Absolute beginner question if else
Hello I am very confused with the if else statement in my code. Running the serial monitor I have correct reading on the monitor but the opposite of what I would think should be happening on the board / output.. Serial monitor shows high with switch not depressed , low with switch pressed ( I have pin 2 tied to 10k resistor that is hooked to 5v, Pin 2 is pulled low through a switch to ground when depressed). The serial monitor shows what I belive to be correct, (PIN 2, 5v = 1 Pin 2, 0.02 V = 0 . The LED light is OFF for 2 sendonds with a quick blink with the serial monitor showing 1. I would expect the LED on most of the time with the blink off breifly according to the code. Please help me understand as I am new and probably overlooking something really easy.
int Switch1 = 2;
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(Switch1, INPUT);
  Switch1 = digitalRead(2);
  Serial.println(Switch1);
  if (digitalRead(Switch1) == HIGH)  // Pin 2 is not pulled low
    digitalWrite(LED_BUILTIN, LOW);
    delay(100);
    digitalWrite(LED_BUILTIN, HIGH);
    delay(2000);
  } else  // If Pin is low  begin good pattern
    delay(2000);  // tooth 1
    delay(100);
    //set up for REPEAT
testing if else.ino (715 Bytes)
Thanks for using code tags for your post. You forgot to post your schematic. You posted in the wrong sub category.
This is not a good test sketch, because it has needless features. Write a simple sketch that only turns the LED on and off in response to the switch. Test that and make it work, then worry about blinking stuff.
e.g.
int Switch1 = 2;
Do you see the problem here?
int Switch1 = 2;
:slight_smile:
It works but why is it initialized to 2?
This, however, will not work, due to the same confusion of pin number and value:
I appreciate the response. However I am confused, I do not need to set a integer as my switch 1 wich is on PIN 2 ?
Follow step by step
int Switch1 = 2;
// here you set the value to 2. So far, so good
// but now you assign a different value to it:
// suppose input was HIGH, now Switch1 == HIGH == 1.
// now you are really doing
//  if (digitalRead(1) == HIGH)
Oh I think I am understanding better. I want to read the state of PIN 2 , however I was assigning a value to it. I am reworking the problem now. My goal is to be able to serial monitor the input pin 2 (high or low) and alse run the if else statement. Thank you for taking the time to try and help me.
so even messing with something very simple I can not get the led to change the pattern. Voltage on Pin 2 is high unless I press the button,!?
pinMode(2, INPUT);
pinMode(13, OUTPUT);
if (digitalRead(2 == HIGH)) {
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(100);
} else if (digitalRead(2 == LOW)) {
delay(100);
I think you must be in too great a hurry...
'2 == HIGH' ???? When will that ever be true?
Remember what your high school algebra teacher said about brackets? It means, "do me first".
If you get stuck at this level, consider comparing your code with official examples and reading the reference documentation on this site.
Try...
if (digitalRead(2) == HIGH)
If it's not HIGH it must be LOW, so just use...
Thank you for helping me clarify, I truly appreciate the time that you have taken. I have a weak understanding of code, but after a night's sleep and your clear explanation I see the error I made. I alsos remember from high school garbage in garbage out. such a simple and obvious mistake. I thank you once again!
  • Brian
Hey, you posted the code in the wrong sub-category.
I really have no idea what you are talking about, or why you are saying that.
That has also worked, so many times for me. Really, I'm not kidding.
