Hey, I've been trying to communicate with the AD5791 DAC using the Arduino duemilanove, but all attempts fail to change the voltage output on the DAC...
I know this a long shot, but I was wondering if anyone had done this before and could help...
-DataSheet for DAC is at: AD5791 Datasheet and Product Info | Analog Devices
Code:
// DAC Data Transfer
#define DATAOUT 11 // DIN
#define SPICLOCK 13 // SCLK
long AD5791_DATA_REGISTER = 0x100000; //data register mask
int syncPin = 10;
long dac_code = 0x000CC0;
long data = AD5791_DATA_REGISTER | dac_code;
// Setup SPI Interface code BEGIN ///////////////////////////////////////////
byte clr;
pinMode(DATAOUT, OUTPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(syncPin,OUTPUT);
digitalWrite(syncPin,HIGH); //disable device
//The SPI control register (SPCR) has 8 bits, each of which control a particular SPI setting.
// SPCR
// | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |0000000000000000000
// | SPIE | SPE | DORD | MSTR | CPOL | CPHA | SPR1 | SPR0 |
// SPIE - Enables the SPI interrupt when 1
// SPE - Enables the SPI when 1
// DORD - Sends data least Significant Bit First when 1, most Significant Bit first when 0
// MSTR - Sets the Arduino in master mode when 1, slave mode when 0
// CPOL - Sets the data clock to be idle when high if set to 1, idle when low if set to 0
// CPHA - Samples data on the falling edge of the data clock when 1, rising edge when 0'
// SPR1 and SPR0 - Sets the SPI speed, 00 is fastest (4MHz) 11 is slowest (250KHz)
SPCR = B01010100;
clr=SPSR;
clr=SPDR;
delay(10);
//Write to Control Register
/* digitalWrite(syncPin,LOW);
spi_transfer(0x20);
spi_transfer(0x00);
spi_transfer(0x20);
//So now we can write a function SetVoltage(int) that will change the DAC output.
// DAC SPI Interface
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))){}; // Wait the end of the transmission
return SPDR; // return the received byte
// Set the voltage on the 20-bit DAC
byte SetVoltage()
//Read from Control Register/
/* spi_transfer(0x00);
spi_transfer(B10100000);
spi_transfer(B00000000);
digitalWrite(syncPin,HIGH); //release chip, signal end transfer
spi_transfer(0x00);
spi_transfer(0x00);
spi_transfer(data>>16);
spi_transfer(data>>8);
spi_transfer(data);
spi_transfer(0x00);
SetVoltage();
** I have commented out my attempts at reading/writing from/to the DAC's control register since no data is returned on the MISO line**
**Thanks for any and all suggestions/comments
