I'm working on a small project that requires a three minute timer. Default with power up an LED comes on. Push a button an the LED goes out for three minutes and then lights again. It is a simple circuit using a few pins on an Arduino Nano and the code delay (180000) to get the three minutes. My middle school teaching daughter asked me to build the LED timer (I called it an egg timer) to assist a child in her classroom that has a learning disability.
The delay code is a brute force method of counting down time. I did some reading on millis() and thought maybe it is the better approach?
I don't have a need to manage other tasks while I wait for time, which is what I see millis() does (I think). I tried generating a block of code for the three minute timer using millis() with little success. I abandoned the exercise and used delay. I have a mental post it note to follow-up on the learning to create a working three minute timer using millis(). The code would count what ever time you set, in this case three minutes.
Any insight a member has to offer is welcome. I apologise up front, if my responses to any replies are dumb. I'm a resurrectionist rather than a programmer. I have enough knowledge to kludge together different code parts to create something. I lack the skills to actually program from scratch.
If all you're doing and all you'll ever do with this code is turn on an LED for 3-minutes there's nothing technically wrong with using a long blocking function like delay(). But you could also do this with, say, a 555 timer; you don't need all the MHz of processing cycles and peripherals and memory of an MCU for this task.
As soon as you might want to add other functions or features that you'd like to do while the LED is being timed you need to migrate to a non-blocking
Here's an example using a non-blocking technique:
* Sketch: sketch_oct26g
* Target: Uno, 2650 etc
const uint8_t pinButton = 2;
const uint8_t pinLED = LED_BUILTIN;
pinMode( pinButton, INPUT_PULLUP ); //when pressed, button to ground pin
pinMode( pinLED, OUTPUT );
}//setup
//handle the LED
DoLED();
//...do other non-blocking stuff
}//loop
void DoLED( void )
//static variables stick around and retain their
//value between calls
static uint32_t
timeStart;
static bool
bLEDState = false;
if( bLEDState == false )
//LED is off now; has button been pressed?
if( digitalRead( pinButton ) == LOW )
//yes; get and save the current millis count
timeStart = millis();
//turn on the LED
digitalWrite( pinLED, HIGH );
//and indicate the LED is on
bLEDState = true;
}//if
}//if
//LED is on now; has 3-minutes elapsed?
if( (millis() - timeStart) >= 180000ul )
//yes; turn off the LED
digitalWrite( pinLED, LOW );
//and indicate it's off
bLEDState = false;
}//if
}//else
}//DoLED
