Recently had no other choice but to start getting into Arduino. It always has been hard to learn since programming reminds too much of a dry mathematical abstractions.
Have been studying some programming in university to no avail. Disinterested sleepy or erratic teachers didn't help either.
Is there any way to add a buzzer code to this turn signal program? The sound should imitate ticking flasher relay when the turn signal buttons are pressed.
Adding some turn signal off delay and dashboard brake light indication to make sure everything is working during the operation is the next thing on the list.
So far have only successfully uploaded the program before soldering everything together so not very familiar with the intricacies of every operational aspect yet.
Your topic was MOVED to its current forum category as it is more suitable than the original as it has nothing to do with the response to Covid
Eventually decided to use some simple current alarm buzzer on power input with a single transistor and 1.5 ohm shunt (0.5W resistor) instead, since that might be the only way to be sure that everything is operational while riding on a bicycle ( happens to make a different beep for turn signals (chirp) and brakes (click)). Simple three position miniature slide switch also might be less tiring to operate than a pushbuttons (closer to standard motorcycle switch).
Currently not feeling confident enough to mess with the code appart from changing some parameters.
Interesting but what is the question as you have a solution but not a problem. Post a schematic, not a frizzy picture and links to "Technical" information on your hardware devices. Posting the code helps us to understand it as we cannot see our system or screen. FYY your google drive is not working for me so I see nothing posted there.
