8 Push switch and 8 relay .while push switch then relay on other wise off. Arduino nano using wireless Tx & Rx with nrf2401 please suggest me code
Your topic has been moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
Please read and use this link: How to get the best out of this forum - Community / General Discussion - Arduino Forum
More information is needed. Schematics telling how the receiving end is arranged.
There's hardly any ready code to send You, and forum is not free coding for You.
Ok, I suggest you code.
i am student try to learn. don't worry i will pay you .i know nothing free . text me massage box box
thank you dear. i will learn from your coding
That sounds like an interesting project that could be a lot of fun! However, please keep in mind that we are not a free design or code-writing service. We’re more than happy to help with your design or code, but we need you to make an initial attempt. Please design and write your code, then post it along with an explanation of what’s not working properly.
- Show Your Work First: Before asking for assistance, make an attempt to design or write the code yourself. Share your work along with details about what isn’t working.
- Provide Clear Documentation: Since we can’t see your project, share an annotated schematic (best) or a clear drawing of your setup. Pictures are welcome, but avoid using Fritzing diagrams as they are wiring diagrams, not schematics, and are not ideal for troubleshooting.
- Include Technical Details: If there is specific hardware involved, include links to technical information. There are often many versions of similar components, so precise details are essential.
- Reference Resources: For additional help, check out useful links and tutorials: Useful Links on Arduino Forum.
Before posting your code, please review the forum guidelines and use code tags for better readability. Also, provide links to the technical information about your hardware, and include a preliminary schematic that shows all power, ground, and connections. For additional guidance, you can refer to this link: Useful Links and Tutorials. Note that in this context, breadboard diagrams are not considered proper schematics.
| 1 | Solar Pannel | 1 |
| 2 | 8Channel Relay board | 1 |
| 3 | USB Convertor | 1 |
| 4 | Receiver/Transmitter NRF24 | 2 |
| 5 | Aurdino nano | 2 |
| 6 | ACRYLIC Case | 1 |
| 7 | Battery Charger | 1 |
| 8 | Battery | 1 |
| 11 | Screw terminal Board | 2 |
Hardware
- As always, show us a good schematic of your proposed circuit. Hand drawn schematics are acceptable.
- Schematic diagrams are the universal language of electronics
- We use schematics to communicate hardware design.
- Show us several good image views of your actual wiring.
- Give WEB links to your major components.
Software
- For readability, place { and } on separate lines by themselves, place each line of code on a separate line.
- In the Arduino IDE, use Ctrl T or CMD T to format your code, then copy the complete sketch.
- Use the < CODE / > icon from the ‘posting menu’ to attach your copied sketch.
There is a special section for paying for work.
yes i have four remote i want wireless .8spushwithes and 8 relay i will not operate by controller 5volt i will use 5volt 8 channel relay module . push to on .if i press all pushswitch all on . tell me pay amount
if self do it it take time . i am learner . but logic matter in my mind schematic i need code simple and thank you [LarryD] i am beginner . just start
- You are posting in the wrong section.
- The post is not even close to the specitications needed.
brother i know beginner guide me . i have good command on schematic
- Show us that schematic.
i konw knowledge not available free we should pay for it . becoz some one spend time=money. i have knowledge about schematic (connecting devices ) . new for me coding(programming) ( [LarryD] Guide me how to do it don't worry .i few month i will .
i will show you sir .
thank you sir
