Accelerometer with a stepper motor?
Hello all. I'm attempting to use a Rebot accelerometer to trigger the use of a step motor using an Arduino Uno R3. The issue I'm currently running into is before any of the "meat and potatoes" of the accelerometer code is written, initializing it causes the step motor to cease working. The entirety of the code is as follows (much of it courtesy of Dan Thompson):
// Stepper Motor skecth for use with the EasyDriver v4.2 //
// Dan Thompson 2010
// Use this code at your own risk.
// For all the product details visit http://www.schmalzhaus.com/EasyDriver/
// For the full tutorial visit http://danthompsonsblog.blogspot.com/
////// ED_v4 Step Mode Chart //////
// MS1 MS2 Resolution //
// L L Full step (2 phase) //
// H L Half step //
// L H Quarter step //
// H H Eighth step //
#include <Wire.h> // Must include Wire library for I2C
#include <SFE_MMA8452Q.h> // Includes the SFE_MMA8452Q library
int DIR = 3; // PIN 3 = DIR
int STEP = 2; // PIN 2 = STEP
int MS1 = 13; // PIN 13 = MS
int MS2 = 9; // PIN 9 = MS2
int SLEEP = 12; // PIN 12 = SLP
MMA8452Q accel;
Serial.begin(9600); // open the serial connection at 9600bps
pinMode(DIR, OUTPUT); // set pin 3 to output
pinMode(STEP, OUTPUT); // set pin 2 to output
pinMode(MS1, OUTPUT); // set pin 13 to output
pinMode(MS2, OUTPUT); // set pin 9 to output
pinMode(SLEEP, OUTPUT); // set pin 12 to output
//accel.init(SCALE_4G); // initializing the accelerometer
int modeType = 4; // This number increases by multiple of 2 each through the while loop..
// ..to identify our step mode type.
while (modeType<=8){ // loops the following block of code 4 times before repeating .
digitalWrite(DIR, LOW); // Set the direction change LOW to HIGH to go in opposite direction
digitalWrite(MS1, MS1_MODE(modeType)); // Set state of MS1 based on the returned value from the MS1_MODE() switch statement.
digitalWrite(MS2, MS2_MODE(modeType)); // Set state of MS2 based on the returned value from the MS2_MODE() switch statement.
digitalWrite(SLEEP, HIGH); // Set the Sleep mode to AWAKE.
//accel.read();
//printCalculatedAccels();
int i = 0; // Set the counter variable.
while(i<(modeType*400)) // Iterate for 200, then 400, then 800, then 1600 steps.
// Then reset to 200 and start again.
digitalWrite(STEP, LOW); // This LOW to HIGH change is what creates the..
digitalWrite(STEP, HIGH); // .."Rising Edge" so the easydriver knows to when to step.
//delayMicroseconds(1600/modeType); // This delay time determines the speed of the stepper motor.
delayMicroseconds(1600);
// Delay shortens from 1600 to 800 to 400 to 200 then resets
i++;
modeType = modeType * 2; // Multiply the current modeType value by 2 and make the result the new value for modeType.
// This will make the modeType variable count 1,2,4,8 each time we pass though the while loop.
//delay(500);
// digitalWrite(SLEEP, LOW); // switch off the power to stepper
// Serial.print("SLEEPING..");
//delay(500);
//Serial.print("z");
//delay(500);
//delay(500);
//delay(500);
//Serial.println("");
//digitalWrite(SLEEP, HIGH);
//Serial.println("AWAKE!!!"); // Switch on the power to stepper
//delay(500);
int MS1_MODE(int MS1_StepMode){ // A function that returns a High or Low state number for MS1 pin
switch(MS1_StepMode){ // Switch statement for changing the MS1 pin state
// Different input states allowed are 1,2,4 or 8
case 1:
MS1_StepMode = 0;
Serial.println("Step Mode is Full...");
case 2:
MS1_StepMode = 1;
Serial.println("Step Mode is Half...");
case 4:
MS1_StepMode = 0;
Serial.println("Step Mode is Quarter...");
case 8:
MS1_StepMode = 1;
Serial.println("Step Mode is Eighth...");
return MS1_StepMode;
int MS2_MODE(int MS2_StepMode){ // A function that returns a High or Low state number for MS2 pin
switch(MS2_StepMode){ // Switch statement for changing the MS2 pin state
case 1:
MS2_StepMode = 0;
case 2:
MS2_StepMode = 0;
case 4:
MS2_StepMode = 1;
case 8:
MS2_StepMode = 1;
return MS2_StepMode;
// This function demonstrates how to use the accel.cx, accel.cy,
// and accel.cz variables.
// Before using these variables you must call the accel.read()
// function!
void printCalculatedAccels()
Serial.print(accel.cx, 3);
Serial.print("\t");
Serial.print(accel.cy, 3);
Serial.print("\t");
Serial.print(accel.cz, 3);
Serial.print("\t");
Looking in the "void setup" area, you can see the accelerometer initialization is commented out; when run with this in, the motor doesn't work at all. Any ideas? Thank you guys, I'm rather new
Can you provide a link to that MMA8452Q library - the exact version you are using?
Certainly!
There may be a clash between your two libraries. This simple stepper code will work with an Easydriver and does not use any library. See also stepper motor basics.
...R
The accelerometer library requires the I2C address to be passed in the constructor,
which you haven't done.
How would I pass it? Sorry for asking if it's obvious; I've only ued the accelerometer with the Redbot unit and never had to do it before
