Hello everyone. I today got my hands on my first Arduino, an Illuminato. I have been fiddling with the basics, and have noticed that the time related functions seem to be a little screwy. Using both delay() and millis() to blink the pin 13 LED every half second, the results are... imperfect. I'm not in a position to post video, but I will explain as best I can.
The millis() sketch is this one;
int ledPin = 13; // LED connected to digital pin 13
int value = LOW; // previous value of the LED
long previousMillis = 0; // will store last time LED was updated
long interval = 500; // interval at which to blink (milliseconds)
pinMode(ledPin, OUTPUT); // sets the digital pin as output
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, is the difference
// between the current time and last time we blinked the LED bigger than
// the interval at which we want to blink the LED.
if (millis() - previousMillis > interval) {
previousMillis = millis(); // remember the last time we blinked the LED
// if the LED is off turn it on and vice-versa.
if (value == LOW)
value = HIGH;
value = LOW;
digitalWrite(ledPin, value);
This sketch blinks the LED in a fashion that is very close to perfect. The on/off intervals are very regular for the first 14 or so blinks, and then the off period is noticeably short, although not severe. Repeat.
The delay() sketch is this one;
int LEDPin = 13;
pinMode(LEDPin, OUTPUT);
digitalWrite(LEDPin, HIGH);
digitalWrite(LEDPin, LOW);
This sketch is much more noticeably wrong. The on/off periods are regular until the 5th HIGH state, which is then significantly shorter than 500ms. Repeat. So to rephrase, every 5th visibly on state of the LED is obviously short. Goes on like that forever.
So my question is, is this to be expected? I don't know what the accuracy of the hardware is, or what is considered normal. Just curious, thanks! ![]()
