74HC595 Shift Register adjustments for ESP32
Hi. I need a few more digital output pins than the Nano ESP32 has available, and my reading led me to the 74HC595 shift register. So far it works with a Mega but not with the Nano ESP32, so perhaps you can help me figure out why.
I am testing with code taken from one of several nearly identical tutorials online, but I'll post it at the end. The specific tutorial I found is here: https://lastminuteengineers.com/74hc595-shift-register-arduino-tutorial/ but I have cross-checked the pin assignments with other tutorial versions at Adafruit and elsewhere.
Application: I eventually need to control an 8-outlet AC power bar which is apparently built with Omron G2R-1 relays. My full application may have two such power bars and other pins are busy with a clock, SD card, temperature sensors, some small solid-state relays, and a display. Speed of output is not an issue, as one state change per second is fast enough. Current for the relays could be an issue, but at the moment I just want to get the tutorial to work. The eventual goal is an updated version of the system described here: The Coral Bleaching Automated Stress System (CBASS): A low‐cost, portable system for standardized empirical assessments of coral thermal limits
I wired up the tutorial on a breadboard, using some old LEDs and resistors as outputs. The first time I ran the code I just got 7 bright LEDs instead of the progressive lighting that was expected (all off, 1 on, 1 and 2 on, etc.).
After checking the wiring with no change in behavior, here are some of the things I tried.
  1. Ran exactly the same code on an Arduino Mega, wiring it to the same breadboard. This worked as expected, so there is nothing grossly wrong with the code or wiring, at least when using a Mega.
Back on the Nano ESP32 none of this helped:
  1. Verified that the pin numbers in the sketch were controlling the pins I wired to.
  2. Added some blinks of the onboard LED and serial monitor prints of the "leds" variable, just to see that the code was running.
  3. Put a 100 nanofarad capacitor between the clockPin and ground. Also one across the power input at pin 16.
  4. Put capacitors on the output pins. It didn't help and in retrospect I don't think it was a good idea.
  5. Added a 2 millisecond delay before shiftOut() to allow for the rise time of the latchPin and 2 milliseconds after for no good reason.
  6. Tried reducing the processor clock speed with setCpuFrequencyMhz(), since that's one big difference between the two Arduinos. At 40 and 20 MHz the output changed to have one LED on, but it still wouldn't switch. After setting 10 MHz I could not load another sketch until I reset the bootloader and uninstalled and reinstalled the Arduino IDE and drivers!
  7. Connected 5V to the chip Vcc pin, since that's what the Mega has. Pin 10, SRCLR bar, was also connected to 5V. This was probably doomed to fail, since interpolating between datasheet points for Vcc and the high input voltage suggests that a 5V Vcc would require nearly 3.5 V to switch the inputs. Of course I'm only working with 3.3V or so.
  8. Unplugged most of the LEDs in case there was a total current issue.
Some general observations on the state of the LEDs. Usually they start all off or all on, but occasionally in some other pattern. That state sometimes changes once in the first second of a run, but never again. Briefly unplugging the USB cable tends to restore the previous state, but leaving it out for 10 seconds or so seems more likely to show a new starting state. Hitting the reset button does not change the state.
I'm much more of a programmer than an electronics person, but I have one of those little pocket oscilloscopes (DSO Nano V3). The latch pin sits at 3.3V and drops to ground for about 8 microseconds at each update. The transitions aren't square, but they are pretty steep with no noticeable overshoots. This seems reasonable.
The data and clock pin just sit at zero volts all the time! This could simply be that my skills with the oscilloscope are not good enough for the more rapid signals. I tried the full range of time scales, but I could be missing something.
Speculation:
There are two big differences between the Mega and ESP32 that are likely to matter here. First is 3.3V logic versus 5V, but note that the 74HC595 data sheet allows a 2V to 6V supply.
Second, the Mega CPU clock is 16 MHz and the ESP32 is 240 MHz. The data sheet values for the 74HC595 interpolate to about 20 MHz at 3.3 V. This is where my internet searches failed me. I don't know how fast the clock and data pins are actually being switched by the shiftOut() function. I can see that the clock is set high for a very short time for each bit with no delay or other code between two digitalWrite() calls.
        digitalWrite(clockPin, HIGH);
        digitalWrite(clockPin, LOW);
In the 8 microseconds between latch changes shiftOut() does 24 digitalWrite() calls, 16 of which are the clockPin changes in the code snippet above. In the unlikely event that all 24 calls are evenly spaced that should mean 0.33 * 10-6 seconds per call or a frequency around 3 MHz. Because I don't actually know how the calls are spaced I still don't know whether something there will violate the 20 MHz frequency limit of the chip.
Question time:
  1. Should I be doing this a whole different way?
  2. If it's a clock issue is there a way to set the rate without slowing down the whole CPU?
  3. Is there anything else I should check?
  4. Are there other Mega vs. ESP32 differences that I should be allowing for (and how)?
Thanks for anything!
int dataPin = 4;       // Data pin of 74HC595 is connected to Digital pin 4  (SER, chip pin 14)
int latchPin = 5;      // Latch pin of 74HC595 is connected to Digital pin 5  (RCLK, chip pin 12)
int clockPin = 6;      // Clock pin of 74HC595 is connected to Digital pin 6 (SRCLK, chip pin 11)
byte leds = 0;         // Variable to hold the pattern of which LEDs are currently turned on or off
  // Set all the pins of 74HC595 as OUTPUT
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  leds = 0;        // Initially turns all the LEDs off, by giving the variable 'leds' the value 0
  updateShiftRegister();
  delay(2000);
  for (int i = 0; i < 8; i++)        // Turn all the LEDs ON one by one.
    bitSet(leds, i);                // Set the bit that controls that LED in the variable 'leds'
 * updateShiftRegister() - This function sets the latchPin to low, then calls the Arduino function 'shiftOut' to shift out contents of variable 'leds' in the shift register before putting the 'latchPin' high again.
void updateShiftRegister()
   digitalWrite(latchPin, LOW);
   shiftOut(dataPin, clockPin, LSBFIRST, leds);
   digitalWrite(latchPin, HIGH);
These caps will kill the output pins and the clockPin. Who told you to add caps to digital signal lines?
Remove the caps, except the one on Vcc
Try this code instead of shiftOut
void MYshiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, uint8_t val)
  uint8_t i;
  for (i = 0; i < 8; i++)  {
    if (bitOrder == LSBFIRST) {
      digitalWrite(dataPin, val & 1);
      val >>= 1;
      digitalWrite(dataPin, (val & 128) != 0);
      val <<= 1;
    delayMicroseconds(10);
My typo on the clockPin. It was the latchPin where I added and kept the capacitor. That stays low for a while. I don't think it helped or hurt, but I will remove it.
The output pins were the result of the many dozens of forum posts I read (or maybe misread). I only had them in place briefly, as I realized that they were a bad move.
'HC' is 3V marginal.
'HCT' is better.
Thank you! It works perfectly now.
Steve
Thanks! I'll check those out.
So basically ShiftOut on the ESP is to fast
At 3.3V, I think the max clock for the HC595 is around 10MHz
Your solution solves my problems completely, but I wonder if the code in wiring_shift.c should be modified for everyone. I suppose there are applications where maximum speed is needed, so perhaps another argument or some other optional slowdown would be good.
As a bonus I can now see the clock and data transitions on my little oscilloscope, which is reassuring.
Steve
I modified the AVR version of ShiftOut. The version in the ESP library is a little bit different.
I did tests on ESP32 with an oscilloscope and it works much faster without delay, about 13us per one call function. You can comment on the delay.
  uint8_t i;
      val >>= 1;
      val <<= 1;
    // delayMicroseconds(10);
Of course it works faster without the delay but will it reliably clock the HC595 in the OPs set-up?
A regular HC595 can handle a clock of 10MHz and in our case the clock is 13us/8 = 1.625us = 0,615 MHz or 615kHz
Did you verify that it works with a similar set-up and a scope?
Yes. I have verified it in my circuit. The ShiftOut() function does not work at all. There is no clock or data on the oscilloscope, as if it is not going at all (it does not communicate with the pins). This MYshiftOut() function works reliably.
So you tested with a set-up similar to the OPs and it works OK?
Yes.
Then contact the OP. I normally use shiftOut
Now every bit the bit-order is tested, with some extra code you can squeeze another us.
  uint8_t i;
      val >>= 1;
      val <<= 1;
Another possible optimization is to use local variables (copies) for val, dataPin and clockPin.
My “customers” for the board I was making and giving away have been quiet lately, but the next time I have one on my desk I’ll try compiling without the delays and see if it works. All I can say now is that in 2023 the change took my device from 100% failing to 100% reliable.
OP
