Adafruit ADXL345
I am using this Sparkfun ADXL345 library (ADXL345 Hookup Guide - SparkFun Learn) for SPI communication between my Adafruit ADXL345 and Arduino. Specifically I am using the "Sparkfun_ADXL345_Example." I chose to use SPI Communication and set my range to 2g.
When lying the ADXL345 flat on a table I get -1s as my value. When I push down on the ADXL sensor (only in the z-direction) I start getting values such as -13365. By any chance, does someone know what these values mean? Did I set something up wrong? Or does the Sparkfun ADXL345 library not work on the Adafruit ADXL345 accelerometer?
Thanks
Pushing down on the sensor:
Code:
#include <SparkFun_ADXL345.h>
/*********** COMMUNICATION SELECTION ***********/
/*    Comment Out The One You Are Not Using    */
ADXL345 adxl = ADXL345(10);           // Use when you want to use Hardware SPI, ADXL345(CS_PIN);
//ADXL345 adxl = ADXL345();             // Use when you need I2C
/****************** VARIABLES ******************/
int AccelMinX = 0;
int AccelMaxX = 0;
int AccelMinY = 0;
int AccelMaxY = 0;
int AccelMinZ = 0;
int AccelMaxZ = 0;
int accX = 0;
int accY = 0;
int accZ = 0;
int pitch = 0;
int roll = 0;
/************** DEFINED VARIABLES **************/
#define offsetX   0       // OFFSET values
#define offsetY   0
#define offsetZ   0
#define gainX     1     // GAIN factors
#define gainY     1
#define gainZ     1
/******************** SETUP ********************/
/*          Configure ADXL345 Settings         */
Serial.begin(9600);                 // Start the serial terminal
Serial.println("SparkFun ADXL345 Accelerometer Breakout Calibration");
adxl.powerOn();                     // Power on the ADXL345
adxl.setRangeSetting(2);           // Give the range settings
                                    // Accepted values are 2g, 4g, 8g or 16g
                                    // Higher Values = Wider Measurement Range
                                    // Lower Values = Greater Sensitivity
adxl.setSpiBit(0);                // Configure the device to be in 4 wire SPI mode when set to '0' or 3 wire SPI mode when set to 1
                                    // It is set to 1 by Default.
                                    // SPI pins on the ATMega328 as reference in SPI Library are 11, 12, and 13
/****************** MAIN CODE ******************/
/*  Accelerometer Readings and Min/Max Values  */
Serial.println("Send any character to display values.");
while (!Serial.available()){}       // Waiting for character to be sent to Serial
// Get the Accelerometer Readings
int x,y,z;                          // init variables hold results
adxl.readAccel(&x, &y, &z);         // Read the accelerometer values and store them in variables declared above x,y,z
if(x < AccelMinX) AccelMinX = x;
if(x > AccelMaxX) AccelMaxX = x;
if(y < AccelMinY) AccelMinY = y;
if(y > AccelMaxY) AccelMaxY = y;
if(z < AccelMinZ) AccelMinZ = z;
if(z > AccelMaxZ) AccelMaxZ = z;
Serial.print("Accel Minimums: "); Serial.print(AccelMinX); Serial.print("  ");Serial.print(AccelMinY); Serial.print("  "); Serial.print(AccelMinZ); Serial.println();
Serial.print("Accel Maximums: "); Serial.print(AccelMaxX); Serial.print("  ");Serial.print(AccelMaxY); Serial.print("  "); Serial.print(AccelMaxZ); Serial.println();
/* Note: Must perform offset and gain calculations prior to seeing updated results
/  Refer to SparkFun ADXL345 Hook Up Guide: https://learn.sparkfun.com/tutorials/adxl345-hookup-guide
/  offsetAxis = 0.5 * (Acel+1g + Accel-1g)
/  gainAxis = 0.5 * ((Acel+1g - Accel-1g)/1g) */
// UNCOMMENT SECTION TO VIEW NEW VALUES
//accX = (x - offsetX)/gainX;         // Calculating New Values for X, Y and Z
//accY = (y - offsetY)/gainY;
//accZ = (z - offsetZ)/gainZ;
//Serial.print("New Calibrated Values: "); Serial.print(accX); Serial.print("  "); Serial.print(accY); Serial.print("  "); Serial.print(accZ);
//Serial.println();
while (Serial.available())
    Serial.read();                    // Clear buffer
Sounds like you have one or more intermittent or bad connections. Pressing on the sensor is not a particularly good idea as you may bend the PCB and stress the IC. The sensor detects acceleration, including that due to Earth's gravity, but not applied force.
A good test of sensor function is to hold it still, with any of the three axes vertical. It should report +/-1 g acceleration along the vertical axis and approximately 0 g along any horizontal axis.
Start with a test program that simply prints raw values, rather than a collection of minimum/maximum values.
Thanks for the tip. I will double check all my connections. I realized that in my screenshot I was actually running the following code and not the calibration code in the original post. The values I was reading was the raw values. Sorry for the confusion.
 *  SparkFun_ADXL345_Example
 *  Triple Axis Accelerometer Breakout - ADXL345
 *  Hook Up Guide Example
 *  Utilizing Sparkfun's ADXL345 Library
 *  Bildr ADXL345 source file modified to support
 *  both I2C and SPI Communication
 *  E.Robert @ SparkFun Electronics
 *  Created: Jul 13, 2016
 *  Updated: Sep 06, 2016
 *  Development Environment Specifics:
 *  Arduino 1.6.11
 *  Hardware Specifications:
 *  SparkFun ADXL345
 *  Arduino Uno
#include <SparkFun_ADXL345.h>         // SparkFun ADXL345 Library
ADXL345 adxl = ADXL345(10);           // USE FOR SPI COMMUNICATION, ADXL345(CS_PIN);
//ADXL345 adxl = ADXL345();             // USE FOR I2C COMMUNICATION
/****************** INTERRUPT ******************/
/*      Uncomment If Attaching Interrupt       */
//int interruptPin = 2;                 // Setup pin 2 to be the interrupt pin (for most Arduino Boards)
void setup(){
  Serial.println("SparkFun ADXL345 Accelerometer Hook Up Guide Example");
                                      // Default: Set to 1
                                      // SPI pins on the ATMega328: 11, 12 and 13 as reference in SPI Library
  adxl.setActivityXYZ(1, 0, 0);       // Set to activate movement detection in the axes "adxl.setActivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setActivityThreshold(75);      // 62.5mg per increment   // Set activity   // Inactivity thresholds (0-255)
  adxl.setInactivityXYZ(1, 0, 0);     // Set to detect inactivity in all the axes "adxl.setInactivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setInactivityThreshold(75);    // 62.5mg per increment   // Set inactivity // Inactivity thresholds (0-255)
  adxl.setTimeInactivity(10);         // How many seconds of no activity is inactive?
  adxl.setTapDetectionOnXYZ(0, 0, 1); // Detect taps in the directions turned ON "adxl.setTapDetectionOnX(X, Y, Z);" (1 == ON, 0 == OFF)
  // Set values for what is considered a TAP and what is a DOUBLE TAP (0-255)
  adxl.setTapThreshold(50);           // 62.5 mg per increment
  adxl.setTapDuration(15);            // 625 μs per increment
  adxl.setDoubleTapLatency(80);       // 1.25 ms per increment
  adxl.setDoubleTapWindow(200);       // 1.25 ms per increment
  // Set values for what is considered FREE FALL (0-255)
  adxl.setFreeFallThreshold(7);       // (5 - 9) recommended - 62.5mg per increment
  adxl.setFreeFallDuration(30);       // (20 - 70) recommended - 5ms per increment
  // Setting all interupts to take place on INT1 pin
  //adxl.setImportantInterruptMapping(1, 1, 1, 1, 1);     // Sets "adxl.setEveryInterruptMapping(single tap, double tap, free fall, activity, inactivity);"
                                                        // Accepts only 1 or 2 values for pins INT1 and INT2. This chooses the pin on the ADXL345 to use for Interrupts.
                                                        // This library may have a problem using INT2 pin. Default to INT1 pin.
  // Turn on Interrupts for each mode (1 == ON, 0 == OFF)
  adxl.InactivityINT(1);
  adxl.ActivityINT(1);
  adxl.FreeFallINT(1);
  adxl.doubleTapINT(1);
  adxl.singleTapINT(1);
//attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   // Attach Interrupt
/*     Accelerometer Readings and Interrupt    */
void loop(){
  // Accelerometer Readings
  int x,y,z;
  // Output Results to Serial
  /* UNCOMMENT TO VIEW X Y Z ACCELEROMETER VALUES */
  delay(100);
  Serial.print(x);
  Serial.print(", ");
  Serial.print(y);
  Serial.print(", ");
  Serial.println(z);
  ADXL_ISR();
  // You may also choose to avoid using interrupts and simply run the functions within ADXL_ISR();
  //  and place it within the loop instead.
  // This may come in handy when it doesn't matter when the action occurs.
/********************* ISR *********************/
/* Look for Interrupts and Triggered Action    */
void ADXL_ISR() {
  // getInterruptSource clears all triggered actions after returning value
  // Do not call again until you need to recheck for triggered actions
  byte interrupts = adxl.getInterruptSource();
//  // Free Fall Detection
//  if(adxl.triggered(interrupts, ADXL345_FREE_FALL)){
//    Serial.println("*** FREE FALL ***");
//    //add code here to do when free fall is sensed
//  // Inactivity
//  if(adxl.triggered(interrupts, ADXL345_INACTIVITY)){
//    Serial.println("*** INACTIVITY ***");
//     //add code here to do when inactivity is sensed
//  // Activity
//  if(adxl.triggered(interrupts, ADXL345_ACTIVITY)){
//    Serial.println("*** ACTIVITY ***");
//     //add code here to do when activity is sensed
//  // Double Tap Detection
//  if(adxl.triggered(interrupts, ADXL345_DOUBLE_TAP)){
//    Serial.println("*** DOUBLE TAP ***");
//     //add code here to do when a 2X tap is sensed
//  // Tap Detection
//  if(adxl.triggered(interrupts, ADXL345_SINGLE_TAP)){
//    Serial.println("*** TAP ***");
//     //add code here to do when a tap is sensed
Those raw numbers don't make sense, either. Please triple check that your wiring is correct for the SPI interface, and that all of the wires have the expected continuity. A multimeter is invaluable for this.
The Sparkfun test code you most recently posted does not test to see whether the accelerometer was properly recognized, so look through the library to see if there is an example that does so.
Or switch to the I2C interface and run the I2C Address Scanner program to check for a device with the correct address.
Will do, thanks for the help. I am looking to use multiple Adafruit ADXL345 accelerometers so unfortunately I2C won't work.
I2C works just fine with multiple ADXL345.
Simply use I/O pins to set the sensor Alt Address pins so that only one sensor is addressed at a time.
Switched to I2C and got it working great!
