AD620 amplifier
Hi i am looking For AD620 library , please any one can share it
thank you very much
There is no library.
You just use analogRead() to read the AD620 output voltage
i made code to read voltage from strain gauge but it is not showing please can you check this
What, exactly, do you mean by that?
i have two codes in one arduino , one code is to control 4 linear actuators , other code is to get voltage from strain gauge during motion , the seriall monitoe is emptry from voltage reading
Show your entire code using code tags
Is your serial monitor baud rate set to 9600?
i am not sure, how can i do this
It's at the bottom or on the right of the serial monitor window.
yes it is set 9600 , if we have two codes in one arduino , can w use void1 , loop1 to distinguish from each other?
No!
oh i am doing this mistake :frowning: :frowning: :frowning: , please need our guide how should i do when i have one arduino
You still have not posted your complete code
