This is dronebot's code, did you try it before adding the DHT, to test your display?
74HC595 Shift Register with 7-segment LED display
74hc595-7segdisplay.ino
Count in hex from 0-F and display on 7-segment Common Cathode LED display
DroneBot Workshop 2020
https://dronebotworkshop.com
// Define Connections to 74HC595
// ST_CP pin 12
const int latchPin = 10;
// SH_CP pin 11
const int clockPin = 11;
// DS pin 14
const int dataPin = 12;
// Patterns for characters 0,1,2,3,4,5,6,7,8,9,A,b,C,d,E,F
int datArray[16] = {B11111100, B01100000, B11011010, B11110010, B01100110, B10110110, B10111110, B11100000, B11111110, B11110110, B11101110, B00111110, B10011100, B01111010, B10011110, B10001110};
void setup ()
// Setup pins as Outputs
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Count from 0 to 15
for (int num = 0; num < 16; num++)
// ST_CP LOW to keep LEDs from changing while reading serial data
digitalWrite(latchPin, LOW);
// Shift out the bits
shiftOut(dataPin, clockPin, MSBFIRST, datArray[num]);
// ST_CP HIGH change LEDs
digitalWrite(latchPin, HIGH);
Get the test code working on your project before editing code.
What displays are you using?(part number)
Common anode or common cathode?
Tom...
