A step by step SHA256 data hashing (Updated with full source code) [external source]
I made a video clip on YouTube titled "A step by step SHA256 data hashing".
It shows you the SHA256 algorithm flow and how it works.
It also guides you the programming steps how to get the hashed output data.
Based on these instructions, I successfully get the result on my Arduino Nano board.
My full source code.
  String InputMessage = "The quick brown fox" ;
  Serial.print("SHA256 hash program version 1.1 on Arduino Nano board") ;
  Serial.print("Now support UTF-8 with maximum printable characters up to 55 bytes");
  Serial.print("Written by p'SorSixty");
  Serial.print("5 January 2020");
  Serial.print ("Input message...");
  Serial.print (InputMessage);
  ProcessInputMessage (InputMessage);}
// Function ProcessInputMessage
  unsigned long S0; // Sigma0(HashA)
  unsigned long S1; // Sigma1(HashE)
  unsigned long maj; // Majority (A,B,C)
  unsigned long ch; // Choose (E,F,G)
  unsigned long temp1, temp2;
  unsigned long w[64]; //Holds input message
  unsigned long s0[64]; //Numbers to generate w[i]
  unsigned long s1[64]; //Number to generate w[i]
// Initial hash value
  unsigned long a, h0=0x6A09E667;
  unsigned long b, h1=0xBB67AE85;
  unsigned long c, h2=0x3C6EF372;
  unsigned long d, h3=0xA54FF53A;
  unsigned long e, h4=0x510E527F;
  unsigned long f, h5=0x9B05688C;
  unsigned long g, h6=0x1F83D9AB;
  unsigned long h, h7=0x5BE0CD19;
// Initial array of round constants:
  unsigned long k[64] = {
  0x428a2f98, 0x71374491, 0xb5c0fbcf, 0xe9b5dba5, 0x3956c25b, 0x59f111f1, 0x923f82a4, 0xab1c5ed5,
  0xd807aa98, 0x12835b01, 0x243185be, 0x550c7dc3, 0x72be5d74, 0x80deb1fe, 0x9bdc06a7, 0xc19bf174,
  0xe49b69c1, 0xefbe4786, 0x0fc19dc6, 0x240ca1cc, 0x2de92c6f, 0x4a7484aa, 0x5cb0a9dc, 0x76f988da,
  0x983e5152, 0xa831c66d, 0xb00327c8, 0xbf597fc7, 0xc6e00bf3, 0xd5a79147, 0x06ca6351, 0x14292967,
  0x27b70a85, 0x2e1b2138, 0x4d2c6dfc, 0x53380d13, 0x650a7354, 0x766a0abb, 0x81c2c92e, 0x92722c85,
  0xa2bfe8a1, 0xa81a664b, 0xc24b8b70, 0xc76c51a3, 0xd192e819, 0xd6990624, 0xf40e3585, 0x106aa070,
  0x19a4c116, 0x1e376c08, 0x2748774c, 0x34b0bcb5, 0x391c0cb3, 0x4ed8aa4a, 0x5b9cca4f, 0x682e6ff3,
  0x748f82ee, 0x78a5636f, 0x84c87814, 0x8cc70208, 0x90befffa, 0xa4506ceb, 0xbef9a3f7, 0xc67178f2};
  int n, LengthOfInputString, ByteIndex, WordIndex = 0;
  int WordPointer, NoOfWordsUsed, BytePosToWriteBit1, ByteInWord2WriteBit1;
  int InputStringBitLength, i; // i use for S0 and S1
  byte ByteInputString;
  void ProcessInputMessage (String InputString) {
  LengthOfInputString=InputString.length(); //Length in bytes, max 55 bytes
  if (LengthOfInputString > 55) {
    Serial.print("Warning!!! Input strings exceed 55 bytes...");
    //Serial.println();
    while( true ){} //Halt the program
  WordPointer=LengthOfInputString / 4;//Point to the last word which was written
  NoOfWordsUsed=WordPointer + 1;
  //Move input strings (ascii) into w[] word by word
  for (WordIndex=0; WordIndex<=NoOfWordsUsed; WordIndex++) {
    for (ByteIndex=0; ByteIndex<=3; ByteIndex++) {
      w[WordIndex]=w[WordIndex]<<8; //Shift left one byte
      ByteInputString=InputString.charAt(n);
      w[WordIndex]=w[WordIndex]+ByteInputString;
      n++;
  //Append '1' bit at (WordPointer and Byte in word to write)
  BytePosToWriteBit1=LengthOfInputString+1;
  ByteInWord2WriteBit1=BytePosToWriteBit1-(WordPointer*4);
  switch (ByteInWord2WriteBit1) {
    case 1:
      w[WordPointer]=w[WordPointer] | 0x80000000;
    case 2:
      w[WordPointer]=w[WordPointer] | 0x00800000;
    case 3:
      w[WordPointer]=w[WordPointer] | 0x00008000;
    case 4:
      w[WordPointer]=w[WordPointer] | 0x00000080;
  //Write input string bit length to last two words, w[14] and w[15]
  InputStringBitLength=LengthOfInputString*8;
  w[14]=0x0; //This version supports only 55 character of input message, so w[14] is always 0
  w[15]=w[15]+InputStringBitLength;
  //Serial.print(InputStringBitLength,HEX);
  //Serial.println();
  //Calculate s0[i], s1[i] and w[i]
  for (i=16; i<=63; i++) {
    s0[i]=Gets0(w[i-15]);
    s1[i]=Gets1(w[i-2]);
    w[i]=w[i-16] + s0[i] + w[i-7] + s1[i] ; }
  //Initialize working variables to current hash value:
  a=h0;
  b=h1;
  c=h2;
  d=h3;
  e=h4;
  f=h5;
  g=h6;
  h=h7;
  //Compression function main loop
  for (i=0; i<=63; i++) {
    S1=GetSigma1(e);
    ch=GetChoose(e,f,g);
    temp1=h+S1+ch+k[i]+w[i];
    S0=GetSigma0 (a);
    maj=GetMajority(a,b,c);
    temp2=S0+maj;
    //Assign new hash then loop again
    h=g;
    g=f;
    f=e;
    e=d+temp1;
    d=c;
    c=b;
    b=a;
    a=temp1+temp2;
  //Final hash result, add original hash with the last caculated hash
  h0=h0+a;
  h1=h1+b;
  h2=h2+c;
  h3=h3+d;
  h4=h4+e;
  h5=h5+f;
  h6=h6+g;
  h7=h7+h;
  Serial.println() ;
  Serial.print("SHA256 hashed output message...") ;
  Serial.println() ;
  //Print the result
  PrintWithLeadingZero(h0);
  PrintWithLeadingZero(h1);
  PrintWithLeadingZero(h2);
  PrintWithLeadingZero(h3);
  PrintWithLeadingZero(h4);
  PrintWithLeadingZero(h5);
  PrintWithLeadingZero(h6);
  PrintWithLeadingZero(h7);
  Serial.print("----------------------------------------------------------------") ;
}//End
// Function GetS1 (s1[i])
  unsigned long s1Return;
  unsigned long Gets1 (unsigned long wi2Receive) {
  s1Return=((wi2Receive & 0x0001ffff)<<32-17)+(wi2Receive>>17)^((wi2Receive & 0x0007ffff)<<32-19)+(wi2Receive>>19)^(wi2Receive>>10);
  return s1Return;}
// Function Gets0[i]
  unsigned long s0Return;
  unsigned long Gets0 (unsigned long wi15Receive) {
  s0Return=((wi15Receive&0x0000007f)<<32-7)+(wi15Receive>>7)^((wi15Receive&0x0003ffff)<<32-18)+(wi15Receive>>18)^(wi15Receive>>3);
  return s0Return;}
// Function GetChoose(E,F,G)
  unsigned long Choose ;
  unsigned long GetChoose (unsigned long HashE,unsigned long HashF,unsigned long HashG) {
  Choose=(HashE & HashF)^((~HashE)&HashG);
  return Choose;}
// Function GetMajority
  unsigned long Majority; //Majority(A,B,C)
  unsigned long GetMajority (unsigned long HashA,unsigned long HashB,unsigned long HashC) {
    Majority=(HashA&HashB)^(HashA&HashC)^(HashB&HashC);
  return Majority;}
// Function GetSigma0
  unsigned long TempSigma0 ;
  unsigned long GetSigma0 (unsigned long InputHash) {
  TempSigma0=((InputHash&0x00000003)<<32-2)+(InputHash>>2)^((InputHash&0x00001fff)<<32-13)+(InputHash>>13)^((InputHash&0x003fffff)<<32-22)+(InputHash>>22);
  return TempSigma0;}
// Function GetSigma1
  unsigned long TempSigma1 ;
  unsigned long GetSigma1 (unsigned long InputHash) {
  TempSigma1=((InputHash&0x0000003f)<<32-6)+(InputHash>>6)^((InputHash&0x000007ff)<<32-11)+(InputHash>>11)^((InputHash&0x01ffffff)<<32-25)+(InputHash>>25);
  return TempSigma1;}
// Function PrintWithLeadingZero
  unsigned long TempLz;
  void PrintWithLeadingZero (unsigned long ReceiveUnsignedLong) {
    TempLz=ReceiveUnsignedLong&0xf0000000; TempLz=TempLz>>28; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x0f000000; TempLz=TempLz>>24; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x00f00000; TempLz=TempLz>>20; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x000f0000; TempLz=TempLz>>16; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x0000f000; TempLz=TempLz>>12; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x00000f00; TempLz=TempLz>>8; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x000000f0; TempLz=TempLz>>4; Serial.print(TempLz, HEX);
    TempLz=ReceiveUnsignedLong&0x0000000f; TempLz=TempLz>>0; Serial.print(TempLz, HEX);
I updated with full list of source code.
You can try by changing different InputMessage at line no. 2.
Input message length support up to 55 bytes of printable characters with UTF-8 Thai characters support.
Note that one Thai character takes 3 bytes long (UTF-8).
Let me know if you have any question.
Thank you.
References:
An excellent spreadsheet to start with SHA256, made by David Rabahy.
Arduino Reference - Arduino Reference */
