About comparing a char in an "if" statment.
Hello everyone,
I am very new to the arduino. For making a project i need to write the code in such a manner so that it can compare a char in an if conditional logic.
I have written a code. It doesn't show any error message while compiling. But after uploading it to the arduino it doesn't work too. Can anyone please solve this for me.
char myStrings;
int u;
int q; int r; int s; int t;
int m; int n; int o; int p;
char a, b, c, d;
if (Serial.available() > 0 ) {
myStrings = Serial.read();
Serial.print("I received: ");
Serial.println(myStrings);
u=u+1;
if (u=1) {a=myStrings;
Serial.println(a);}
if (u=2) {b=myStrings;
Serial.println(b);}
if (u=3) {c=myStrings;
Serial.println(c);}
if (u=4) {d=myStrings;
Serial.println(d);}
if (a=='a')
m=1;
if (a=='b')
m=2;
if (a=='c')
m=3;
if (a=='d')
m=4;
if (a=='e')
m=5;
if (a=='f')
m=6;
if (a=='g')
m=7;
if (a=='h')
m=8;
if (c=='a')
n=1;
if (c=='b')
n=2;
if (c=='c')
n=3;
if (c=='d')
n=4;
if (c=='e')
n=5;
if (c=='f')
n=6;
if (c=='g')
n=7;
if (c=='h')
n=8;
if (b=='1')
o=1;
if (b=='2')
o=2;
if (b=='3')
o=3;
if (b=='4')
o=4;
if (b=='5')
o=5;
if (b=='6')
o=6;
if (b=='7')
o=7;
if (b=='8')
o=8;
if (d=='1')
p=1;
if (d=='2')
p=2;
if (d=='3')
p=3;
if (d=='4')
p=4;
if (d=='5')
p=5;
if (d=='6')
p=6;
if (d=='7')
p=7;
if (d=='8')
p=8;
q=n-m; r=p-o;
s= abs(q);
t=abs(r);
A useful simplification for you. Not an answer to your question sorry, but it will combine lots of those lines into just four equivalent ones.
if( (a >= 'a') && (a <= 'h')) m = a -'a' +1;
if( (b >= 'a') && (b <= 'h')) n = b -'a' +1;
if( (c >= '1') && (c <= '8')) o = c -'1' +1;
if( (d >= '1') && (d <= '8')) p = d -'1' +1;
Why set u to 1?
Mark
Yes, fix these:
                u=u+1;
                Serial.println(a);}
                Serial.println(b);}
                Serial.println(c);}
                Serial.println(d);}
to use u == #
Does this line
u=u+1;
ever get set back to u = 0?
Or does it get just increment until u equals some ridiculous high number?
char myStrings;
I hope this doesn't imply that you'll do other stupid shit like:
int myFloats;
float myChars;
char myFloats;
Delta_G:
What do you mean when you say it doesn't work? What actually happens? How does that compare with what you wanted?
the arduino doesn't process the comparison. I want to give the arduino a serial command in a format "a2a3" which means it will make the output "1 2 1 3" where a, b, c.... is 1, 2,3...
ok.. here is my full code... please help me fix it... i need to run the motors when a coordinate is given by serial in "a2b3" format which means it will move a thing from a2 posion to b3 position.
#include <AFMotor.h>
#include <Servo.h>
int Electromagnet = 2;
AF_Stepper motor1(32, 1);
AF_Stepper motor2(32, 2);
char myStrings;
int u;
char a, b, c, d;
pinMode(Electromagnet, OUTPUT);
motor1.setSpeed(500);
motor2.setSpeed(500);
u=u+1;
Serial.println(a);}
Serial.println(b);}
Serial.println(c);}
Serial.println(d);}
u=0;
if (a=='a')
m=1;
if (a=='b')
m=2;
if (a=='c')
m=3;
if (a=='d')
m=4;
if (a=='e')
m=5;
if (a=='f')
m=6;
if (a=='g')
m=7;
if (a=='h')
m=8;
if (c=='a')
n=1;
if (c=='b')
n=2;
if (c=='c')
n=3;
if (c=='d')
n=4;
if (c=='e')
n=5;
if (c=='f')
n=6;
if (c=='g')
n=7;
if (c=='h')
n=8;
if (b=='1')
o=1;
if (b=='2')
o=2;
if (b=='3')
o=3;
if (b=='4')
o=4;
if (b=='5')
o=5;
if (b=='6')
o=6;
if (b=='7')
o=7;
if (b=='8')
o=8;
if (d=='1')
p=1;
if (d=='2')
p=2;
if (d=='3')
p=3;
if (d=='4')
p=4;
if (d=='5')
p=5;
if (d=='6')
p=6;
if (d=='7')
p=7;
if (d=='8')
p=8;
q=n-m; r=p-o;
s= abs(q); t=abs(r);
if ( q>0 && r>0 ) //1
motor1.step(100m-1, FORWARD, DOUBLE);
delay (500);
motor2.step(100
o-1, FORWARD, DOUBLE);
delay (500);
digitalWrite(Electromagnet, HIGH);
delay (500);
motor1.step(100.5, FORWARD, DOUBLE);
delay (500);
motor2.step(100.5, FORWARD, DOUBLE);
delay (500);
motor2.step(100t-1, FORWARD, DOUBLE);
delay (500);
motor1.step(100
s-1, FORWARD, DOUBLE);
delay (500);
delay (500);
delay (500);
digitalWrite(Electromagnet, LOW);
delay (500);
motor2.step(100p-1, BACKWARD, DOUBLE);
delay (500);
motor1.step(100
n-1, BACKWARD, DOUBLE);
delay (500);
if ( q>0 && r<0 ) //2
motor1.step(m-1, FORWARD, DOUBLE);
delay (500);
motor2.step(o-1, FORWARD, DOUBLE);
delay (500);
delay (500);
motor1.step(0.5, FORWARD, DOUBLE);
delay (500);
motor2.step(0.5, BACKWARD, DOUBLE);
delay (500);
motor2.step(t-1, BACKWARD, DOUBLE);
delay (500);
motor2.step(q-1, FORWARD, DOUBLE);
delay (500);
delay (500);
delay (500);
delay (500);
motor2.step(p-1, BACKWARD, DOUBLE);
delay (500);
motor1.step(n-1, BACKWARD, DOUBLE);
delay (500);
if ( q<0 && r>0 ) //3
delay (500);
delay (500);
delay (500);
motor2.step(0.5, FORWARD, DOUBLE);
delay (500);
motor1.step(0.5, BACKWARD, DOUBLE);
delay (500);
motor1.step(s-1, BACKWARD, DOUBLE);
delay (500);
motor2.step(t-1, FORWARD, DOUBLE);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
if ( q<0 && r<0 ) //4
motor1.step(m-1, FORWARD, DOUBLE); delay (500);
motor2.step(o-1, FORWARD, DOUBLE); delay (500);
digitalWrite(Electromagnet, HIGH); delay (500);
motor2.step(0.5, BACKWARD, DOUBLE); delay (500);
motor1.step(0.5, BACKWARD, DOUBLE); delay (500);
motor1.step(s-1, BACKWARD, DOUBLE); delay (500);
motor2.step(t-1, BACKWARD, DOUBLE); delay (500);
digitalWrite(Electromagnet, LOW); delay (500);
motor2.step(p-1, BACKWARD, DOUBLE); delay (500);
motor1.step(n-1, BACKWARD, DOUBLE); delay (500);
if ( q==0 && r>0 ) //5
motor1.step(0.5, FORWARD, DOUBLE); delay (500);
motor2.step(0.5, FORWARD, DOUBLE); delay (500);
motor2.step(t-1, FORWARD, DOUBLE); delay (500);
if ( q==0 && r<0 ) //6
if ( q>0 && r==0 ) //7
motor2.step(s-1, FORWARD, DOUBLE); delay (500);
if ( q<0 && r==0 ) //8
I am trying to make a chess robot where i will give input to the arduino as a format "a2b3". I have done the code but it's not working. In the comparison step which is done using if statment doesn't work. Here is my code. please help me fix this.
#include <Servo.h>
char myStrings;
int u;
char a, b, c, d;
motor1.setSpeed(500); // 10 rpm
motor2.setSpeed(500); // 10 rpm
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
// read the incoming byte:
// say what you got:
u=u+1;
Serial.println(a);}
Serial.println(b);}
Serial.println(c);}
Serial.println(d);}
u=0;
if (a=='a')
m=1;
if (a=='b')
m=2;
if (a=='c')
m=3;
if (a=='d')
m=4;
if (a=='e')
m=5;
if (a=='f')
m=6;
if (a=='g')
m=7;
if (a=='h')
m=8;
if (c=='a')
n=1;
if (c=='b')
n=2;
if (c=='c')
n=3;
if (c=='d')
n=4;
if (c=='e')
n=5;
if (c=='f')
n=6;
if (c=='g')
n=7;
if (c=='h')
n=8;
if (b=='1')
o=1;
if (b=='2')
o=2;
if (b=='3')
o=3;
if (b=='4')
o=4;
if (b=='5')
o=5;
if (b=='6')
o=6;
if (b=='7')
o=7;
if (b=='8')
o=8;
if (d=='1')
p=1;
if (d=='2')
p=2;
if (d=='3')
p=3;
if (d=='4')
p=4;
if (d=='5')
p=5;
if (d=='6')
p=6;
if (d=='7')
p=7;
if (d=='8')
p=8;
q=n-m; r=p-o;
delay (500);
motor2.step(100
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
motor1.step(100
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
motor1.step(100
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
delay (500);
Please edit your post and use code tags.
** **[code]** **
your code here
** **[/code]** **
will result in
 your code here
Based on below excerpt of your code, I don't think that the variable 'u' will ever have the values 2, 3 or 4? The last line resets 'u' to 0. I strongly suggest that you read serial input basics and learn how to use arrays.
    u = u + 1;
    if (u = 1) {
      a = myStrings;
      Serial.println(a);
    if (u = 2) {
      b = myStrings;
      Serial.println(b);
    if (u = 3) {
      c = myStrings;
      Serial.println(c);
    if (u = 4) {
      d = myStrings;
      Serial.println(d);
    u = 0;
Next, don't use single character variable names and ABSOLUTELY do not use them for global variables. Give those variables sensible names. The variable name 'u' above is probably meant as a kind of an index. So call it something like 'index'.
I think it was already mentioned that something like below
  if (a == 'a')
    m = 1;
  if (a == 'b')
    m = 2;
  if (a == 'c')
    m = 3;
  if (a == 'd')
    m = 4;
  if (a == 'e')
    m = 5;
  if (a == 'f')
    m = 6;
  if (a == 'g')
    m = 7;
  if (a == 'h')
    m = 8;
can easily be replaced by
if(a>='a' && a <='h')
  m = a - 'a' + 1;
So what does the letter 'm' stand for? Give it a decent name and while you're doing so, give those other single character variables decent names as well.
                Serial.println(a);}
                Serial.println(b);}
                Serial.println(c);}
                Serial.println(d);}
Garbage. Pure unadulterated garbage. Just like in your other post.
I'm not totally surprised. Try doing some C tutorials.
Oh, and read the forum "stickies". In particular the part about using code tags.
 if (a=='a')
        m=1;
        if (a=='b')
        m=2;
        if (a=='c')
        m=3;
        if (a=='d')
        m=4;
        if (a=='e')
        m=5;
        if (a=='f')
        m=6;
        if (a=='g')
        m=7;
        if (a=='h')
        m=8;
Is there a pattern there? Perhaps you can do a simple subtraction?
Duplicate of this thread
Stop cross-posting.
Thread locked.
Iftekhar:
Two-day ban for cross-posting. Are you new to the Internet as well?
sterretje:
It's generally better to use the Report to Moderator link, and let the moderators deal with the idiots that cross-post.
OK, thanks.
//Edit: Reported :wink:
. . . and the OP is enjoying a brief forum timeout, to give him/her a chance to read the posting guidelines.
