
#define Z_MIN_PIN          18
#define A_MIN_PIN 27
#define B_MIN_PIN 29
#define C_MIN_PIN 25
struct MyStruct {
  const char *name;
  int enablePin;
  int button;
  {"X", {AccelStepper::DRIVER, X_STEP_PIN, X_DIR_PIN}, X_ENABLE_PIN,X_MIN_PIN},
  {"Y", {AccelStepper::DRIVER, Y_STEP_PIN, Y_DIR_PIN}, Y_ENABLE_PIN,Y_MIN_PIN},
  {"Z", {AccelStepper::DRIVER, Z_STEP_PIN, Z_DIR_PIN}, Z_ENABLE_PIN,Z_MIN_PIN},
  {"A", {AccelStepper::DRIVER, A_STEP_PIN, A_DIR_PIN}, A_ENABLE_PIN,A_MIN_PIN},
  {"B", {AccelStepper::DRIVER, B_STEP_PIN, B_DIR_PIN}, B_ENABLE_PIN,B_MIN_PIN},
  {"C", {AccelStepper::DRIVER, C_STEP_PIN, C_DIR_PIN}, C_ENABLE_PIN,C_MIN_PIN},
void usage() {
Serial.println(F(R"(AccelStepper6AxisRAMPSMega.ino V4_array_structs.ino
Speed, acceleration change with potentiometers.
Bounce position changes with button press. )"));
    now += interval;
      if (digitalRead(obj.button) == LOW && obj.stepper.targetPosition() != position) {
        Serial.print("Retargeting stepper ");
        Serial.print(" to ");
        Serial.println(position);
void process() {
      lastSpeed = speed;
    Serial.print(" Stepper, enable Button Pin:");
      Serial.print("@");
      Serial.print(" ");
    obj.stepper.run();
  usage();
  readAllInputs();
  process();
  runAllSteppers();
I think that "array of AccelStepper objects" sounds better than "array of classes"
How about this:
Array of struct/array of class for 6 AccelSteppers
or
Array of struct/array of class/array of object for 6 AccelSteppers
or
I have found it hard to search/google for more than basic examples of array of ??? declarations. I've seen them in use as finished products, but their creation looks like deep magic and easy to do wrong.
This may be true, but it is pretty basic:
Here's an array of stepper objects tracking the array of FastLED pixels:
And here's an array of buttons managed by an array of ezButtons:
It is a shame that the Arduino built-in examples are mostly 1-device examples and do not show a path forward into multiples of the devices in an array or an array of structs.
Arrays (and arrays of structs) scale well, and there should be more examples of using arrays of things.
Arduino has this:
https://docs.arduino.cc/language-reference/en/variables/data-types/array/
and the How to use Arrays tutorial:
