About the button-label font changes after pressed
Hi all.
The TFT_eSPI example: Keypad_240x320 works well.
the button-label changes after the buttons 4/5/6/Del pressed, by commented out L125/L126, why and how to get that 2 lines removed and still keep fonts no change by pressed button?
Thanks
Adam
  The TFT_eSPI library incorporates an Adafruit_GFX compatible
  button handling class, this sketch is based on the Arduin-o-phone
  example.
  This example diplays a keypad where numbers can be entered and
  send to the Serial Monitor window.
  The sketch has been tested on the ESP8266 (which supports SPIFFS)
  The minimum screen size is 320 x 240 as that is the keypad size.
// The SPIFFS (FLASH filing system) is used to hold touch screen
// calibration data
#include "FS.h"
#include <SPI.h>
#include <TFT_eSPI.h>      // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
// This is the file name used to store the calibration data
// You can change this to create new calibration files.
// The SPIFFS file name must start with "/".
#define CALIBRATION_FILE "/TouchCalData1"
// Set REPEAT_CAL to true instead of false to run calibration
// again, otherwise it will only be done once.
// Repeat calibration if you change the screen rotation.
#define REPEAT_CAL false
// Keypad start position, key sizes and spacing
#define KEY_X 40 // Centre of key
#define KEY_Y 96
#define KEY_W 62 // Width and height
#define KEY_H 30
#define KEY_SPACING_X 18 // X and Y gap
#define KEY_SPACING_Y 20
#define KEY_TEXTSIZE 1   // Font size multiplier
// Using two fonts since numbers are nice when bold
#define LABEL1_FONT &FreeSansOblique12pt7b // Key label font 1
#define LABEL2_FONT &FreeSansBold12pt7b    // Key label font 2
// Numeric display box size and location
#define DISP_X 1
#define DISP_Y 10
#define DISP_W 238
#define DISP_H 50
#define DISP_TSIZE 3
#define DISP_TCOLOR TFT_CYAN
// Number length, buffer for storing it and character index
#define NUM_LEN 12
char numberBuffer[NUM_LEN + 1] = "";
uint8_t numberIndex = 0;
// We have a status line for messages
#define STATUS_X 120 // Centred on this
#define STATUS_Y 65
// Create 15 keys for the keypad
char keyLabel[15][5] = {"New", "Del", "Send", "1", "2", "3", "4", "5", "6", "7", "8", "9", ".", "0", "#" };
uint16_t keyColor[15] = {TFT_RED, TFT_DARKGREY, TFT_DARKGREEN,
                         TFT_BLUE, TFT_BLUE, TFT_BLUE,
// Invoke the TFT_eSPI button class and create all the button objects
TFT_eSPI_Button key[15];
  // Use serial port
  // Initialise the TFT screen
  tft.init();
  // Set the rotation before we calibrate
  tft.setRotation(0);
  // Calibrate the touch screen and retrieve the scaling factors
  touch_calibrate();
  // Clear the screen
  tft.fillScreen(TFT_BLACK);
  // Draw keypad background
  tft.fillRect(0, 0, 240, 320, TFT_DARKGREY);
  // Draw number display area and frame
  tft.fillRect(DISP_X, DISP_Y, DISP_W, DISP_H, TFT_BLACK);
  tft.drawRect(DISP_X, DISP_Y, DISP_W, DISP_H, TFT_WHITE);
  // Draw keypad
  drawKeypad();
void loop(void) {
  uint16_t t_x = 0, t_y = 0; // To store the touch coordinates
  // Pressed will be set true is there is a valid touch on the screen
  bool pressed = tft.getTouch(&t_x, &t_y);
  // / Check if any key coordinate boxes contain the touch coordinates
  for (uint8_t b = 0; b < 15; b++) {
    if (pressed && key[b].contains(t_x, t_y)) {
      key[b].press(true);  // tell the button it is pressed
      key[b].press(false);  // tell the button it is NOT pressed
  // Check if any key has changed state
//    if (b < 3) tft.setFreeFont(LABEL1_FONT);
//    else tft.setFreeFont(LABEL2_FONT);
    if (key[b].justReleased()) key[b].drawButton();     // draw normal
    if (key[b].justPressed()) {
      key[b].drawButton(true);  // draw invert
      // if a numberpad button, append the relevant # to the numberBuffer
      if (b >= 3) {
        if (numberIndex < NUM_LEN) {
          numberBuffer[numberIndex] = keyLabel[b][0];
          numberIndex++;
          numberBuffer[numberIndex] = 0; // zero terminate
        status(""); // Clear the old status
      // Del button, so delete last char
      if (b == 1) {
        if (numberIndex > 0) {
          numberIndex--;
          numberBuffer[numberIndex] = 0;//' ';
      if (b == 2) {
        status("Sent value to serial port");
        Serial.println(numberBuffer);
      // we dont really check that the text field makes sense
      // just try to call
      if (b == 0) {
        status("Value cleared");
        numberIndex = 0; // Reset index to 0
        numberBuffer[numberIndex] = 0; // Place null in buffer
      // Update the number display field
      tft.setTextDatum(TL_DATUM);        // Use top left corner as text coord datum
      tft.setFreeFont(&FreeSans18pt7b);  // Choose a nicefont that fits box
      tft.setTextColor(DISP_TCOLOR);     // Set the font colour
      // Draw the string, the value returned is the width in pixels
      int xwidth = tft.drawString(numberBuffer, DISP_X + 4, DISP_Y + 12);
      // Now cover up the rest of the line up by drawing a black rectangle.  No flicker this way
      // but it will not work with italic or oblique fonts due to character overlap.
      tft.fillRect(DISP_X + 4 + xwidth, DISP_Y + 1, DISP_W - xwidth - 5, DISP_H - 2, TFT_BLACK);
      delay(10); // UI debouncing
void drawKeypad()
  // Draw the keys
  for (uint8_t row = 0; row < 5; row++) {
    for (uint8_t col = 0; col < 3; col++) {
      uint8_t b = col + row * 3;
      key[b].initButton(&tft, KEY_X + col * (KEY_W + KEY_SPACING_X),
                        KEY_Y + row * (KEY_H + KEY_SPACING_Y), // x, y, w, h, outline, fill, text
                        KEY_W, KEY_H, TFT_WHITE, keyColor[b], TFT_WHITE,
                        keyLabel[b], KEY_TEXTSIZE);
void touch_calibrate()
  uint16_t calData[5];
  uint8_t calDataOK = 0;
  // check file system exists
  if (!SPIFFS.begin()) {
    Serial.println("Formating file system");
    SPIFFS.format();
    SPIFFS.begin();
  // check if calibration file exists and size is correct
  if (SPIFFS.exists(CALIBRATION_FILE)) {
    if (REPEAT_CAL)
      // Delete if we want to re-calibrate
      SPIFFS.remove(CALIBRATION_FILE);
      File f = SPIFFS.open(CALIBRATION_FILE, "r");
      if (f) {
        if (f.readBytes((char *)calData, 14) == 14)
          calDataOK = 1;
        f.close();
  if (calDataOK && !REPEAT_CAL) {
    // calibration data valid
    tft.setTouch(calData);
    // data not valid so recalibrate
    tft.setCursor(20, 0);
    tft.setTextFont(2);
    tft.setTextSize(1);
    tft.setTextColor(TFT_WHITE, TFT_BLACK);
    tft.println("Touch corners as indicated");
    tft.setTextFont(1);
    tft.println();
    if (REPEAT_CAL) {
      tft.setTextColor(TFT_RED, TFT_BLACK);
      tft.println("Set REPEAT_CAL to false to stop this running again!");
    tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
    tft.setTextColor(TFT_GREEN, TFT_BLACK);
    tft.println("Calibration complete!");
    // store data
    File f = SPIFFS.open(CALIBRATION_FILE, "w");
    if (f) {
      f.write((const unsigned char *)calData, 14);
      f.close();
// Print something in the mini status bar
void status(const char *msg) {
  tft.setTextPadding(240);
  //tft.setCursor(STATUS_X, STATUS_Y);
  tft.setTextColor(TFT_WHITE, TFT_DARKGREY);
  tft.setTextFont(0);
  tft.setTextDatum(TC_DATUM);
  tft.setTextSize(1);
  tft.drawString(msg, STATUS_X, STATUS_Y);
When you update the display field, you are using the 18pt font. If you don't change it, when you redraw your keys, it will use that font vs. the one used in your drawKeypad() function.
Thanks.
what can be the reason the second picture shown that the font changed after button pressed?
The reason was described by @blh64 in your answer
Thanks.
yes, I just tested it.
The library has:
initButtonUL(TFT_eSPI *gfx, int16_t x1, int16_t y1,
  uint16_t w, uint16_t h, uint16_t outline, uint16_t fill,
  uint16_t textcolor, char *label, uint8_t textsize);
seems uint8_t textsize (KEY_TEXTSIZE) take only default font () ? does IDE has a default font? is it possible to set uint8_t textsize to use font like: 18pt font?
again, how to change the color of individual button or button-label? such like the font changes after pressed above?
The lines L125 and L126 in your code that you mentioned are related to font selection for the keypad buttons. They set different fonts for the labels of the buttons based on whether the button index is less than 3 or not. Specifically:
This code selects LABEL1_FONT for button labels when the button index (b) is less than 3 and LABEL2_FONT for the other buttons. LABEL1_FONT and LABEL2_FONT are defined in your code as different fonts. This is done to make the labels of the "New," "Del," and "Send" buttons have a different font from the numeric buttons.
If you want to remove these lines and keep the font consistent for all buttons, you can set a single font for all buttons. For example, you can set a common font for all buttons like this:
tft.setFreeFont(LABEL1_FONT);  // Choose a common font for all buttons
This will use LABEL1_FONT for all button labels, and you won't need to have the differentiation between fonts for different buttons.
Thank you.
actually, the original code work well without font changes whatever pressed or not.
the changes happened after I commented out that two line (4 lines in face).
my propose is to control the color of the individual button or button-label based on the pressed condition. let's say change the button color from BLUE to RED when that button is pressed.
is it possible to accomplish this?
you can modify the code in the loop function where the button states are checked. Specifically, when a button is justPressed, you can change its color. Here's an example of how to do it:
  key[b].drawButton(true);  // Change color when pressed
  // ... other code ...
You can add this code inside the for loop that checks the button states. This will change the button color to indicate that it's pressed. You can choose any color you prefer for the pressed state.
Remember to adjust the color to your liking in the key[b].drawButton(true); line.
Thank you for your time.
The original code used this function that set the buttons just change its color for a moment from BLUE to WHITE and then change back,
what I like to have is the color of the button or button-label changes after pressed till next time press happen.
because of the color of the buttons and button-labels all set in header, so may not be able to change them individually?
To make the color change persist until the next press, you need to store the state of each button and use that state to determine the color. Keep in mind this is based off of the last code I presented.
Here's an example of how you can modify the code:
// Define an array to store the state of each button
bool buttonPressed[NUM_BUTTONS] = {false};
// Inside your loop function
for (int b = 0; b < NUM_BUTTONS; b++) {
    // Change the button color when pressed
    // Set the button state to indicate it's pressed
    buttonPressed[b] = true;
    // If the button is not justPressed, set the color based on its state
    key[b].drawButton(buttonPressed[b]);
This code uses an array buttonPressed to store the state of each button. When a button is justPressed, it changes its color and updates its state. If it's not justPressed, it sets the color based on its state. This way, the color change will persist until the next press. Adjust the color in the key[b].drawButton calls to your liking.
