AD8232 Heart rate monitor
Hi:
Im using the AD8232 board distributed by sparkfun. It comes with a handy tutorial to test it:
https://learn.sparkfun.com/tutorials/ad8232-heart-rate-monitor-hookup-guide
Unfortnately, I dont have an arduino mini, I have an arduino UNO. When everything is connected as instructed, only noise is shown on the Process Graph.
Recently (by mistake) I discovered that touching the arduino uno USB metallic case solves the problem!
Am I missing some extra connection by using arduino UNO?
Thanks in advance
Check your ground (GND) connection
Using the Mini should not make any difference.
rogerClark:
Do you mean using the UNO?
Sorry,
I missread your posting. Yes the Uno should be fine.
It just sounds like the GND connection, or possibly something else is loose
If you have a volt meter, check the supply voltage to the module.
Gilgamesh90:
Hi:
Thanks in advance
I have the same problem, could you please tell me about how you solved it?
Having the same problem-( Processing demo sketch didn't work until I delete "void serialEvent (Serial myPort) {" and instead of it included the whole code into the draw loop. But I still can't understand what's wrong. Here is a screenshot of the signal I have. (First part is improper grounding and the period of the second part is about 1,5 sec with an equal pause). Any ideas how to deal with it?-)
Having the same problem-( Processing demo sketch didn't work until I delete "void serialEvent (Serial myPort) {" and instead of it included the whole code into the draw loop. But I still can't understand what's wrong. Here is a screenshot of the signal I have. (First part is improper grounding and the period of the second part is about 1,5 sec with an equal pause). Any ideas how to deal with it?-) please help me ,i have 1 day to submit project ,kindly help me
