Hi to all.
I will start a project with xBee's, GPS module's and Arduino's.
My project design goal is:
- There are 5 xBee modules that are as TXs, and 1 xBee module as RX.
- Each TX will transmit an GPS coordinates to RX.
My questions are: - Is this system possible?
- How can I configure multiple transmitters and one receiver xBee?
- Each TX and RX must be connected one by one at a time. How can I configure that firstly the node 1 should sent to rx, then node 2 and so on. Or is this necessary or xBee's can handle it by hardware.
- I don't need to talk the nodes talks each other. Just one by one between TX and RX.
- My last and a absolutely necessary question is that, in each transmission, I could read the RSSI value from RX that corresponds of the each node. RX will be plugged to computer to store data. In other words, I want to record the data as:
Node 1, GPS coordinates, RSSI value
Node 2, GPS coordinates, RSSI value
Node 3, GPS coordinates, RSSI value
Node 4, GPS coordinates, RSSI value
Node 5, GPS coordinates, RSSI value
I will have series 2 xBees (because of 1 mile range)
Thanks for your answers from now on.
Have a great day.
Best regards...
