Hi I have a stepper motor set up with an easy driver, I have no problem setting it up and running the few sample programs I have found, but they don't do what I need it to do which is quite simple I'm sure but I just hit a brick wall trying to work it out using Accelstepper library, What I want to do is press a button once, the motor travels forward a set distance then stops then delay for 10 seconds then go back to the start position ,
Something like:
#define IDLE 0
#define MOVING 1
#define DELAYING 2
#define DISTANCE ??? // steps to move
#define button_pin ??
unsigned long when = 0L ;
byte state = IDLE ;
AccelStepper stepper (????) ; // pins and mode
void setup ()
stepper.setSpeed (???) ; // top speed, steps/sec
stepper.setAcceleration (???) ; // top acceleration steps/sec/sec
void loop ()
stepper.run () ; // progress the stepper. This must be called regularly and often
// statemachine to progress the states
switch (state)
case IDLE:
if (digitalRead (button_pin) == LOW)
stepper.moveTo (DISTANCE) ; // AccelStepper handles the rest, so long as you call run() often
state = MOVING ;
break ;
case MOVING:
if (stepper.currentPosition () == DISTANCE)
state = DELAYING ;
when = millis () ;
break ;
case DELAYING:
if (millis () - when >= 10000)
stepper.moveTo (0) ; // start moving back
state = IDLE ;
Thank you Mark I could kiss you all over, it works just as I wanted, I would love to understand it fully , perhaps one day if you have the time you could comment the program for myself and others who will like the program, thanks again .
I'd recommend going to AccelStepper.h file itself and reading all the comments...
