ADC, TTL and PCINT - what's the difference?
Quick couple of questions on this.
On Mega Rev3 board, pins ADC[8..15] (PCINT[16..23]), would like to configure them to read status of equipment (put to 5) error TTL signals. Can these pins be programmed to do that?
thanks
kris123berkeley:
thanks
Did you try; they are digital IO pins as well as analog input pins.
How does your question relate to the difference between INT and PCINT?
@kris123berkeley
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Yes.
Lookup: pinMode() and digitalRead() functions.
Have a common ground between the mega and the device you are connecting to.
6v6gt:
Yes.
The OP doesn't give much details about the "equipment" status that needs to be monitored.
I generally go for opto-isolation between arduino and other equipment in most cases.
