Hey everyone! I’m programming a countdown timer to act as the timer for an escape room. Their goal is to press button2 and “disarm” it (which will trigger the “Mission Successful”) within the hour.
The issue I’m having right now, is that if you press button3 (which I’ve set up just to start the timer, the timer will start, but then stops two seconds later.
I’m not entirely sure what’s going on, any suggestions would be appreciated!
Here’s the button to start the countdown timer:
if (buttonState3 != lastbuttonState3) {
lcd.clear();
lcd.setCursor(1,0);
lcd.print("Time remaining:");
lcd.setCursor(6,1);
lcd.print(":");
lcd.setCursor(9,1);
lcd.print(":");
S--;
if(S<0)
M--;
S=59;
if(M<0)
H--;
M=59;
if(H<0) { H=23; M=59; S=59; } if(M>9)
lcd.setCursor(7,1);
lcd.print(M);
lcd.setCursor(7,1);
lcd.print("0");
lcd.setCursor(8,1);
lcd.print(M);
lcd.setCursor(9,1);
lcd.print(":");
if(S>9)
lcd.setCursor(10,1);
lcd.print(S);
lcd.print("0");
lcd.setCursor(11,1);
lcd.print(S);
lcd.setCursor(12,1);
lcd.print(" ");
if(H>9)
lcd.setCursor(4,1);
lcd.print (H);
lcd.setCursor(4,1);
lcd.print("0");
lcd.setCursor(5,1);
lcd.print(H);
lcd.setCursor(6,1);
lcd.print(":");
lastbuttonState3 = buttonState3;
And here’s the whole code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
int S = 0; // count seconds
int M = 0; // count minutes
int H = 1; // count hours
const int button2 = 2;
const int button3 = 3;
const int ledPin = 13;
int buttonState2 = 0;
int buttonState3 = 0;
int lastbuttonState2 = 0;
int lastbuttonState3 = 0;
lcd.init();
lcd.backlight();
pinMode(ledPin, OUTPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
buttonState2 = digitalRead(button2);
buttonState3 = digitalRead(button3);
if (buttonState2 != lastbuttonState2) {
lcd.clear();
lcd.setCursor(4,0);
lcd.print("Mission");
lcd.setCursor(2,1);
lcd.print("Successful!");
lastbuttonState2 = buttonState2;}
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(6,1);
lcd.print(":");
lcd.setCursor(9,1);
lcd.print(":");
S--;
if(S<0)
M--;
S=59;
if(M<0)
H--;
M=59;
lcd.setCursor(7,1);
lcd.print(M);
lcd.setCursor(7,1);
lcd.print("0");
lcd.setCursor(8,1);
lcd.print(M);
lcd.setCursor(9,1);
lcd.print(":");
if(S>9)
lcd.print(S);
lcd.print("0");
lcd.print(S);
lcd.print(" ");
if(H>9)
lcd.setCursor(4,1);
lcd.print (H);
lcd.setCursor(4,1);
lcd.print("0");
lcd.setCursor(5,1);
lcd.print(H);
lcd.setCursor(6,1);
lcd.print(":");
