Hi everyone. I am trying to read data from a SN74HC165N shift register connected to an arduino.
I am using pull down resistors and correctly connected the 74HC165 as:
- Vcc to +5v
- Clock_INH to GND
- Q7 to Arduino pin 4
- GND to GND
- SH/LD to Arduino pin 2
- Clock to Arduino pin 3
I am having issues with the ShiftIn() function called as in my sketch:
const int PL = 2; // Parallel Load
const int CLK = 3; // Clock
const int DATA = 4; // Data Output
pinMode(PL, OUTPUT);
pinMode(CLK, OUTPUT);
pinMode(DATA, INPUT);
digitalWrite(PL, LOW);
delayMicroseconds(5);
digitalWrite(PL, HIGH);
byte buttons = shiftIn(DATA, CLK, MSBFIRST);
Serial.print("State: ");
for (int i = 0; i < 8; i++) {
Serial.print((buttons >> i) & 1);
Serial.print(" ");
delay(100);
with the output being
State: 0 0 0 0 0 0 0 1
when pressing the button connected to pin D6 on the shift register.
If I use this script, which calls the digitalRead() function, everything works fine:
const int dataPin = 4; /* Q7 */
const int clockPin = 3; /* CP */
const int latchPin = 2; /* PL */
const int numBits = 8; /* Set to 8 * number of shift registers */
pinMode(dataPin, INPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
// Step 1: Sample
digitalWrite(latchPin, LOW);
digitalWrite(latchPin, HIGH);
// Step 2: Shift
Serial.print("Bits: ");
for (int i = 0; i < numBits; i++) {
int bit = digitalRead(dataPin);
if (bit == HIGH) {
Serial.print("1");
Serial.print("0");
digitalWrite(clockPin, HIGH); // Shift out the next bit
digitalWrite(clockPin, LOW);
Can you please tell me why I am not able to read the D7 pin using the shiftIn function? It looks like it is shifted by one bit!
thanks a lot!
