trying to get accurate 100Hz from Arduino, but having a bit of trouble.
So my first approach was to set pin high, wait 5ms, set it low and wait another 5ms.
The problem is, the resulting frequency is a actually a bit higher (102,4) - according to various frequency counters.
Why is that? If anything, I would actually expect it to be slower (didn't counting on the instruction time for setting the registers).
Anyone has a solution?
Try using micros() instead.I see better results when I code clocks that way.
If you use blink without delay style coding, will help also.
As for the speed you see, no way to tell without seeing your code.
// declare variable names, pinModes, etc.
void loop(){
currentMicros = micros();
if ( (currentMicros - nextMicro) >= interval){
PIND = 0x00010000; // toggle D4 - writing 1 to PINx toggles a bit
nextMicro = nextMicro + interval; // time to next flip
// do other stuff while waiting
} // end loop
The clock speed may not be precise and temperature will effect it. The time to execute functions (like digitalWrite) may also need taking into consideration.
Another tip is to disable interrupts if possible (you would need to use micros for delay then) and put pin on/off code in it's own while loop as when the normal loop() ends I think it goes of and does other things before entering loop again so you cannot rely on it for exact timing.
What degree of accuracy do you want? You may need to choose an
Arduino with a quartz crystal based clock (not the current Uno's for example,
although they can have their ceramic resonator replaced with a crystal).
Timer1 can be configured to a wide range of frequencies and duty cycles
on pin 9 or 10 (on the Uno).
Hi, mrkva what part of the world do you come from, if you have 50Hz AC mains then you can produce a 100Hz output from that.
You haven't said if the arduino is doing anything else apart from producing the 100Hz, if it is doing anything else then that will also effect to the timing, so a mains based 100Hz would be easier.
I also think there are IC's which with a crystal can give you 50Hz/60Hz.
That's it! Thanks. I didn't know which direction that 20000-1 should go. (or was it that -1 that should change?) It will be easy now with that clue. And yes, control will be a pot to simulate crank speed changes and another pot simulates throttle position changes. The bike has CAN bus, and this will be an interface.
Then using map() and a 2D array() I look up values to apply gain multipliers, just like fuel maps on the bike.
Note that map() uses integer math and truncates values. Might cause some side effects, but I do not expect serious ones as you scale down quite some factor.
I too would vote on you just simply using the tone() library.
Keep in mind that the accuracy (which you have to define for your application) of any method given in this posting thread is based on the assumption that your crystal is oscillating at exactly 16,000,000 Hz, which will not be the case as there is always some variation in any crystal/circuit.
The current rev3 mega and uno boards don't even use a quartz crystal but rather a ceramic resonator, so frequency accuracy will have even a larger variation.
Exactly. I count on the the integer math in map(). The algorithm I made uses attachInterrupt(), and counts each event for 200 milliseconds. If count is under 10, the crank speed is not high enough. Restart the count.
For 10 events, subtract 10 and get the zero position for the y axis, etc.
And then I do the same for the voltage representing 1/2 throttle, say (2.5 volts - 2.5) give the zero for x in the array.
This will be able to meter in things like, alcohol injection or Nitrous Oxide, or even a supercharger
to dial that against fueling tables on a dynamometer to make best power.
Hi, mrkva ,sorry it seems this thread has been HIJACKED....
Have you had any success with your project.
Tom........
PS, Come on guys, I know both problems are to do with timing, but different implementations, if I was mrkva I'd have a good reason to be completely disillusioned (could have used stronger word). Probably is because he has gone quiet, although its only been nearly 24hours.
