OK, so I tackled the bit-wise approach. This is my first serious C project, so go easy on the critiques. I started with Andrews pinout scheme, and wrote it out the best I could (not nearly as elegant as Andrew, but it works). I'm using 5x7 letters, so each character cost you 5 bytes instead of 64. You should be able to run a 100 char message easy. I was too lazy to tackle an 8x8 font, but that would only be 8 bytes per character.
(also my first Youtube video!)
As for the wiring, I cut an IDE cable header in half and used that to connect the matrix. Again, not elegant, but it works.
Remember, I'm using a cathode-row matrix, so you'll have to monkey with it to get an anode-row matrix to work.
* Show messages on an 8x8 led matrix (cathode rows),
* scrolling from right to left.
* Pinouts & code by Andrew
* see http://arduino.pastebin.com/f35fdf323
* see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/13#13
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 8, 9, 10, 11, 12, 13, 6, 7};
// (for some reason I ended up with different pinouts that Andrew's)
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
// Letter definitions based on 5 bit-wise columns (5 x 7 font)
#define SP {0, 0, 0, 0, 0}
#define EX {0, 125, 0, 0, 0} // !
#define A {31, 36, 68, 36, 31}
#define B {127, 73, 73, 73, 54}
#define C {62, 65, 65, 65, 34}
#define D {127, 65, 65, 34, 28}
#define E {127, 73, 73, 65, 65}
#define F {127, 72, 72, 72, 64}
#define G {62, 65, 65, 69, 38}
#define H {127, 8, 8, 8, 127}
#define I {0, 65, 127, 65, 0}
#define J {2, 1, 1, 1, 126}
#define K {127, 8, 20, 34, 65}
#define L {127, 1, 1, 1, 1}
#define M {127, 32, 16, 32, 127}
#define N {127, 32, 16, 8, 127}
#define O {62, 65, 65, 65, 62}
#define P {127, 72, 72, 72, 48}
#define Q {62, 65, 69, 66, 61}
#define R {127, 72, 76, 74, 49}
#define S {50, 73, 73, 73, 38}
#define T {64, 64, 127, 64, 64}
#define U {126, 1, 1, 1, 126}
#define V {124, 2, 1, 2, 124}
#define W {126, 1, 6, 1, 126}
#define X {99, 20, 8, 20, 99}
#define Y {96, 16, 15, 16, 96}
#define Z {67, 69, 73, 81, 97}
int dispSpeed = 8; // Constrols scroll speed (1 minimum, way too fast)
byte bit[8] = {128, 64, 32, 16, 8, 4, 2, 1}; // Used for bit comparisons
byte colVals[8] = {0, 0, 0, 0, 0, 0, 0, 0}; // Hold display columns (initaly blank)
// Define display string here
const int charNum = 16; // Number of letters in display string
byte string[charNum][5] = {A,R,D,U,I,N,O,SP,R,O,C,K,S,EX,SP,SP};
Serial.begin(9600); // for troubleshooting
for (int i = 1; i <= 16; i++) { // sets the pins as output
pinMode(pins[i], OUTPUT); }
for (int col = 0; col < 8; col++) { // set up cols and rows
digitalWrite(cols[col], HIGH); }
for (int row = 1; row < 8; row++) {
digitalWrite(rows[row], HIGH);
Serial.println(availableMemory()); // 670 bytes for charNum = 15
for (int ltr = 0; ltr < charNum; ltr++){// For each letter in string array
for (int y = 0; y < 6; y++){ // For each columin in letter + one space
shiftLeft(); // shifts display columns left
if (y < 5){
colVals[7] = string[ltr][y]; } // add new letter column on right
else {colVals[7] = 0; } // or empty space between
for (int x = 0; x < dispSpeed; x++){// loop to refresh display x times ton control scrolling
display();
void shiftLeft(){
for (int x = 0; x < 7; x++){
colVals[x] = colVals[x + 1];
void display() {
for (int col = 0; col < 8; col++){
for (int row = 0; row < 8; row++){
if (colVals[col] & bit[row]){
digitalWrite(rows[row], HIGH);}
digitalWrite(cols[col], LOW); // Turn on column
delay(1); // Delay for POV
digitalWrite(rows[row], LOW);
digitalWrite(cols[col], HIGH); // And off
// this function will return the number of bytes currently free in RAM
// written by David A. Mellis
// based on code by Rob Faludi http://www.faludi.com
int availableMemory() {
int size = 1024;
byte *buf;
while ((buf = (byte *) malloc(--size)) == NULL);
free(buf);
return size;
Now, of course, all I need for for my Max7221 chips to arrive so I can try a different tack.
