Hello!
I would like to share my library for building user interface. It is based on the Frank de Brabander's library for text I2C displays. I added some functions for formatted output, input and value selection, definition the menu. You can find the source code and examples on github: GitHub - VladimirTsibrov/LiquidCrystal_I2C_Menu: Arduino library for LiquidCrystal displays that use the I2C bus. Provides additional functions for building the user interface.. Sorry for the lack of description in English. Maybe someone will find my library useful. Or someone might want to give advice.
Below are library functions:
- printAt(x, y, data) β prints data from the specified position.
- printf(format, β¦) β prints formatted data. Works like sprintf, but unlike it prints data to the display, not to the buffer.
- printfAt(x, y, format, β¦) β prints formatted data from the specified position.
- attachEncoder(pinA, pinB, pinBtn) β tells the library which pins of the Arduino the encoder is connected to.
- getEncoderState() β polling the encoder status. Returns a value of type eEncoderState (an enumerated type, described in the library as {eNone, eLeft, eRight, eButton}).
- printMultiline(text) β prints text with vertical scrolling.
- inputVal(title, min, max, default, [step], [onChangeFunc]) β entering a numeric value. The min and max parameters specify the range in which the value can change; default - initial value; step - the value of the increment, by the default is 1; optional parameter onChangeFunc - a pointer to a function that should be called when the value changes.
- inputValAt(x, y, min, max, default, [step], [onChangeFunc]) β is similar to the inputVal function, but unlike it, it does not clear the display when called and the value is entered from the specified position.
- inputValBitwise(title, value, precision, [scale], [signed]) β allows you to enter values by editing individual digits of a number. The value parameter is a reference to the variable into which the result will be placed; precision - total number of digits in a number; scale - the number of digits to the right of the decimal point, the default value is 0; signed - allows (if true) or disallows (if false - by default) entering negative numbers. The function returns true if the user confirmed the input, false if he refused.
- inputStrVal(title, buffer, length, available_symbols) β unlike inputValBitwise allows you to enter not only numeric values. buffer - a reference to a character buffer, into which the result of the input will be placed; length - the number of characters to enter; the available_symbols parameter is the string of characters available for input.
- selectVal(title, list_of_values, count, [show_selected], [selected_index]) β lets you select a value from the list and returns the index of the selected item. list - a list of values to select, is an array of char*, String or int values; count - the number of elements in the array; show_selected - flag for displaying the label on the selected element; selected_index - the index of the default selected item.
- showMenu(menu, menu_length, show_title) β displays the menu and returns the key of the selected item. menu is an array of items of sMenuItem type; menu_length - length of the menu; show_title - flag to display the title.
- getSelectedMenuItem() β returns the key of the selected menu item for use inside menu-handlers.
- attachIdleFunc(IdleFunc) β allows you to bind a function that will be called by the library when idle.
Here are wiring diagram and a few examples in the attachments:
