hi..
sorry for my english..
i have project with read serial from arduino
example : the incoming data string 12345678, and i want the data to be 123456,78.
so how i can add comma at string in 2 last digit.
thank you..
Are you receiving this data over a SUART Port? If yes, then wait until 8 characters are accumulated in the buffer. After that read 6 characters (one-by-one), save/print them and then insert a comma (,) and then read, save/print the last two characters. The sample codes:
int i;
byte n = SUART.available ();
if(n == 8)
for(i = 0; i < 6; i++)
myData[i] = SUAT.read();
Serial.print(myData[i]);
myData[i++] = ',';
Serial.print(',');
//--- perform two more read, save, print
// operations
Convert the string into a long and divide by 100.
Sorry. A true double would be needed.
Is it comma or period? (123456,78)
thx for reply..
sorry i mean 123456.78
so the incoming serial always different length.
so i just want to add (.) in before 2 last digit
thx for reply bro.
i haved try this method but if divide 100 the result is not same because round.
Corrected/edited the reply.
maybe something like this..
//buffer for formatted string..
char result[80];
char* c = "123\n";
Serial.println(c);
AddDecimal(c);
Serial.println(result);
void AddDecimal(const char* inStr) {
int len = strlen(inStr);
int pos = len - 3;
memset(result,0,sizeof(result));//empty//
if (len<3) return;//nothing to do..
for (int i = 0; i < len; i++) {
if (i < pos) {
result[i] = inStr[i];
if (i == pos) {
result[i] = '.';
result[i + 1] = inStr[i];
doesn't care about data just adds the "." to it..
good luck.. ~q
divide by 100
print the comma
print % 100
You would get better advices if you just make a short demo sketch which shows how you receive the data currently and what you want to do with that data.
A full sketch with globals, a setup and loop.
The algorithm needs to start with the end of the array of characters and then back up two characters.
As a result, in order to know where and when to insert the '.', the algorithm must read all the characters first.
Simply checking for the position index being equal to (known length -2) and inserting the '.' could solve it
but would mean checking the position and doing the math every time the serial port is read by the code.
Alternatively:
Borrowing from GolanMostafa's tidy example, with modifications.
int i;
int n = (int) SUART.available (); // I live without classes, not sure of type returned, but want to work with ints
for(i = 0; i < n; i++)
// when the serial input read completes, i and n have the same value (i is the current position, n is one past last).
// my rule is that you have to send a string with at least 3 digits before I will insert a '.' into the middle of it.
// when moving the elements of an array away from [0], you must move the each [element] to [element+1] first.
// my buffer for this example is infinite length but we still care that our indices reach valid bytes only.
// when i is 2, two characters have been entered. logic similar to this could also insert a '0' in front of these cases.
if (i >= 3)
myData[i+0] = myData[i-1]; // copy [i-1] before [i-2] overwrites it
myData[i-1] = myData[i-2]; // copy [i-2] before '.' overwrites it
myData[i-2] = '.'; // insert the decimal point
n++;
// once again deal with the serial port in a very focused manner
ShockedOldDad
