Hello again!, Can anyone help me in translating different combinations of 6 FSR's (Each FSR corresponds to one of the individual blacked dots in the braille alphabet) into each corresponding letter of the alphabet (Text only). I'm having a hard time translating each combination into letters. Thank you
Hello johnbernardcristobal
Post your sketch, well formated, with well-tempered comments and in so called
code tags "< code >" and a schematic to see how we can help.
int pressureAnalogPins[] = {0, 4, 5}; // Pins where our pressure pads are located
int numPressureAnalogPins = 3; // Number of pressure analog pins
int pressureReading; // Variable for storing our reading
// Adjust these if required.
int noPressure = 2; // Max value for no pressure on the pad
int lightPressure = 50; // Max value for light pressure on the pad
int mediumPressure = 100; // Max value for medium pressure on the pad
void setup(void) {
void loop(void) {
for (int i = 0; i < numPressureAnalogPins; i++) {
int currentPressureAnalogPin = pressureAnalogPins[i];
pressureReading = analogRead(currentPressureAnalogPin);
Serial.print("Pressure Pad ");
Serial.print(i + 1);
Serial.print(" Reading = ");
Serial.println(pressureReading);
if (pressureReading < noPressure) {
Serial.println(" - No pressure");
} else if (pressureReading < lightPressure) {
Serial.println(" - Light Pressure");
} else if (pressureReading < mediumPressure) {
Serial.println(" - Medium Pressure");
Serial.println(" - High Pressure");
sorry if i misunderstood your instructions, im only new to robotics and stuff. It only creates an output for the pressure of each FSR. Additionally, i don't know how to create the hardware for translating the outputs of each fsr into letters.
do you have 3 or 6 pads?
Show a picture of the mechanical interface between FSR and braille system.
i got 6 fsr pads each connected from what i think is called analog pins 0-5
You could create an array of structs representing the pads arrangement an matching letter
(I let you fill in the bit representation so you need to replace all the 0bxxxxxx
bits of the dots are arranged as such in the Braille struct
0 3
1 4
2 5
struct Braille {
uint8_t dots; // 6 dots represented in LSB 0-5 vertically (bit 0 is top left)
char letter;
const Braille braille_alphabet[] = {
{0b000001, 'A'}, // ⠁
{0b000011, 'B'}, // ⠃
{0bxxxxxx, 'C'}, // ⠉
{0bxxxxxx, 'D'}, // ⠙
{0bxxxxxx, 'E'}, // ⠑
{0bxxxxxx, 'F'}, // ⠋
{0bxxxxxx, 'G'}, // ⠛
{0bxxxxxx, 'H'}, // ⠓
{0bxxxxxx, 'I'}, // ⠊
{0bxxxxxx, 'J'}, // ⠚
{0bxxxxxx, 'K'}, // ⠅
{0bxxxxxx, 'L'}, // ⠇
{0bxxxxxx, 'M'}, // ⠍
{0bxxxxxx, 'N'}, // ⠝
{0bxxxxxx, 'O'}, // ⠕
{0bxxxxxx, 'P'}, // ⠏
{0bxxxxxx, 'Q'}, // ⠟
{0bxxxxxx, 'R'}, // ⠗
{0bxxxxxx, 'S'}, // ⠎
{0bxxxxxx, 'T'}, // ⠞
{0bxxxxxx, 'U'}, // ⠥
{0bxxxxxx, 'V'}, // ⠧
{0bxxxxxx, 'W'}, // ⠺
{0bxxxxxx, 'X'}, // ⠭
{0bxxxxxx, 'Y'}, // ⠽
{0b110101, 'Z'}, // ⠵
you read the pads and build a byte in the same order using bit manipulations macros bitSet() when the sensor is activated and then walk the array to find a match
I would assign a binary number position to each dot. This would take only 6 binary bits.
For instance if the locations are numbered:
1 2
3 4
5 6
Then V would be
123456 <- only for ease of counting positions
101011
O would be:
123456
100110
etc
Smart ;)…
Hello, how would i input these binary numbers into the code given by @J-M-L ? do i simply replace the 0bxxxxxx? thank you
That’s what I suggested - just a different order for the pads (in case you had only a vertical reader with 3 sensors)
Each dot is a one and a space is a zero
{0b100110, 'O',
{0b101011, 'V'},
etc
My intention is to map the pins to a binary position. Where @J-M-L Suggested assigning sequential numbers to the alphabet.
Not sure if either has a benefit over the other.
got it, thank you so much
Nope… read again my proposal
You might have been confused because A and B have one dot and then two dots.
The vertical numbering is common - see Braille Alphabet - Braille Works
Wasn't confused, I just assumed a different "pinout" than you.
Ok.. then I ma confused by what you think my proposal was.. there was no sequential number in my proposal
You are likely correct. I was thinking there may be a way to make the "decoding" easier / faster depending on how there were defined. However with a little google I read some combination of letters have different patterns. So I stopped thinking about it.
Sure it was the same suggestion, just different bit ordering . Hence why I’m confused.
Anyway no big deal
