A6 GPRS and sim lock
Hi all
I just received my A6 GPRS module. I inserted a sim code and tried to send an SMS.
I found some scripts on the internet. They ran okay.
When I tried to send an sms, I got CME 58 error. I found out that this was due to a pin lock on the sim card.
Using AT+CPIN=XXXX (where XXXX was the sim code) in the serial monitor, it gave some output I didn't understand, but however, thereafter I could send an sms-message.
Is it possible to 'run' that code without typing it in the serial monitor ? If yes, how should I enter this as a command (as AT+CPIN=xxxx is not recognized as an Arduino commando).
The code I am using is written below.
Thanks for any help.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3, 2); // TX-Pin11, RX-Pin10
void updateSerial()
delay(2000);
while (Serial.available()) {
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while(mySerial.available()) {
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
mySerial.begin(9600);
mySerial.println("AT"); // Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CMGF=1"); // Configuring mode is TEST, only English texts are available
updateSerial();
mySerial.println("AT+CMGS="0497249119"");//xxxxxxxxxxx is the phone number
updateSerial();
mySerial.print("Dit is een test"); //text content
updateSerial();
mySerial.write(26);
while(1)
if(mySerial.available())
Serial.write(mySerial.read());}//Data received by mySerial will be outputted by Serial }
if(Serial.available())
mySerial.write(Serial.read());//Data received by Serial will be outputted by mySerial }
Diedhert:
You can print whatever you want to the A6. You are already doing that in the code you posted:
  updateSerial();
  updateSerial();
  mySerial.println("AT+CMGS=\"0497249119\"");//xxxxxxxxxxx is the phone number
These are all AT commands you are sending from the program running on your Arduino board to the A6.
Hi
(I have little programming skills, so I am looking for codes, try to understand it and then to adjust it).
If I understand well, if I add a line
mySerial.println("AT+CPIN=1234") //where 1234 is the pin code
updateSerial();
the pincode should be send to the A6.
But - apologies if this is a dumb question - will this work on the "arduino+A6" solely, not connected to a computer & serial monitor ?
If I understand well ... the instruction is written to the serial monitor, and read (=send to A6) as well. So what if there is no serial monitor ?
But what command should I use to send an sms if something happens (for instance if a laser beam is interrupted, if a counter counts 100, ...) ?
If the Arduino+A6 is not connected to a computer, there is no serial monitor, so I suppose the MySerial command will not work ?
(I am just trying to understand how it is working).
Regards
Diederik
Diedhert:
if I add a line
You forgot the semicolon.
Diedhert:
Correct.
Diedhert:
Yes.
Diedhert:
You don't understand well. This line:
writes "AT+CPIN=1234" to the software serial interface on pins 2 and 3, which your A6 is connected to. It does not write it to Serial Monitor. If the A6 returns data in response to that command, that data will be written to Serial Monitor.
If you wanted to write something to Serial Monitor, you would do it like this:
Serial.println("This is printed to Serial Monitor");
Diedhert:
Diedhert:
It will work just fine! Why don't you give it a try? The great thing about Arduino is it's so easy to run experiments and learn from them.
Thanks for your answer. Really (truly really).
I am experimenting further.
I have still another issue.
Actually, I found two codes, from a different site.
The code below is working fine, giving nothing peculiar in the serial monitor view.
//Create software serial object to communicate with A6
SoftwareSerial mySerial(3, 2); //A6 Tx & Rx is connected to Arduino #3 & #2
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and A6
Serial.println("Initializing...");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
updateSerial();
mySerial.println("AT+CMGS="0497249119"");//change ZZ with country code and xxxxxxxxxxx with phone number to sms
updateSerial();
mySerial.print("Last Minute Engineers | lastminuteengineers.com"); //text content
updateSerial();
mySerial.write(26);
void updateSerial()
However, this very similar code
"#include <SoftwareSerial.h>
void updateSerial()
delay(2000);
updateSerial();
// mySerial.println("AT+CPIN=1111");
// updateSerial();
updateSerial();
updateSerial();
mySerial.print("SIM5 test"); //text content
updateSerial();
mySerial.write(26);
while(1)
Returns in the serial monitor
AT
OK
AT+CMGF=1
OK
SIM5 test⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
+CMGS: 15
OK
I do receive the sms (so far so good), but I am quite confused with the inverted question marks.
When I do compare the two codes, they are very similar. Only some parts are in different order.
The procedure void updateSerial() is exactly the same, only once in the beginning and once in the end.
Main difference is in the one code the void loop is empty, and the void setup consists of the code that is in the void loop of the other one. It is followed by a while-function as well.
Is it the while-loop that generates an error ?
Regards (and once again thanks for clearing out things step by step)
