### Describe the problem
I've installed the new official release 2.0.0… (on Windows 10 and Linux Ubuntu 20.04 LTS) from archive.
When launching it, I got this windows and nothing happen.
#### First step:
Log from the console are (Linux):
```text
Starting backend process. PID: 667034
[667055:0915/102131.293101:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///local/home/<username>/.theia'
root INFO Backend Object.initialize: 7.5 ms [Finished 1.253 s after backend start]
root INFO Backend Object.configure: 5.8 ms [Finished 1.253 s after backend start]
root INFO Backend MessagingContribution.onStart: 2.9 ms [Finished 1.253 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.7 ms [Finished 1.320 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 1.320 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.4 ms [Finished 1.321 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 67.7 ms [Finished 1.321 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.6 ms [Finished 1.321 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.7 ms [Finished 1.323 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.8 ms [Finished 1.323 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 1.4 ms [Finished 1.325 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.7 ms [Finished 1.326 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.6 ms [Finished 1.327 s after backend start]
root INFO Backend NodeFileUploadService.configure: 3.0 ms [Finished 1.328 s after backend start]
daemon INFO Starting daemon from /local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/arduino-ide-extension/build/arduino-cli...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 1.6 ms [Finished 1.330 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.8 ms [Finished 1.330 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.6 ms [Finished 1.332 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 1.332 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.333 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.334 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 0.5 ms [Finished 1.334 s after backend start]
root INFO Theia app listening on http://localhost:40205.
root INFO Finished starting backend application: 5.5 ms [Finished 1.338 s after backend start]
root WARN The local plugin referenced by local-dir:/local/home/<username>/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/local/home/<username>/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:/local/home/<username>/.arduinoProIDE/plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
daemon INFO {"level":"info","msg":"Using config file: /local/home/<username>/.arduinoIDE/arduino-cli.yaml","time":"2022-09-15T10:21:32+02:00"}
{"level":"info","msg":"arduino-cli version 0.27.1","time":"2022-09-15T10:21:32+02:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-09-15T10:21:32+02:00"}
{"IP":"127.0.0.1","Port":"46627"}
daemon INFO Daemon is running.
root INFO ---- DURATION: loadCliConfig took 74.283 ms. Args: [] ----
root INFO Resolve plugins list: 94.7 ms [Finished 1.425 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/cortex-debug/extension/dist/extension": 7.1 ms [Finished 1.433 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-arduino-tools/extension/dist/bundle": 5.9 ms [Finished 1.439 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-builtin-cpp/extension": 13.0 ms [Finished 1.452 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-builtin-json/extension": 2.0 ms [Finished 1.454 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain": 0.6 ms [Finished 1.455 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-cs/extension": 155.6 ms [Finished 1.610 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-de/extension": 91.1 ms [Finished 1.701 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-es/extension": 141.6 ms [Finished 1.843 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-fr/extension": 109.3 ms [Finished 1.952 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-it/extension": 81.1 ms [Finished 2.033 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-ja/extension": 102.3 ms [Finished 2.136 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-nl/extension": 25.9 ms [Finished 2.162 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-pt-BR/extension": 129.5 ms [Finished 2.291 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-ru/extension": 118.1 ms [Finished 2.409 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-tr/extension": 83.8 ms [Finished 2.493 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "/local/data/ide/arduino/arduino_2.0.0/resources/app/plugins/vscode-language-pack-zh-hans/extension": 80.4 ms [Finished 2.574 s after backend start]
root INFO Deploy plugins list: 94.7 ms [Finished 2.582 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 201.9 ms [Finished 2.584 s after frontend start]
root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 114.1 ms [Finished 2.743 s after frontend start]
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 161.7 ms [Finished 3.011 s after frontend start]
root ERROR E Failed to connect to localhost:46627 through proxy <address>:<port> with status 403
root ERROR Uncaught Exception:
root ERROR Error: 14 UNAVAILABLE: No connection established
at Object.callErrorFromStatus (/local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/@grpc/grpc-js/build/src/call.js:31:26)
at Object.onReceiveStatus (/local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/@grpc/grpc-js/build/src/client.js:189:52)
at Object.onReceiveStatus (/local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/@grpc/grpc-js/build/src/client-interceptors.js:365:141)
at Object.onReceiveStatus (/local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/@grpc/grpc-js/build/src/client-interceptors.js:328:181)
at /local/data/ide/arduino/arduino_2.0.0/resources/app/node_modules/@grpc/grpc-js/build/src/call-stream.js:187:78
at processTicksAndRejections (node:internal/process/task_queues:78:11)
Same issue on Windows.
It seems the IDE can't connect due to the http_proxy settings (`http_proxy` and `https_proxy` set as an env variables) anyway, user should be warned an issue occurs.
#### Second step:
After removing the `http_proxy` and `https_proxy`, the log show it can go further anyway it fails later when other network access are performed.
Here the logs (Linux):
```text
Starting backend process. PID: 669267
[669288:0915/110646.964823:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
root INFO Backend Object.initialize: 7.4 ms [Finished 1.227 s after backend start]
root INFO Backend Object.configure: 5.7 ms [Finished 1.227 s after backend start]
root INFO Backend MessagingContribution.onStart: 2.9 ms [Finished 1.227 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.7 ms [Finished 1.293 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.6 ms [Finished 1.293 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.3 ms [Finished 1.294 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 66.3 ms [Finished 1.294 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 1.294 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.7 ms [Finished 1.296 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.8 ms [Finished 1.297 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 1.4 ms [Finished 1.298 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.7 ms [Finished 1.299 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.6 ms [Finished 1.300 s after backend start]
root INFO Backend NodeFileUploadService.configure: 2.9 ms [Finished 1.301 s after backend start]
root INFO Backend BoardDiscovery.onStart: 1.5 ms [Finished 1.303 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.8 ms [Finished 1.303 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.7 ms [Finished 1.305 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.8 ms [Finished 1.305 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.306 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 1.306 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 0.5 ms [Finished 1.307 s after backend start]
root INFO Theia app listening on http://localhost:35383.
root INFO Finished starting backend application: 5.4 ms [Finished 1.311 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: /local/home/<username>/.arduinoIDE/arduino-cli.yaml","time":"2022-09-15T11:06:48+02:00"}
{"level":"info","msg":"arduino-cli version 0.27.1","time":"2022-09-15T11:06:48+02:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-09-15T11:06:48+02:00"}
{"IP":"127.0.0.1","Port":"36433"}
root INFO ---- DURATION: loadCliConfig took 69.967 ms. Args: [] ----
daemon INFO {"level":"info","msg":"Loading hardware from: /local/home/<username>/.arduino15/packages","time":"2022-09-15T11:06:48+02:00"}
daemon INFO {"index":"/local/home/<username>/.arduino15/library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-09-15T11:06:48+02:00"}
{"dir":"/local/home/<username>/.arduino15/libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-15T11:06:48+02:00"}
{"dir":"/local/home/<username>/Arduino/libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-15T11:06:48+02:00"}
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file /local/home/<username>/.arduino15/package_index.json: open /local/home/<username>/.arduino15/package_index.json: no such file or directory
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open /local/home/<username>/.arduino15/library_index.json: no such file or directory
root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-09-15T11:06:48+02:00"}
{"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-09-15T11:06:48+02:00"}
{"level":"info","msg":"Updating index","time":"2022-09-15T11:06:48+02:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
#### Third step:
So I've added manually the proxy setting in the newly created config `~/.arduinoIDE/arduino-cli.yaml` (linux)
```yaml
network:
proxy: http://<username>:<password>@<proxy>:<port>
Finally I was able to get the IDE properly started.
### To reproduce
Works behind a proxy.
### Expected behavior
- Warn user properly instead of having empty windows with 'splashscreen' or proposed to configure network proxy.
- Document proxy settings requirements for Arduino IDE 2.0.0
Maybe partially linked to arduino/arduino-ide#29
### Arduino IDE version
2.0.0
### Operating system
Windows, Linux
### Operating system version
Windows10 and Linux ubuntu 20.04 LTS
### Additional context
<a name="workaround"></a>
#### Workaround
1. Select **File > Quit** from the Arduino IDE menus if it is running.
1. Use any text editor to open the file at the following path:
- **Windows:**
```text
C:\Users\<username>\.arduinoIDE\arduino-cli.yaml
(where `<username>` is your Windows username)
- **Linux:**
```text
❗ The `~/.arduinoIDE/` folder may be hidden by default in your file manager and terminal.
- **macOS:**
```text
❗ The `~/.arduinoIDE/` folder is hidden by default. You can make it visible by pressing the <kbd>**Command**</kbd>+<kbd>**Shift**</kbd>+<kbd>**.**</kbd> keyboard shortcut.
1. Add the following lines anywhere in the file:
```yaml
network:
proxy: <proxy scheme>://<username>:<password>@<proxy address>:<port>
Where the placeholders are:
- `<proxy scheme>`: the URL scheme for your proxy server.
One of the following;
- `http`
- `socks5`
- `<username>`: the username of your proxy server credentials.
- `<password>`: the password of your proxy server credentials.
- `<proxy address>`: the address of your proxy server.
- `<port>`: the port of your proxy server.
1. Save the file.
1. Start Arduino IDE.
#### Additional reports
- https://github.com/arduino/arduino-ide/issues/1438#issuecomment-1386600707
- https://github.com/arduino/arduino-ide/issues/1438#issuecomment-1577988752
- https://github.com/arduino/arduino-ide/issues/1438#issuecomment-1722883600
- https://forum.arduino.cc/t/arduino-ide-doesnt-get-any-further-than-splash-screen/1084721
- https://forum.arduino.cc/t/2-0-0-not-loading-windows-10/1035264
- https://forum.arduino.cc/t/arduino-2-0-will-not-start-past-the-loading-screen/1049023/9
- https://forum.arduino.cc/t/adding-a-root-cert-to-the-ide-keystore/1085491/3
- https://forum.arduino.cc/t/v2-0-x-on-linux-behind-proxy/1089208
- https://forum.arduino.cc/t/arduino-2-x-proxy-system-settings/1169532
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My report contains all necessary details
