hi all,
actually I have a serious problem I connected arduino mega with ethernet shield and RC522 RFID both ethernet shield and RC522 works pretty well when they are used individually but when I connect them both the RC522 continues to work but ethernet shield stopped working
ps: I used different SS pins for the two SPI devices but the problem still occuring
please any help!
please any help!
Without seeing your code? No.
ok now I solved the problem both are working in the present of the other but till now there is no output from RC522 in the webserver when I use them both in the same program
here is the code
#include <SPI.h>
#include <Ethernet.h>
#include <MFRC522.h>
#include <String.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };// Enter the IP address for Arduino, as mentioned we will use 192.168.0.16
// Be careful to use , insetead of . when you enter the address here
IPAddress ip(192,168,1,115);#define RST_PIN 5 //this is configurable and it stands for RST pin of the RFID tag
#define SS_PIN 53 //this is configurable and it stands forchip select pin of the RFID tag
String read_RFID;
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance// Initialize the Ethernet server library
EthernetServer server(80);void setup() {
// Serial.begin starts the serial connection between computer and Arduino
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("Arduino server IP address: ");
Serial.println(Ethernet.localIP());
while(!Serial); // Do nothing if no serial port is opened just wait
SPI.begin(); // Initialize SPI bus
mfrc522.PCD_Init(); //Initialize MFRC522
void dump_byte_array(byte buffer , byte buffer_size)
read_RFID = "";
for (byte i = 0 ; i < buffer_size ; i++)
read_RFID = read_RFID + String(buffer,HEX); *
void loop() {//photocellReading = analogRead(photocellPin); // Fill the sensorReading with the information from sensor*
//pirReading = digitalRead(pirPin); // Fill the sensorReading with the information from sensor*
EthernetClient client = server.available(); // Listen for incoming clients*
if (client) {*
// When a client sends a request to a webserver, that request ends with a blank line*
boolean currentLineIsBlank = true;*
while (client.connected()) {*
if (client.available()) {*
char c = client.read();*
// This line is used to send communication information between Arduino and your browser over Serial Monitor*
Serial.write(c);*
// When the request has ended send the client a reply*
if (c == '\n' && currentLineIsBlank) {*
// We send the HTTP response code to the client so it knows that we will send him HTML data*
// and to refresh the webpage every 5 seconds*
client.println("HTTP/1.1 200 OK");*
client.println("Content-Type: text/html");*
client.println("Connection: close");*
client.println("Refresh: 5");*
client.println();*
// Here we write HTML data (for the page itself) which will be sent to the client.*
// The HTML includes Javascript which fills the data*
client.println("");*
client.println("Arduino sensor data");*
client.println("*
");client.println("
tag read from the sensor is:
");*client.println("
");*client.println("");*
break;*
if (c == '\n') {*
// Check if a new line is started*
else if (c != '\r') {*
// If a new line was not strated*
currentLineIsBlank = false;*
// Give the client some time to recieve the data (1ms)*
delay(100);*
// In the end close the connection*
client.stop();*
}[/quote]
What pin is the Ethernet shield using as the chip select pin?
Can you tell us the line numbers of the code that actually reads from the RFID hardware?
When a browser connects to the Arduino-as-server, can you right click, and choose to view the page source? Can you post that data here?
sorry sir for the late reply I have some internet connection problems , later on I will provide you with the complete information and circuitry
thank you very much;
