Hello, i'm verry new to arduino and programming it.
I wanted to make a 3 digit display that counts up 1 when i press on a button and subtracts 1 when i press on another button.
I made the circuit hooked up the 3 digit 7 segment display and made the outputs of each digit go into the collector of a npn transistor, i connected the base to the arduino and the emitor to ground. whenever i want to display something on the 7 segment display it does not display anything this is my code:
int LedB = 2;
int LedLB = 3;
int LedRB = 4;
int LedM = 5;
int LedLO = 6;
int LedRO = 7;
int LedO = 8;
int button = 9;
int counter = 0;
int button2 = 10;
int DigitL = 11;
int DigitM = 12;
int DigitR = 13;
pinMode(LedB, OUTPUT);
pinMode(LedLB, OUTPUT);
pinMode(LedRB, OUTPUT);
pinMode(LedM, OUTPUT);
pinMode(LedLO, OUTPUT);
pinMode(LedRO, OUTPUT);
pinMode(LedO, OUTPUT);
pinMode(button, INPUT);
pinMode(button2, INPUT);
pinMode(DigitL, OUTPUT);
pinMode(DigitM, OUTPUT);
pinMode(DigitR, OUTPUT);
if(digitalRead(button) == HIGH)
counter = counter + 1;
delay(200);
if(digitalRead(button2) == HIGH)
counter = counter - 1;
delay(200);
if(counter == 1)
digitalWrite(LedB, LOW); //Write all other outputs LOW
digitalWrite(LedLB, LOW);
digitalWrite(LedM, LOW);
digitalWrite(LedLO, LOW);
digitalWrite(LedO, LOW);
digitalWrite(LedRB, HIGH); //Write outputs HIGH for 7 segment
digitalWrite(LedRO, HIGH);
digitalWrite(DigitR, HIGH); //Digit selection
digitalWrite(DigitM, LOW);
digitalWrite(DigitL, LOW);
if(counter == 2)
digitalWrite(LedB, HIGH);
digitalWrite(LedM, HIGH);
digitalWrite(LedLO, HIGH);
digitalWrite(LedO, HIGH);
digitalWrite(LedRO, LOW);
if(counter == 3)
if(counter == 4)
digitalWrite(LedLB, HIGH);
if(counter == 5)
digitalWrite(LedRB, LOW);
if(counter == 6)
if(counter == 7)
if(counter == 8)
if(counter == 9)
if(counter == 0)
if(counter == -1)
counter = 9;
if(counter >= 10)
counter = 0;
the led outputs go to the 7 segment display and the digit outputs go to the base of each transistor to control what digit is on and wich one isn't.
what am i doing wrong ?
thank you
