Adafruit 3G Cellular et GPS Breakout
Bonjour, je poste ce message puisque j'ai un problème avec ma FONA 3G (SIM5320E).
Mon but est de réaliser une localisation GPS toutes les 15 secondes. Donc j'ai une antenne GPS active.
Plusieurs programmes sont donnés par Adafruit pour tester la carte. Malheureusement pour moi, je n'arrive pas à les faire fonctionner. Je vous mets celui que j'utilise :
#include "Adafruit_FONA.h"
// standard pins for the shield, adjust as necessary
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
//  HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Have a FONA 3G? use this object type instead
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
  while (! Serial);
  Serial.println(F("Adafruit FONA 808 & 3G GPS demo"));
  Serial.println(F("Initializing FONA... (May take a few seconds)"));
  fonaSerial->begin(4800);
  if (! fona.begin(*fonaSerial)) {
    Serial.println(F("Couldn't find FONA"));
    while(1);
  Serial.println(F("FONA is OK"));
  // Try to enable GPRS
  Serial.println(F("Enabling GPS..."));
  fona.enableGPS(true);
  delay(2000);
  float latitude, longitude, speed_kph, heading, speed_mph, altitude;
  // if you ask for an altitude reading, getGPS will return false if there isn't a 3D fix
  boolean gps_success = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
  if (gps_success) {
    Serial.print("GPS lat:");
    Serial.println(latitude, 6);
    Serial.print("GPS long:");
    Serial.println(longitude, 6);
    Serial.print("GPS speed KPH:");
    Serial.println(speed_kph);
    Serial.print("GPS speed MPH:");
    Serial.println(speed_mph);
    Serial.print("GPS heading:");
    Serial.println(heading);
    Serial.print("GPS altitude:");
    Serial.println(altitude);
    Serial.println("Waiting for FONA GPS 3D fix...");
  // Fona 3G doesnt have GPRSlocation :/
  if ((fona.type() == FONA3G_A) || (fona.type() == FONA3G_E))
    return;
  // Check for network, then GPRS
  Serial.println(F("Checking for Cell network..."));
  if (fona.getNetworkStatus() == 1) {
    // network & GPRS? Great! Print out the GSM location to compare
    boolean gsmloc_success = fona.getGSMLoc(&latitude, &longitude);
    if (gsmloc_success) {
      Serial.print("GSMLoc lat:");
      Serial.print("GSMLoc long:");
      Serial.println("GSM location failed...");
      Serial.println(F("Disabling GPRS"));
      fona.enableGPRS(false);
      Serial.println(F("Enabling GPRS"));
      if (!fona.enableGPRS(true)) {
        Serial.println(F("Failed to turn GPRS on"));
Ce qui me donne sur le moniteur série la deuxième photo ci-jointe.
Je n'arrive pas à trouver le problème. Merci d'avance :slight_smile:
Vous avez bien la version Européenne ?
Montrez une vraie photo de votre câblage et virez tout ce qui ne sert à rien dans le test de la carte comme le moteur ou détecteur ultrason
Bonjour
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST); <<----------!!!
Si la carte est bien une FONA_3G il faut commencer par suivre les consignes d'Adafruit et utiliser le second objet , celui qui correspond la la carte 3G
(Le code fourni s'adresse à plusieurs cartes , c'est à l'utilisateur de faire l'adaptation)
