I have a voltage read for battery but I would like to increase resolution by removing the bottom half of the battery voltage. Basically change the ground point. Is this possible?
Battery is 2 cell lipo so approx 6 - 8.6v
Is it possible to read only 5 - 8.6v and ignore the bottom? The voltage divider changes the reading to 5v max.
This way instead of using only 1/3 of the ADC resolution I should get closer to 2/3 the range to empty.
Can I tell analog read to say read from 2.5 to 5v and translate that into 0-1023?
If the Arduino is powered independently from that battery you could connect the Arduino GND to your battery's mid point, making that your GND reference.
The biggest problem may be that this requires a voltage divider, which by nature leaks power. This may be an issue for battery powered projects, if it's a small battery that has to last long.
Anyway, you merely double your resolution. No great gain. If that is make or break get a higher resolution ADC such as the ADS1115.
You need a voltage divider to bring down the battery voltage to something you can read (best is to take it down to 1.1V and then use the internal reference for stability).
Then you're reading your 7V battery at 7 mV steps using the 10-bit ADC. Is that really not good enough? In other words: does it really matter if you see your battery voltage at 6.445 V or 6.452 V, when the actual voltage is 6.449 V? For most practical uses it's good enough to display this as 6.45 V.
