A4988 Step Motor Control With ESP32/ESP8266
Hi all,
I am trying to control Nema17+A4988 step motor with ESP32 board via web server but I could'nt be successful.
The thing which I want to do is; Rotating motor clock side while pressed one button, rotating otherside while pressed other button. ( This motion will be used for wifi controlled blind)
After uploading code to the board I noticed ,although button is pressed motor turns only once (once for loop). Probbly it is because of function "break" which is needed to webserver run.
I would be very grateful if you could help me on how to fix this problem.
// Load Wi-Fi library
#include <WiFi.h>
// Replace with your network credentials
const char* ssid = "KAYA-NET";
const char* password = "ardakaya-159753*";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the current output state
String output26State = "off";
String output27State = "off";
// Assign output variables to GPIO pins
const int output26 = 26;
const int output27 = 27;
const int dirPin = 2;
const int stepPin = 4;
const int enable_pin=13;
const int stepsPerRevolution = 10;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
  // Initialize the output variables as outputs
  pinMode(output26, OUTPUT);
  pinMode(output27, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(enable_pin, OUTPUT);
  digitalWrite(output26, LOW);
  digitalWrite(output27, LOW);
  digitalWrite(enable_pin, HIGH);
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  server.begin();
void up(){
  digitalWrite(dirPin, HIGH);
  digitalWrite(enable_pin, LOW);
  for(int x = 1; x > 0; x++)
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(1000);
    digitalWrite(stepPin, LOW);
     Serial.println("Kaldir..");
void down(){
  digitalWrite(dirPin, LOW);
     Serial.println("Indir..");
void iddle(){
void loop(){
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    previousTime = currentTime;
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected() && currentTime - previousTime <= timeoutTime) {  // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /26/on") >= 0) {
              Serial.println("GPIO 26 on");
              output26State = "Up";
              digitalWrite(output26, HIGH);
              kaldir();
            } else if (header.indexOf("GET /26/off") >= 0) {
              Serial.println("GPIO 26 off");
              iddle();
            } else if (header.indexOf("GET /27/on") >= 0) {
              Serial.println("GPIO 27 on");
              output27State = "Iniyor";
              digitalWrite(output27, HIGH);
              down();
            } else if (header.indexOf("GET /27/off") >= 0) {
              Serial.println("GPIO 27 off");
              iddle();
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #555555;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>KAYA HOME Perde Kontrol</h1>");
            // Display current state, and ON/OFF buttons for GPIO 26
            client.println("<p>Perde " + output26State + "</p>");
            // If the output26State is off, it displays the ON button
            if (output26State=="off") {
              client.println("<p><a href=\"/26/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/26/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 27
            client.println("<p>Perde " + output27State + "</p>");
            // If the output27State is off, it displays the ON button
            if (output27State=="off") {
              client.println("<p><a href=\"/27/on\"><button class=\"button\">ON</button></a></p>");
              client.println("<p><a href=\"/27/off\"><button class=\"button button2\">OFF</button></a></p>");
            client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
Thanks to below wonderfull website I found my solution.
https://randomnerdtutorials.com/esp32-websocket-server-arduino/
I edited codes for my project requirement and it worked.
I'm adding codes below in case it might be useful to someone.
// Import required libraries
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
int kaldir_state = 0;
int indir_state = 0;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
AsyncWebSocket ws("/ws");
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <title>ESP Web Server</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="icon" href="data:,">
  <style>
  html {
    font-family: Arial, Helvetica, sans-serif;
    text-align: center;
  h1 {
    font-size: 1.8rem;
    color: white;
  h2{
    font-size: 1.5rem;
    font-weight: bold;
    color: #143642;
  .topnav {
    overflow: hidden;
    background-color: #143642;
  body {
    margin: 0;
  .content {
    padding: 30px;
    max-width: 600px;
    margin: 0 auto;
  .card {
    background-color: #F8F7F9;;
    box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5);
    padding-top:10px;
    padding-bottom:20px;
  .button {
    padding: 15px 50px;
    font-size: 24px;
    text-align: center;
    outline: none;
    color: #fff;
    background-color: #0f8b8d;
    border: none;
    border-radius: 5px;
    -webkit-touch-callout: none;
    -webkit-user-select: none;
    -khtml-user-select: none;
    -moz-user-select: none;
    -ms-user-select: none;
    user-select: none;
    -webkit-tap-highlight-color: rgba(0,0,0,0);
   /*.button:hover {background-color: #0f8b8d}*/
   .button:active {
     box-shadow: 2 2px #CDCDCD;
     transform: translateY(2px);
   .state {
     font-size: 1.5rem;
     color:#8c8c8c;
     font-weight: bold;
  </style>
<title>KAYAHOME-Perde Control</title>
</head>
<body>
  <div class="topnav">
    <h1>Perde Kontrol</h1>
  </div>
  <div class="content">
    <div class="card">
      <p class="state">Durum: <span id="state">%STATE%</span></p>
      <p><button id="button_kaldir" class="button">Kaldir</button></p>
      <p><button id="button_indir" class="button">Indir</button></p>
    </div>
  </div>
<script>
  var gateway = `ws://${window.location.hostname}/ws`;
  var websocket;
  window.addEventListener('load', onLoad);
  function initWebSocket() {
    console.log('Trying to open a WebSocket connection...');
    websocket = new WebSocket(gateway);
    websocket.onopen    = onOpen;
    websocket.onclose   = onClose;
    websocket.onmessage = onMessage; // <-- add this line
  function onOpen(event) {
    console.log('Connection opened');
  function onClose(event) {
    console.log('Connection closed');
    setTimeout(initWebSocket, 2000);
  function onMessage(event) {
    var state;
    if (event.data == "1"){
      state = "ON";
    else{
      state = "OFF";
    document.getElementById('state').innerHTML = state;
  function onLoad(event) {
    initWebSocket();
    initButton_kaldir();
    initButton_indir();
  function initButton_kaldir() {
    document.getElementById('button_kaldir').addEventListener('click', kaldir);
  function initButton_indir() {
    document.getElementById('button_indir').addEventListener('click', indir);
  function kaldir(){
    websocket.send('kaldir');
  function indir(){
    websocket.send('indir');
</script>
</body>
</html>
)rawliteral";
void notifyClients_kaldir() {
  ws.textAll(String(kaldir_state));
void notifyClients_indir() {
  ws.textAll(String(indir_state));
void handleWebSocketMessage(void *arg, uint8_t *data, size_t len) {
  AwsFrameInfo *info = (AwsFrameInfo*)arg;
  if (info->final && info->index == 0 && info->len == len && info->opcode == WS_TEXT) {
    data[len] = 0;
    if (strcmp((char*)data, "kaldir") == 0) {
      kaldir_state = !kaldir_state;
      notifyClients_kaldir();
    if (strcmp((char*)data, "indir") == 0) {
      indir_state = !indir_state;
      notifyClients_indir();
void onEvent(AsyncWebSocket *server, AsyncWebSocketClient *client, AwsEventType type,
  switch (type) {
    case WS_EVT_CONNECT:
      Serial.printf("WebSocket client #%u connected from %s\n", client->id(), client->remoteIP().toString().c_str());
    case WS_EVT_DISCONNECT:
      Serial.printf("WebSocket client #%u disconnected\n", client->id());
    case WS_EVT_DATA:
      handleWebSocketMessage(arg, data, len);
    case WS_EVT_PONG:
    case WS_EVT_ERROR:
void initWebSocket() {
  ws.onEvent(onEvent);
  server.addHandler(&ws);
String processor(const String& var){
  Serial.println(var);
  if(var == "STATE"){
    if (kaldir_state){
      return "ON";
    else{
      return "OFF";
  return String();
void setup(){
  // Serial port for debugging purposes
  // Connect to Wi-Fi
    Serial.println("Connecting to WiFi..");
  // Print ESP Local IP Address
  initWebSocket();
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  // Start server
  server.begin();
  ws.cleanupClients();
  if(kaldir_state == 1){
    // Set motor direction clockwise
  // Spin motor slowly
  for(int x = 0; x < stepsPerRevolution; x++)
    delayMicroseconds(400);
  if(kaldir_state == 0){
  if(indir_state == 1){
  if(indir_state == 0){
