Hello,
I have a general bit manipulation question.
Lets say we have three bytes
Byte_A
Byte_B
Byte_C
We want to copy certain bit values from Byte_A into Byte_B and Byte_C
First, we want to take the top 4 most significant bit values in Byte_A
And we want these to be duplicated within the bottom 4 least significant bits in Byte_B.
But without altering Byte_B's top 4 most significant bits
Then we we want to take the bottom 4 least significant bits form Byte_A
And we want these to be duplicated within the bottom 4 least significant bits in Byte_C.
But again without altering Byte_C's top 4 most significant bits
Whats is the Arduino way of doing this?
byteAupper = byteA && 0xF0; // clears lower bits
byteAlower = byteA && 0x0F; // clears upper bits
byteBlower = byteB && 0x0F;
byteAupperbyteBlower = byteAupper || byteblower; // combine an upper and a lower
byteCupper = byteC && 0xF0;
byteCupperbyteAlower = byteCupper || byteAlower;
make sense?
The Arduino programming language Reference, organized into Functions, Variable and Constant, and Structure keywords.
If you want upper bits to end up in lower location, you can clear them and then shift them left or right.
byteAupperMoved = (byteA && 0xF0) >> 4;
byteAlowerMoved = (byteA && 0x0F) << 4;
And then OR ( || ) in them in like above.
Thank you CrossRoads!
Let me play with these and get back to you if I have questions.
Otherwise - thank you very much!
traja47
January 10, 2021, 12:43am
5
CrossRoads:
make sense?
&& - Arduino Reference
|| - Arduino Reference
spot on!
great answer
congrats
On the first step:
I tried this:
Byte_A = 255;
Byte_AUpper = 0;
Byte_AUpper = Byte_A && 0xF0; // clears the lower bits
Serial.println(Byte_AUpper);
Instead of clearing the lower bits and returning xF0 (decimal 240) it returned 0x1
And this also returned the value 0x1
Byte_AUpper = Byte_A && 0x0F;
Try Serial.println(Byte_AUpper, HEX);
Ascii character table - What is ascii - Complete tables including hex, octal, html, decimal conversions
I don't what you'd get trying to print the character that 240 represents from the extended ascii codes.
&& performs a logical AND ( && - Arduino Reference ) and will always return 0 or 1.
You must use a bitwise AND, see & - Arduino Reference .
Rats, did I get those backwards? & vs &&, and | vs || ?
dougp
January 10, 2021, 1:21am
11
It's a bit funky but there's insert_bits .
Thank you very much!
I'm pretty sure I've got it!
I'm going to run some further tests to verify consistency - but I think this is it.
To copy Byte_A's upper 4 bits into Byte_B without altering Byte_B's 4 top bits
//clear Byte_B's lower 4 bits
Byte_B = Byte_B & 0xF0;
//Take Byte_A's upper 4 bits and shift them down & load into TempBits
2) TempBits = Byte_A >> 4;
//Now OR Byte_B with TempBits
3) Byte_B = Byte_B | TempBits;
To Copy Byte_A's lower 4 bits into Byte_C without altering Byte_C's 4 top bits
//clear Byte_C's lower 4 bits
Byte_C = Byte_C & 0xF0;
//Load Byte_C into TempBits with the 4 upper bits cleared
2) TempBits = Byte_C & 0x0F;
//Now OR Byte_C with TempBits
3) Byte_C = Byte_C | Temp4bits;
system
Closed
May 10, 2021, 2:12am
13
